Cooler Master Launches the MasterFan Halo² Case Fan
47,279 (7.53/day)
Cooler Master has launched the MasterFan Halo², the new version of its popular MasterFan Halo series. The new Dual Loop LED Case Fans feature a 10% increase in fan blade size for improved airflow and cooling performance, while the hybrid frame structure ensures stability without compromising operational estate. The upgraded driver IC also enhances cooling performance while minimizing fan noise, with RPM speeds of up to 2050 RPM.
"The MasterFan Halo² Series builds on the success of its predecessor and delivers even better performance and aesthetics," said Jimmy Sha, CEO of Cooler Master. "We know how important it is for gamers and PC enthusiasts to have reliable, high-performing cooling solutions, and the MasterFan Halo² delivers on that promise with its enhanced design and features."
The MasterFan Halo² comes with Addressable RGB control, allowing for customization of every LED to fit any design needs. It will be available in 120mm and 140mm sizes, as well as black and white colorways. The MF120 Halo² will be available for $24,99 and MF140 Halo² will be available for $29,99.
Cooler Master MasterFan Halo² feature highlights:
  • MF120 Halo² and MF120 Halo² White Edition
  • 120 mm, up to 2050RPM
  • 10% Larger Fan Blades
  • Hybrid Frame Design
  • More vibrant ARGB lighting
  • Updated Fan Control IC
MF140 Halo² and MF140 Halo² White Edition
  • 140 mm, up to 2050RPM
4,603 (0.92/day)
They have been listed on their website for weeks at this point. Also power consumption for LEDs is absurd.
