Cooler Master Announces the MasterBox Lite 5 Chassis
47,231 (7.55/day)
Cooler Master, a leading manufacturer of desktop components and peripherals, today announced the release of the MasterBox Lite 5, a high performance ATX mid-tower case with DarkMirror front panel and external customization. The MasterBox Lite 5 case is a straightforward choice for a PC build that looks good and has ample space. The case is armed with full black coating and a PSU cover to make your configuration pop against the black background.
The customizable trim allows users to choose from three different colors to suit their taste accordingly. The four 120mm fans, front and rear watercooling support ensure that performance will not be compromise performance. Harboring up to 400mm of graphic card space, fitting your graphic card won't be an obstacle. Finally, it comes with an edge to edge transparent acrylic side panel to show your internal components while the DarkMirror front panel tings the case with an attractive look, providing full visibility. Choose Your Style, with the MasterBox Lite 5.
"We wanted to introduce a standard and space saving case that still grants paramount characteristics. The MasterBox Lite 5 is compact yet does not sacrifice performance and style," said case product manager, Wei Yang."
The MasterBox Lite 5 can easily go wherever you need your PC to be with its manageable size. Put it on your desk, squeeze it against your bookshelf, or hide it away under your colleague's work space. Following small apartment design, Cooler Master has put effort into structuring layouts to give multiple functions to a single area of the case. This creates room for a little monster build with full-sized graphics cards, liquid cooling, and SSDs. Furthermore, the customization options allow users to "Make It Yours."
The MasterBox Lite 5 will be available to purchase at local resellers in Europe at the end of May .2017, for a suggested retail price of 49.99€.
14,084 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
624 (0.19/day)
I really like the bottom part inside the case. Clean af. Now make the drive bay area just as clean so I never have to close my case for it to look good anymore. Instant coolness factor right there.
It apparently also has a transparent front, which is kinda cool.
Definitely like the direction of this one and nice of them to include an all black version from then start. I see companies forget that all the time.
339 (0.06/day)
System Name Xajel Main
Processor AMD Ryzen 7 5800X
Motherboard ASRock X570M Steel Legened
Cooling Corsair H100i PRO
Memory G.Skill DDR4 3600 32GB (2x16GB)
Video Card(s) ZOTAC GAMING GeForce RTX 3080 Ti AMP Holo
Storage (OS) Gigabyte AORUS NVMe Gen4 1TB + (Personal) WD Black SN850X 2TB + (Store) WD 8TB HDD
Display(s) LG 38WN95C Ultrawide 3840x1600 144Hz
Case Cooler Master CM690 III
Audio Device(s) Built-in Audio + Yamaha SR-C20 Soundbar
Power Supply Thermaltake 750W
Mouse Logitech MK710 Combo
Keyboard Logitech MK710 Combo (M705)
New case in 2017 and no Type-C ?
Nowadays such case need at least 2x USB 3.1 gen1 & 2x gen2 & and one of these gen2 should be Type-C
712 (0.22/day)
Croatia
Processor Ryzen 5 3600 PRO
Motherboard AsRock B450 Pro4
Cooling Thermalright Peerless Assassin 120
Memory Silicon Power XPower Zenith 2x8GB @3200 MHz
Video Card(s) Gigabyte RTX 2070 Super Gaming OC 8GB
Storage Crucial P5 Plus 1TB / Crucial MX 500 1TB
Display(s) Dell P2419H
Case Fractal Design Pop Air /w 3x Thermalright TL-C12C
Audio Device(s) Creative Sound Blaster Z + Edifier R1000T4
Power Supply Super Flower Leadex III 650W
Mouse Microsoft Intelimouse Pro
Keyboard IBM KB-8926
Benchmark Scores Turns on on the first try! Usually.
Now that's how you do LED's.
854 (0.30/day)
Italy
Processor i7 2600K
Motherboard Asus P8Z68-V PRO/Gen 3
Cooling ZeroTherm FZ120
Memory G.Skill Ripjaws 4x4GB DDR3
Video Card(s) MSI GTX 1060 6G Gaming X
Storage Samsung 830 Pro 256GB + WD Caviar Blue 1TB
Display(s) Samsung PX2370 + Acer AL1717
Case Antec 1200 v1
Audio Device(s) aune x1s
Power Supply Enermax Modu87+ 800W
Mouse Logitech G403
Keyboard Qpad MK80
They could've included rubber grommets tho. Also i'd have loved this, slightly smaller, in the 40x40cm with tempered glass and slightly better/tougher materials, i like the design.
AsRock
TPU addict
19,080 (3.00/day)
UK\USA
$49, and for that much add the shit.
339 (0.06/day)
You have a point, but the shit is not having at least one Type-C, at least optional sold separately accessory
7,530 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
There are electrical limitations having Type C in the front! Get real. USB3.1 is enough really.
339 (0.06/day)
I am real, because there's already some motherboards that have a front panel USB 3.1 gen2 header. so why will they put that header if there's any limitations ?
BTW, What electric limitations you're talking about ?
6,184 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
hummmmmm......
another day, another boring, same ole same same rectangular boxen clone drone....
I DO like the semi-transparent front panel idea, but also agree with Xajel about not having any front panel USB-C ports.... they are supposed to be the next gen of universal connector, but they will never be adopted quickly unless/until the case mfgr's start putting them on the front...
So come on folks, just suck up the whole $1.87 cost difference and put 'em in there already, you'll more than offset that with increased case sales in no time :)
peche
Thermaltake fanboy
6,709 (1.83/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
peche
Thermaltake fanboy
6,709 (1.83/day)
System Name Athenna
but l
Looks to me that the tube is slimmer. It's going up to hide.
look at the retention brackets... for the pump / waterblock
3,505 (0.61/day)
but l
CM has been making their own AIO for a while. It could be that they are for Masterbox branded ones. They've been going all hype on masterbox-something.
703 (0.14/day)
Pensacola, FL, USA, Earth
According to their website they will be putting out the 3D print files for that top/bottom trim, if anyone is into that stuff.
peche
Thermaltake fanboy
6,709 (1.83/day)
System Name Athenna
guess that has something related to asetek war,
some brands are including that, for example asus
703 (0.14/day)
Yup yup, my Asus TUF Z270 Mark 2 board has some 3D printed parts on their site. I just don't know anyone local with a 3D printer. :cry:
14,084 (3.82/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
but l
I prefer those to the standard Asetek style fitting, they appear to be simpler to install.
From what I understand, they were including the different colored trims in the box, so you have the option of red, white, black and possibly blue.
So there shouldn't be a need to 3D print your own unless you want a different material or color.
7,530 (1.47/day)
Rīga, Latvia
Software FEDORA 41
Because some engineers are retarded just do what they are told to by PR. USB 3.1 gen2 works in less than 1m lenght, if else it drops down to a plain USB3/2, in reality connecting a case header already halves the size and attaching any other feasible device to it renders the port useless, especially in a large case. We need to consider PCB trace length and signal loss because of the additional connectors(that need to be uber high quality to host a 5GHz signal). There for I said about getting real.
You may see such ports in really small HTPC solutions where are really short cables to the front panel. You will attach your phone cable and the thing will exceed USB specifications.
Use the proper I/O ports in the back, simple as that, this thing really is bleeding edge, and suffers all problems as any high RF device.
14,084 (3.82/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
peche
Thermaltake fanboy
6,709 (1.83/day)
System Name Athenna
thats another interesting thing about them, also i have noticed that CM has overcome wiht a decent product line of almost everything
Ruru
S.T.A.R.S.
12,699 (2.91/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X @ PBO +200 -20CO
Cooling Arctic Freezer 50, EKWB Vector TUF
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 3.3TB of SSDs + 3TB USB3.0 HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p60
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
Mouse Logitech MX518 + Asus ROG Strix Edge Nordic
VR HMD Oculus Rift CV1
