- Oct 9, 2007
- 47,393 (7.52/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
The Cooling X Pro from Cooler Master is a case designed for the "cooling defined build," a high-end PC build where the primary focus is on high-performance liquid cooling of the CPU, GPU, and NVMe SSD. The case reimagines the layout of key components in the build, such as positioning the PSU toward the front, putting the CPU and VGA under a proprietary liquid cooling solution, and using a large, common square 360 mm x 360 mm radiator to dissipate heat from both. This is either ventilated by nine 120 mm fans, or a large diameter fan.
Besides this unique cooling solution, the Cooling X Pro appears to feature an aluminium inner chassis similar to the MasterFrame Aluminium series that the company also showcased this year. The various panels aren't as modular, the one facing the left side is a curved tempered glass. The right probably features a coarse mesh panel to let the 360 mm x 360 mm radiator breathe.
