- Dec 6, 2011
- 4,784 (1.02/day)
- Still on the East Side
Cooler Master, an industry leading chassis, thermal solution, peripheral, and accessory manufacturer today introduced a flexible new ergonomic stand that truly revolves around your mobile life, the NotePal ERGO 360 laptop cooling stand and tablet stand.
All Encompassing
NotePal ERGO 360 focuses on that single overriding need to have one powerful accessory that works with the products that keep you mobile. It incorporates the design and efficiency of our ergonomic laptop cooling stands with the versatility of a tablet stand into one easy to use product.
As a laptop cooling stand, users get a high quality ergonomic stand that helps reduce hand and wrist fatigue caused by using their laptops for long periods of time. This comfort level can be selected by choosing one of three available height settings.
Utilizing these comfortable angles helps reduce the instance of injuries from prolonged periods of laptop or tablet use. Avoid the hassle of choosing between functions by removing the adjustment stand to reveal a laptop cooling pad and an adjustable height tablet stand.
This adjustable height stand rotates 360 degrees for easy viewing. Adding to the convenience, anti-slip holders keep your laptop stable and cable management grooves provide a place to easily manage the attached USB cable.
Excellent Cooling
A whisper quiet 80 mm fan significantly cools the base of your laptop. This airflow is directed by a high performance perforated aluminum cooling surface that assists in maximizing heat dissipation.
ERGO 360 is compatible with laptops up to 17". NotePal ERGO 360 releases on September 2012. MSRP is $34.99.
All Encompassing
Excellent Cooling
