I only have three SP120 RGB Elite fans in the front of the case right now, i want to add 3 more fans. The case allows for configurations like these, how would it work if i used the same configuration in picture 1 but i instead use 3 120mm fans in the front? Would it be better than a full 120mm configuration?
In short: should i get 140mm fans for the top of the case or should i keep it all 120mm?
