Cooler master hyper 212 RGB?
1,299 (0.20/day)
Strongsville, Ohio
System Name Prebuilt - because covid...
Processor Intel Core i7-11700F
Motherboard Gigabyte b560 ds3h ac-y1
Cooling Cooler Master 212 BE
Memory 16 GB
Video Card(s) Asus RTX 3060 Ti
Storage 1 TB Wd, 500 SSD
Display(s) 27in Curved Samsung
Case CyberpowerPC
Audio Device(s) -
Power Supply Antec NeoECO C 520 watt
Software Win 8.1 Pro
Benchmark Scores 3DMark Score 7754.0 3DMarks Graphics Score 8392.0 Physics Score 6498.0 Combined Score 6062.0
So I replaced the stock cooler that came with the prebuilt that I bought. The fan that came on it was a cooler master plugged into an apevia controller, that fan would change with the case fans. I plugged the fan in exactly as it came off and it stays a static color. I then tried to connect to included controller for the fan from the CM box and can change the color independently. Am I missing something, or can I not change the color with the other fans? I feel like this should have just been a plug and play and done... thanks in advance.
This is what came off: https://www.newegg.com/cooler-maste...AJjf7bUXRajiZ1KTuFwaAgEpEALw_wcB&gclsrc=aw.ds
This is what replaced it: https://www.newegg.com/cooler-maste...ion-_-9SIB3D9GMJ4624-_-Product&quicklink=true
13,762 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Is the new Cooler ARGB?
The original was only RGB which is a different voltage.
Combing the two types will render the 5V ones inoperable.
ps your second link is broken.
1,299 (0.20/day)
Strongsville, Ohio
Memory 16 GB
Case CyberpowerPC
Audio Device(s) -
They have the same exact connectors on them
the box doesn't specify argb but RGB 16.7 million colors. Old fan shows 12v
7,762 (2.91/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
They have the same exact connectors on themView attachment 227529 the box doesn't specify argb but RGB 16.7 million colors. Old fan shows 12v
That voltage is for the fan motor, and all standard PC fans are 12V. LED voltages are separate from this, and there are both 5V and 12V standards. Show a pic of the RGB connector from both fans?
Edit: ah, yes, that fan label does state ARGB. The stock case fans are most likely not ARGB, and the controllers will then not be compatible. I would assume your motherboard has an ARGB header? Plug it in there instead.
13,762 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
4 pin connector for the leds is RGB 12V, 3 pin is ARGB 5V.
1,299 (0.20/day)
Strongsville, Ohio
Memory 16 GB
Case CyberpowerPC
Audio Device(s) -
Both fans had a 4 pin 12v to mobo, and 3 pin for led - conenctors were 100% Identical, I unhooked them, installed the heatsink and reconnected in the same positions --- I'm sure it's something really simple as far as resetting the controller to "see" the new fan or something, I'm just not sure - I've never dealt with argb (rgb) fans before. My old system I used cold cathode tubes, and this only has RGB as what it came with, but it bugs my OCD that they don't work together yet lol.
Both the old fan and new fan have this exact pin setup for the fan and led connections. This is the old one (new is currently installed)
That ARGB fan is what I removed from the cheap cooler they used - but it synced perfectly with the case lights. The pinouts were exact so I tried to reconnect exactly how it connects --- I know the motherboard supports the cpu fan and I can hook it directly into the motherboard - But I was hoping to control it along with the case fans so I can shut them off at night or change the colors in one move versus having to get into the bios. I'm almost certain the fan will work--- just need to figure out the right configuration with wiring or "learning" the controller to accept it or vice versa.
13,762 (3.83/day)
Sunshine Coast
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Odd as they are both CoolerMaster and should sync the same.
1,299 (0.20/day)
Strongsville, Ohio
Memory 16 GB
Case CyberpowerPC
Audio Device(s) -
Which was my thought as well. I wrote to the PC builder to see if there is a sync setting from the controller, I may try and connect the old fan in series and see if it will still be controlled as well.
