Cooler Master Announces CM Storm Xornet Gaming Mouse
47,296 (7.53/day)
CM Storm introduces the latest addition to its line of gaming mice, the CM Storm Xornet. Gamers focused on minimalistic designs are the inspiration behind the Xornet. It's an ultra lightweight, claw-grip design with anti-slip rubber side grips that make it well suited for the intensity of extended gaming sessions. The textured stealth black finish allows the Xornet to fly under the radar as a secret weapon at LANs.
Top Grade Components
Focused on a pure gaming experience, the CM Storm Xornet features a highly accurate 2000 DPI sensor that can be adjusted on-the-fly between 500, 1000, and 2000 presets. An Ultra-Step Scroll Wheel Encoder enables you to exercise absolute control over the slightest movements. Omron micro-switches guarantee at least 5,000,000 clicks. Even under prolonged usage, Xornet is geared to outlast the enemy over the course of intense conflicts.
High-Tech Design
Xornet is the first mouse with on-the-fly USB speed adjustments, which allows you to switch from 125Hz to 250Hz, 500Hz or 1000Hz with the push of a button! The Anti-drift Control Sensor maintains flawless control when lifts and drops occur. With these essential features and a sleek design, the CM Storm Xornet lies in wait as your best kept secret.
CM Storm Xornet will be available in October, 2011 for $29.99 MSRP via retail and online stores that carry your favorite Cooler Master, CM Storm, and Choiix gear.
396 (0.07/day)
System Name Just A Gaming Rig.
Processor AMD FX-8320 @4.1GHz, 1.268V
Motherboard ASUS M5A97 Evo R2.0
Cooling Cooler Master Hyper 212 Evo
Memory 8 GB Crucial Ballistix Sport 1600MHz
Video Card(s) Club 3D R9 280X 3GB royalQueen, @1115/1615MHz
Storage OS+Often used stuff: Kingston SSDNow V300 120GB, Mass storage: WD Blue 1TB
Case Zalman Z3 Plus
Audio Device(s) Integrated
Power Supply Corsair CX600M
Software Windows 8.1 64-bit
So this is a more affordable, black version of the CM Storm Spawn?
1,110 (0.18/day)
I just looked on their site and found this gem:
I've always wanted a 10 key less mechanical keyboard but Deck and other manufacturers are waay too expensive. When this will be out it will be under 100$ and I think I will be buying the black switch version if I can find it here.
FreedomEclipse
~Technological Technocrat~
24,168 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
this mouse just looks and smells too much like a Saitek GM3200
my friend had this mouse and i hated the shape of it. It looks like an oversized black ladybird of sorts.
5,392 (0.94/day)
Carrollton, GA
System Name ODIN
Processor AMD Ryzen 7 5800X
Motherboard Gigabyte B550 Aorus Elite AX V2
Cooling Dark Rock 4
Memory G Skill RipjawsV F4 3600 Mhz C16
Video Card(s) MSI GeForce RTX 3080 Ventus 3X OC LHR
Storage Crucial 2 TB M.2 SSD :: WD Blue M.2 1TB SSD :: 1 TB WD Black VelociRaptor
Case Fractal Meshify C
Audio Device(s) Onboard Audio
Mouse Corsair M65
Keyboard Corsair K70 RGB Lux
This is a CM Spawn, but all black and cheaper.
151 (0.03/day)
Fremont, CA
Processor Intel Core 2 Quad Q9550 @ 2.83 GHz
Motherboard ASUS P5Q Pro
Cooling Thermalright Venemous-X
Memory OCZ Reaper HPC 4GB DDR2 1066
Video Card(s) XFX HD-587A-ZNF9 Radeon HD 5870
Storage Western Digital Caviar Black WD6401AALS
Display(s) ASUS VH242H
Case Lian Li PC-A05NB
Power Supply CORSAIR HX Series CMPSU-620HX
Software Windows Vista Ultimate 64-bit
Wow that keyboard looks great. Just need to replace some of those hideous keys.
5,614 (1.02/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
Only 2k DPI ... :shadedshu
