[Case Gallery] COOLER MASTER HAF 932 (CUSTOM GAMER)
expedition17350
3 (0.00/day)
Specs:
1. COOL MASTER (HAF 932) FULL TOWER CASE
2. BIOSTAR (TA890FXE MOTHERBOARD)
3. HDT55TFBRBOX PHENOM 2 1055T (SIX CORE PROCESSOR)
4. LITE ON DVDRW-DL BURNER WITH LIGHTSCRIBE
5. THERMALTAKE (Tt ESPORT PROFESSIONAL) BLACK GAMING MOUSE LAZER
6. THERMALTAKE Tt ESPORT CHALLENGER USB GAMING KEYBOARD (WITH COOLING FAN ATTACH MENTS)
7. APEVIA ATX-WA1100W WARLOCK 1100-WATT (SLI/CROSSFIRE READY) WITH CLEAR SIDE WINDOW AND MULTI LIGHT DISPLAY
8. XFX RADEON HD 5830 1GB PCIE DDR5 (GRAPHICS CARD)
9. MSI DVD-ROM DRIVE (SECONDARY)
10. ALPHS 11-1 (MULTI CARD READER)
11. (6) RED LED 12OMM CASE FANS
12. (1) RED LED 140MM CASE FAN
13. (1) RED LED 230MM CASE FAN
14. (3) 1TB SATA HARD DRIVES
15. (3) 1.5TB SATA HARD DRIVES
16. 16GB DDR3 10600 MEMORY
17. COOLER MASTER V8 CPU FAN
I AM CONSIDERING MODDING THE SIDE PANEL AND GO WITH THE FULL SIDE ACRILIC SIDE FOR THE FULL INSIDE LOOK.
9,871 (1.88/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
wow, you should re type it, use lowercase to type the specs
btw i like the red fans, especially if it paired with black color
expedition17350
3 (0.00/day)
i need help overclocking this setup?
i need help overclocking this setup. i have never done it before and it has been in the stock setting since i got it. i cant find any help on how to overclock it correctly. it says i shold be able to overclock my processor and motherboard but dont know what to change? thinking of seeing if i could overclock it safely to "3.4ghz or 3.6ghz" ? any help would be greatly appreciated. thanks
9,871 (1.88/day)
Jakarta, Indonesia
Case Icute Super 18
look at the bios, biostar has special page for OC it you can use its OC setting or you can try by yourself
expedition17350
3 (0.00/day)
thanks i tried that and it has "automatic over clock settings v6, v8 or v10" or i could switch it to "manual overclock". tried the manual one and i dont know what numbers to change the cpu, northbridge and voltages to to get the stable settings. i have it in the automatic v6 settings and it turbo boosts to 3.3ghz under full processor load but i want it to be there or higher "full time".
