cooling for a 5ghz 11700kf
1,955 (0.42/day)
Denmark
Processor Ryzen 7 7700
Motherboard Asrock B650 PG LIgtning
Cooling artic freezer 36
Memory G.Skill Flare X5 DDR5-6000 - 32GB - CL30
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Marantz PM 6007 Triangle Esprit Titus Ez
Power Supply Corsair RM850X White
Mouse Logitech G PRO Superlight
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free bitdefender
Corsair 4000d airflow i7 11700kf at 1.3450 volt and 4.9ghz on all core, be quiet dark rock pro 4 4x120mm be quiet shadow wings 2
I want to run it at 5ghz but need alot more cooling
360mm aio in the front theres no cool air in the case for my gpu, with 2x140 mm fans in the top or 3x120 where nr 3 is close to the i/o shield
I can't deside on a 240 or 280mm aio, is 240mm enough, i don't want to go crazy in price and i hate pump noise
I have enough 140mm artic p12 pwm pst fans in case i need some.
Artic freezer is really good but also thick and not to me super silent (pump and the small vrm fan)
100 euros
10,895 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
280 is good -- almost as good as 360. 240 push pull / or 280 should be enough BUT at 1.34v is a lot of volts for 4.9 not sure its going to be worth pushing that for 100Mhz even with a 360. You will probably gain more spending time on Ram sub-timing/Ring OC.
Maybe see if you can dynamically OC to 5.1/5.2 @ ~1.4v and then drop bins past 90C back to 4.9 1.34 on all core?
That way your games will run fine @5.2 but if you decide to play some cinebench the chip won't sit at 100C bouncing off the throttle the whole time.
If you want quiet you will need a 360mm push pull in the front, with additional fans to push cold air from the bottom compartment into the GPU.
1,955 (0.42/day)
Denmark
No space for fan(s) at the buttom compartment
What 280mm aio can do it, with focus on pump noise
163 (0.14/day)
Processor 6900K @ 4.3Ghz
Motherboard Gigabyte x99 ultra gaming
Cooling H115i pro xt
Memory Tridentz 3200 32gb
Video Card(s) Galax RTX 4070
Storage 970 EVO 500gb
Display(s) AOC g2460pf
Case Non branded shit
Power Supply Corsair Rm550x
Mouse Logitech G603 Double click mode
Keyboard TGK205
Software Win 10
What 280kmm aio can do it, with focus on pump noise
I use a h115i pro xt, on low and mid rpm the pump dont make noise
1,955 (0.42/day)
Denmark
have thought about that corsair aio
163 (0.14/day)
Keyboard TGK205
Software Win 10
When you search for an aio the first thing you have count is leakage damage warranty, corsair have it
1,955 (0.42/day)
Denmark
Deepcool have the anti leak systme and good warranty but they might not be the best aio but the can be had for under 100 euros, dollars, even in a 3 fan version
2,373 (0.57/day)
Audio Device(s) A LOT
From what I understand the Arctic LF II is the quietest AIO pump available? If that’s too loud I’d consider EK or Alphacool, not sure if Seiftech is still selling their solution.
1,955 (0.42/day)
Denmark
The pump in the artic freezer II is no more quiet then kranken x.. and Cooler Master MasterLiquid ML360R RGB
It's also thicker than most aios, it can be to thick depending on what mb,case or even ram you have
Once had a Alphacool 360mm aio, it has alot of coilwhine, it was disappointing, they are also not whitin my budget
163 (0.14/day)
Keyboard TGK205
Software Win 10
That anti leak system its more a marketing than a real feature all aio can leak and The most important is when it fail, you will covered by warranty and not to need send overseas. the most performer is lian li galahad, but dont know about warranty.
I choose corsair because it have a local post 50km far from my house, I can delivery by my hands if it fail :laugh:
1,955 (0.42/day)
Denmark
2,373 (0.57/day)
Just curious, do you have a source for these noise measurements? I haven’t found a place that tests pump noise since SPCR and would love to see it! Everything I’ve read said the Arctic should be quieter than the Asetek/Kraken but I haven’t seen comparisons to the new CM dual-chamber pumps.
65mm — quick google says it’ll only fit in the 4000d if you have low profile RAM
1,533 (0.39/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
You'll need to power limit it for AVX
1,457 (0.34/day)
Australia
OP, when you say you want run it at 5GHz, is that all cores? 1.345v @ 4.9 all core can escalate substantially when at 5.0 all core. If it's the mobo in your system specs, it will struggle with 12+1+1 power delivery.
1,533 (0.39/day)
Grunn
Case FD Define 7
That board isn't fantastic but I am unconvinced that it will be a problem before the CPU cooling is, at least under AVX with that kind of voltage. Even the arctic 240, which is basically the only AIO at that price point will not manage to cool the ~300w or so the CPU will pull under AVX.
1,955 (0.42/day)
Denmark
I have had the mentioned aio's, i just now have a cpu i need a little more cooling to get it to 5ghz
Depends on how big the heatsinks are on the mb, since i have to use it in the top, i can't see no other way of getting cool air in the case if i have to use the top of the case for in or outtake (max 3 fans, top fans out and the rear as intake or the opposite make no sense to me)
when i want 5ghz i can't use a 120 or 140mm aio + what ever fan i can use in the front for more cool air when top fans are
exhaust
it's of course 5ghz on all cores,it boosts to 5ghz, have had no problems with the mb
occt, it's of course alot hotter in ibt and prime 95 small fft
1,212 (0.63/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
How big/many can your case fit? An aio might work but you may need a bigger one to get the job done or a second smaller rad (120-140mm) in addition to the 240mm which you can bolt to your rear exhaust fan.
How would the 240 be oriented in your case? Sideways on the top of the case or vertical at the front? Also are you using it as an exhaust or intake setup? And is a 360mm out of the question?
1,955 (0.42/day)
Denmark
3 fan aio up to 3 case fans or 2 fan aio and 4 case fans
360 is out of the way since it can only be used in the front, there for i wouldn't have enough air intake fans since the air from the aio is lukewarm, nothing like only case fans in the front would blow into the case
Top 2 exhaust fans, 1 rear intake, the cold air from the rear fan wouldn't do nothing for my gpu since the 2 top fans would take all of the cool air out of the case but for it can make a difference
2 intake at the top would blow cold air in to the case only to be blown out (atleast by the fan closest to the rear fan) with only 1 fan blowing cold air into the case (just between the front and the gpu)
My old cpu was at 4.8ghz i wanna do a little more, 5ghz is where i want to stop but it's all cores not 5.1-5.3 on 3-4 core and 4.6-4.8 on all cores
At 5ghz and 1.380 volt it peak many times at 100c in occt, peak at 4.9 ghz and 1.345 volt is 81c
I need a lot of cooling for 5ghz, what is the highest tdp air cooler and 240,280 and 360 aio ?
1,533 (0.39/day)
Grunn
Case FD Define 7
It depends on the CPU, a 3600 for example will only ever be able to draw around 90w under any ambient cooling because the die is too small.
My rough estimates for rocket lake 8c parts are 260-320w (package power) custom water, <250w AIO, <200w dual tower air cooling. These are assuming "reasonable" fan noise limits and conventional thermal paste, you can always squeeze a bit more out of them if you use really fast fans and liquid metal.
My load voltage for my 11900k is around 1.35v, and that puts it at around 290w when rendering a video in resolve with AVX enabled and AVX512 disabled, which is about the limit for my cooling. Based on the experience of other people I would say pushing heavily into the 1.35v+ range is not feasible for high current loads such as these. If you want higher boost clocks for games you will have to use a power limit to keep it in check under higher current loads like rendering.
1,955 (0.42/day)
Denmark
A 3600 can't do 5ghz on all core
occt 4.9ghz 220 watt ibt and prime small fft it goes crazy in temps and wattage
1,533 (0.39/day)
Grunn
Case FD Define 7
That's not the point. A 7700k can do 5GHz but even under a custom water loop with a chiller you won't get it to 200w because again, the active die area of the cores is too small.
That's just rocket lake for you. You either have to disable AVX or use a power limit if you want those loads to be usable.
1,400 (0.30/day)
78°55' N, 11°56' E
System Name -aLiEn beaTs-
Processor Intel i7 11700kf @ 5.055Ghz
Motherboard MSI Z490 Unify
Cooling Corsair H115i Pro RGB
Memory G.skill Royal Silver 4400 cl17 @ 4403mhz
Video Card(s) Zotac GTX 980TI AMP!Omega Factory OC 1418MHz
Storage Intel SSD 330, Crucial SSD MX300 & MX500
Display(s) Samsung C24FG73 144HZ
Case CoolerMaster HAF 932 USB3.0
Audio Device(s) X-Fi Titanium HD @ 2.1 Bose acoustimass 5
Power Supply CoolerMaster 850W v2 gold atx 2.52
Mouse Razer viper 8k
Keyboard Logitech G19s
Software Windows 11 Pro 21h2 64Bit
Benchmark Scores ► ♪♫♪♩♬♫♪♭
What is your cache frequency like?
I can get away with 1.28v at 5ghz, but need cache 4.0ghz.
If I set cache 4.1ghz it will auto jump to 1.41, 4.3ghz is already 1.47v.
That said at 4.3ghz i can get away with 0.130v offset and make it 1.335v.
1,955 (0.42/day)
Denmark
No clue
1,400 (0.30/day)
78°55' N, 11°56' E
Cache, ring is one and the same thing.
Msi in my case auto set to 4.1ghz which would auto raise voltage more.
Post cpuz memory tab or aida64 memory benchmark
1,955 (0.42/day)
Denmark
