System Name | Space Heater MKIV |
Processor | AMD Ryzen 7 5800X |
Motherboard | ASRock B550 Taichi |
Cooling | Noctua NH-U14S, 3x Noctua NF-A14s |
Memory | 2x32GB Teamgroup T-Force Vulcan Z DDR4-3600 C18 1.35V |
Video Card(s) | PowerColor RX 6800 XT Red Devil (2150MHz, 240W PL) |
Storage | 2TB WD SN850X, 4x1TB Crucial MX500 (striped array), LG WH16NS40 BD-RE |
Display(s) | Dell S3422DWG (34" 3440x1440 144Hz) |
Case | Phanteks Enthoo Pro M |
Audio Device(s) | Edifier R1700BT, Samson SR850 |
Power Supply | Corsair RM850x, CyberPower CST135XLU |
Mouse | Logitech MX Master 3 |
Keyboard | Glorious GMMK 2 96% |
Software | Windows 10 LTSC 2021, Linux Mint |
System Name | Desktop-TJ84TBK |
Processor | Ryzen 5 3600 |
Motherboard | Asus ROG Strix B350-F Gaming |
Cooling | ARCTIC Liquid Freezer II 120mm, Noctua NF-F12 |
Memory | B-Die 2x8GB 3200 CL14, Vengeance LPX 2x8GB 3200 CL16, OC'd to 3333 MT/s C16-16-16-32 tRC 48 |
Video Card(s) | PNY GTX 690 |
Storage | Crucial MX500 1TB, MX500 500GB, WD Blue 1TB, WD Black 2TB, WD Caviar Green 3TB, Intel Optane 16GB |
Display(s) | Sceptre M25 1080p200, ASUS 1080p74, Apple Studio Display M7649 17" |
Case | Rosewill CRUISER Black Gaming |
Audio Device(s) | SupremeFX S1220A |
Power Supply | Seasonic FOCUS GM-750 |
Mouse | Kensington K72369 |
Keyboard | Razer BlackWidow Ultimate 2013 |
Software | Windows 10 Home 64-bit, macOS 11.7.8 |
Benchmark Scores | are good |
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Yep, it's a real GTX 750. I think the 4GB variant is pretty rare, but it does exist.
1DVI 1 VGA right?Yep, it's a real GTX 750. I think the 4GB variant is pretty rare, but it does exist.
It's weird that GPU-Z reports Samsung memory when the card has Elpida. @W1zzard, care to chime in on this? I know that GPU BIOSes can support memory from many different sources.
I couldn't find a BIOS for this card in the DB; would you be able to submit it via GPU-Z?
The OP's card has one DVI, one HDMI, and a removable VGA port. That's a pretty standard layout for half-height GPUs.1DVI 1 VGA right?
Yup its 4GB for sure because 4Gb is .5GB x8 chips is 4GB. GM107 is maxwell which is GF GTX 700 seriesFound the datasheet for the memory chips.
EDW4032BABG-60-F Datasheet(PDF)
Part #: EDW4032BABG-60-F. Download. File Size: 222Kbytes. Page: 17 Pages. Description: 4G bits GDDR5 SGRAM. Manufacturer: Elpida Memory.www.alldatasheet.com
The card has eight 4Gb GDDR5 memory chips (two are hidden under the sticker), for a total of 32Gb of Vram, or 4GB.
It's a full-sized HDMI. Most of the half-height cards I own use that exact layout.Yup its 4GB for sure because 4Gb is .5GB x8 chips is 4GB. GM107 is maxwell which is GF GTX 700 series
Oops i wasnt looking at the hdmi and they used a ribbon cable for the vga
@sam_86314 is that a mini hdmi or full? I dont deal with hdmi as I prefer dp lol
Interesting enough the 2 bios that match his bios version have mini hdmi so it seems a different bios version would need to be used.It's a full-sized HDMI. Most of the half-height cards I own use that exact layout.
The main exceptions are my Quadro 600s and my Radeon HD 7750, The Quadros have a DVI and a full-sized DP; no VGA. The Radeon has two full-size HDMIs and a mini DP.
HDMI - Wikipedia
en.wikipedia.org
I wouldn't think that would matter. Mini HDMI has the exact same pins as full-size; they're just arranged differently.
This is the replacement from CORN. The HDMI on the first one I got died after just over 2 months of use. This one (replacement for 5 days) works; but, since the BIOS is giving false information, it's a bit worrisome. The manufacturer seems to be engaging in fraud. Should I just send it back and ask for a refund? I got it from Newegg. Thanks!!
System Name | Rainbow Sparkles (Power efficient, <350W gaming load) |
Processor | Ryzen R7 5800x3D (Undervolted, 4.45GHz all core) |
Motherboard | Asus x570-F (BIOS Modded) |
Cooling | Alphacool Apex UV - Alphacool Eisblock XPX Aurora + EK Quantum ARGB 3090 w/ active backplate |
Memory | 2x32GB DDR4 3600 Corsair Vengeance RGB @3866 C18-22-22-22-42 TRFC704 (1.4V Hynix MJR - SoC 1.15V) |
Video Card(s) | Galax RTX 3090 SG 24GB: Underclocked to 1700Mhz 0.750v (375W down to 250W)) |
Storage | 2TB WD SN850 NVME + 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000P NVME USB 3.2 |
Display(s) | Phillips 32 32M1N5800A (4k144), LG 32" (4K60) | Gigabyte G32QC (2k165) | Phillips 328m6fjrmb (2K144) |
Case | Fractal Design R6 |
Audio Device(s) | Logitech G560 | Corsair Void pro RGB |Blue Yeti mic |
Power Supply | Fractal Ion+ 2 860W (Platinum) (This thing is God-tier. Silent and TINY) |
Mouse | Logitech G Pro wireless + Steelseries Prisma XL |
Keyboard | Razer Huntsman TE ( Sexy white keycaps) |
VR HMD | Oculus Rift S + Quest 2 |
Software | Windows 11 pro x64 (Yes, it's genuinely a good OS) OpenRGB - ditch the branded bloatware! |
Benchmark Scores | Nyooom. |
System Name | 4K-gaming / media-PC |
Processor | AMD Ryzen 7 5800X / Intel Core i7-6700K |
Motherboard | Asus ROG Crosshair VII Hero / Asus Z170-A |
Cooling | Arctic Freezer 50 / Thermaltake Contac 21 |
Memory | 32GB DDR4-3466 / 16GB DDR4-3000 |
Video Card(s) | RTX 3080 10GB / RX 6700 XT |
Storage | 3.3TB of SSDs / several small SSDs |
Display(s) | Acer 27" 4K120 IPS + Lenovo 32" 4K60 IPS |
Case | Corsair 4000D AF White / DeepCool CC560 WH |
Audio Device(s) | Creative Omni BT speaker |
Power Supply | EVGA G2 750W / Fractal ION Gold 550W |
Mouse | Logitech MX518 / Logitech G400s |
Keyboard | Roccat Vulcan 121 AIMO / NOS C450 Mini Pro |
VR HMD | Oculus Rift CV1 |
Software | Windows 11 Pro / Windows 11 Pro |
Benchmark Scores | They run Crysis |
Exactly this is what I mean@W1zzard is this a bug with GPU-Z reading the VRAM wrong?
I dont believe it is, I'm thinking a bios was modded@W1zzard is this a bug with GPU-Z reading the VRAM wrong?
Only way to know is when the op reappears and reloads gpu-z, if the bios even states Samsung, Micron Hynix, Elpida Qimonda. Sometimes GPU drivers are skewed too.W1zz is the fellow to find out if the BIOS is giving false info, or if GPU-Z has made a mistake on a rare card
Processor | Ryzen 7 5700X |
Memory | 48 GB |
Video Card(s) | RTX 4080 |
Storage | 2x HDD RAID 1, 3x M.2 NVMe |
Display(s) | 30" 2560x1600 + 19" 1280x1024 |
Software | Windows 10 64-bit |
My thoughts exactlyGood question, could be modded VBIOS, or simply using the Samsung VBIOS on Elpida (which often works), or using the wrong resistor strap setting on the board by accident (or intentional).
It is a full-HDMI. Thanks.Yup its 4GB for sure because 4Gb is .5GB x8 chips is 4GB. GM107 is maxwell which is GF GTX 700 series
Just uploaded. Below is the link.Well there is a risk of the port to stop working. Is why I ask. I will be giving out the bios but I would like for the OP to get a link to the bios that is currently on the card for comparison
I just looked up his Device ID 10DE 1381 and Subsystem ID 10DE 1073 and only 1G and 2G 750s appear.
Can you please re-open GPU-Z and click the black arrow next to the white UEFI checkbox please?
Then attempt to upload the bios through GPU-Z to the VGA Bios Collection/database.
You may be prompted that the bios is already in the database with a link.
Please copy and paste that link here, I need to do some file comparisons
I know it's not a fake card but the oem did appear to mod a newer bios version
Your concern is correct. The HDMI did stop working. They sent me the replacement -- which is the one I just uploaded the BIOS from. THANKS!!Well there is a risk of the port to stop working. Is why I ask. I will be giving out the bios but I would like for the OP to get a link to the bios that is currently on the card for comparison
System Name | Msi PC |
Processor | Ryzen 5 5600 |
Motherboard | MSI b550 gaming gen 3 |
Cooling | deepcool gammaxx 200t (deepcool z10 paste) |
Memory | 32(4x8) gb g.skill 3200 (qvl) |
Video Card(s) | MSI RTX 3060 8GB Ventus 2X OC |
Storage | Ssd Crucial mx500 500 gb |
Display(s) | Philips 222V8LA/00 dp 75 hz freesync |
Case | Q-Tech Hermes 1004 (4x12cm fans) |
Audio Device(s) | X-fi titanium pcie (Support Pack 8.0 (Refresh 3)) |
Power Supply | Corsair cv 750w bronze |
Mouse | PATRIOT PV530OULK VIPER V530 (500hz) |
Keyboard | Gigabyte force k81 |
Software | Windows 11 |
Yes; but, the card is a replacement they sent due to a failed HDMI output. eidairman 1 mentioned that this could cause an HDMI failure; and, from what I've experienced so far, the concern is legitimate. Thanks.I simply believe that they left the same PCB and vbios and because they don t have anymore Samsung vram put there elpida tested that it works and they sell it.
Your current bios shows mini hdmi which i believe is incorrect for your card.Yes; but, the card is a replacement they sent due to a failed HDMI output. eidairman 1 mentioned that this could cause an HDMI failure; and, from what I've experienced so far, the concern is legitimate. Thanks.
