Cooler Master Hyper 212 Halo Edition CPU Cooler and MasterFan MF120 Halo² Fan Now Available
GFreeman
1,747 (2.39/day)
Over the years, the Cooler Master Hyper 212 series has established itself as a leading choice for aftermarket CPU cooling, earning a reputation as one of the most popular custom CPU coolers available. The company has continuously modernized the series by integrating advanced heatsink and fan technologies. With the introduction of the Hyper 212 Halo, Cooler Master has implemented a significant design and technology overhaul, taking the series to new heights.
The Hyper 212 Halo Series boasts the innovative Halo² fan, a refined version of its predecessor. The hardware is adorned with color accents, available in black or white options. The 4 heat pipe tower now sports a matching color treatment and a coordinating top cover showcasing the signature logo, creating a cohesive and stylish design.
The sleek Hyper 212 Halo stands at an impressive 154 mm, ensuring effortless compatibility with most chassis and RAM orientations. Its updated installation brackets accommodate the latest market platforms, making integration a breeze for a wide range of builds.
Hyper 212 Halo models will be available in two eye-catching color choices, catering to a variety of preferences and styles: Hyper 212 Halo Black and Hyper 212 Halo White. Tailor your cooling solution to complement your dark or light builds, adding a contemporary touch that elevates your system's aesthetics.
Specifications:
Colors: Black - RR-S4KK-20PA-R1; White - RR-S4WW-20PA
Supported Platforms: AM4, AM5, LGA1700, LGA1200, LGA1151, LGA1150, LGA1155, LGA1156
Material: 4x heat pipes, aluminium fins
Dimensions: 124 mm x 73 mm x 154 mm
Fan Type: 1x Cooler Master MasterFan MF120 HALO² (120 mm with addressable RGB LEDs - MFL-B2DN-21NP2-R2)
Fan Speed: 650-2050 RPM ± 10%
Fan Airflow: 51.88 CFM (max)
Fan Bearing Type: Rifle bearing
With fan blades increased by 10% over its predecessor, the Halo² delivers enhanced airflow and cooling performance. The hybrid frame structure ensures stability while optimizing fan operational space. Cooler Master has upgraded the driver IC for superior cooling performance, all while minimizing fan noise.
Retaining the sophisticated Dual Loop LED design, the MasterFan MF120 Halo² features our Addressable Gen 2 RGB lighting, offering the ultimate customization to suit your design needs.
Experience the perfect blend of performance and style with the new MasterFan MF120 Halo².
Availability:
The Hyper 212 Halo models will be available at around €38 while the MasterFans MF Halo² are available around €16 for the 120 mm model and €19 for the 140 mm model.
7,607 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Master Halo Chef edition.
8,566 (1.83/day)
Ovronnaz, Wallis, Switzerland
VR HMD Medion Erazer
well, i know what i can get to upgrade the one on my ETS-T50 ... (just the fan ... the 212 would not be an upgrade )
6,479 (1.56/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
FINALLY, a "white" pc part that is actually, well, you know, like *W*H*I*T*E*.... :roll:
hell must be freezin over and/or the world must be ending soon, cause I never woulda thought this possible
:D
8,566 (1.83/day)
:D
aherm ... look the spoiler ... in my previous post ;) the previous Halo was white and so it the ETS-T50 i have since ... hum a whi[te]le :laugh:
6,479 (1.56/day)
Motherboard AZW SEI
Has anyone reached out about your desire for, er, whiteness?
This only reflects my desire for REAL white pc parts.... mainly because I REALLY, REALLY want to build a true "SNOWBLIND" rig once & for all.... I have alot of the parts already, but the last few are STILL not readily available.....but I'm keepin my fingers crossed...
I'm just so damned tired of seein the tagline say "White" then I open the post & see in the pics that it is not ALL white, but rather 95-98% white, with a bunch of other colors/tones/shades thrown in randomly that makes it look like a pile of frozen mish-mashed dogpoo :)
If you are/were attempting to somehow infer that I have no appreciation for colors (either in pc parts or otherwise) then you are sadly mistaken :D
