Cooler Master Introduces the MasterAir MA620P and MA621P CPU Coolers
889 (0.34/day)
Cooler Master, a leader in PC cooling solutions, introduces the MasterAir MA620P and MA621P that pushes the performance of air cooling beyond AIO liquid cooling. Cooler Master's supercharged heatsink is a combination of two built heatsinks with CDC 2.0 technology and two MasterFan MF120R RGB that is able to transfer and dissipate heat at extremely efficient levels. The MasterFan MF120R RGB are also certified by ASUS, Gigabyte, MSI and Asrock with their motherboard RGB sync.
Supercharged Dual Heatsink Dual ML120R RGB fans
MasterAir MA620P and MA621P TR4 edition supercharges your CPU cooling by doubling the surface area by combining two heatsinks each accompanied by two MasterFan MF120R RGB to ensure enough air pressure brings out the heat quickly enough to continually remove heat from the CPU. An optional 3rd fan is possible to take you to the next level.
RGB Certified for ASUS, Gigabyte, MSI and Asrock
MasterAir MA620P and MA621P TR4 edition come with two MasterFan MF120R RGB and a RGB controller. You have the option of controlling with a click of a few buttons to set the color, intensity level and effects or use the software from the motherboard manufacturer. Because Cooler Master RGB fans are fully compatible with ASUS, Gigabyte, MSI and Asrock, you are guaranteed that full system sync of RGB is possible.
Exact fitting Base for TR4-SP3 (MA621P TR4 edition only)
MasterAir MA621P TR4 edition has an exact fitting base for the TR4-SP3 ensures the AMD Threadripper CPU has optimal surface contact and thus optimal heat transfer. The base also includes the Continuous Direct Contact Technology 2.0 (CDC 2.0), to have direct integration with heatpipes.
FreedomEclipse
~Technological Technocrat~
24,173 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Memory 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming) | 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
This is some 'next level' sh*t right here
13,791 (1.87/day)
I still prefer AiO's because I can place dissipating element somewhere else. Tower air coolers need to be above CPU. No way around that. Where AiO leaves me empty space around CPU and I can place the radiator on the intake. As a result, my system only has 1x 140mm intake fan to cool the CPU. And that's it. It's an intake case fan that also pushes air through the AiO radiator (which is not even screwed anywhere, it just sits on two anti vibration pads on top of HDD cage behind the intake fan). It's quiet and has the cooling capacity to keep overclocked 5820K (6x 4.5GHz) below 70°C under normal conditions and under 85°C under extreme load while being almost inaudible). Then I just channeled the air with a clear acrylic ramp over the graphic card so it has a nicer path tot he rear exhaust fan. It works brilliantly, a system I've used in old miniATX case, but works great in midiATX as well. Took me years to figure this out you don't need double fans on the AiO radiator to achieve good cooling at excellent noise levels.
4,677 (0.94/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Looks a lot like the scythe fuma, crazy are these on the way to you for a review??
543 (0.08/day)
System Name Ed-PC
Processor Intel i5-12600k
Motherboard Asus TUF Z690 PLUS Wifi D4
Cooling Noctua NH-14S
Memory Crucial Ballistix DDR4 C16@3600 16GB
Video Card(s) Nvidia MSI 970
Storage Samsung 980, 860evo
Case Lian Li Lancool II mesh Perf
Power Supply Corsair RM750x
Software Win10 Pro 64bit
3,946 (0.63/day)
Police/Nanny State of America
Processor OCed 5800X3D
Motherboard Asucks C6H
Cooling Air
Memory 32GB
Video Card(s) OCed 6800XT
Storage NVMees
Case Freebie glass idk
Audio Device(s) Sennheiser
Fan in the middle is dumb. Precious fin area is lost. They'll never beat 10 yr old coolers like this.
484 (0.16/day)
Repost of a repost of a repost of a repost
Not the article but the cooler itself
3,014 (0.64/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
... and what's with the top air intakes? When your cpu cooler is sticking through the hub and you are driving really fast?
2,094 (0.53/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
5,976 (1.04/day)
Cybertron aka Canada
Processor Intel Core i5-3570K
Motherboard Asus P8Z77-V Pro
Cooling Noctua NH-D14
Memory 8GB Mushkin Blackline DDR3-1600
Video Card(s) Gigabyte GTX 670
Storage Intel 520 60GB, Seagate Barracuda XT 2TB
Display(s) BenQ 24" XL2420T
Case Corsair 550D
Audio Device(s) Sennheiser HD600, Audeze LCD-3F, Mytek Stereo 192 DSD, La Figaro 339, Burson HA-160, Geek Pulse X
Power Supply Corsair AX650
Mouse steelseries Sensei MLG edition
Keyboard Cooler Master QuickFire Pro
Software Windows 7 64-bit Home Premium
great
