Cooling Help for R7 7700X
ìZany
1 (0.03/day)
guys i need a recommendation for cooling the ryzen 7 7700X i currently have an but it still keeps high temps
I do not agree to hold more than 75 Degrees of War Thunder game
Gigabyte X670 GAMING X AX
Arctic Liquid Freezer II 360G X AX
F5-6000J3636F16G x 2
Evga RTX 3070 Ti
Use 105W TDP
AsRock
TPU addict
18,974 (3.03/day)
UK\USA
You could limit the PPT, not knowing your board might make it harder for people to help you. I use the PPT 130w ( there is a mv one too on my board ) by default the chip will run 143w.
On my board i use the curve optimizer -26 ( all cores ), you might have to lower that number as you may get crashes so maybe experiment with -15.
But 75c isn't bad at all. You could use HWinfo64 to monitor.
5,580 (0.78/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Logitech G613
Yet another clueless new poster who hasn't bothered to do even the most basic research on what temperatures are normal for Zen 4... use a search engine and stop wasting our time.
3,194 (1.76/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 80C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.39V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~466W (366W current) PowerLimit, 1060mV, Adrenalin v24.7.1
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSBuild 22631.4037), upgraded from Win10 to Win11 on Feb 2024
Evga RTX 3070 Ti
Use 105W TDP
It should be known by now that any Ryzen 7/9 almost no matter the cooling capacity upon them, they will occasionally hit 75-80C if not more under low-medium loads like gaming.
Its the average temp that matters most and I bet its far less than max/peak.
Peaking(bursting) at 75C is perfectly fine when max operating temp is 90C and critical is way over 100C.
If you dont like it you can just set its max temp in BIOS/UEFI to your liking, but prepare to potentially loose some high boosting under single core/low/medium load.
Ive set mine (5900X) to 75C, so when gaming it peaks there with an avg of 55-60C, depending the game and ambient conditions.
