- Oct 9, 2007
- 47,177 (7.56/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
CORSAIR, a world leader in enthusiast memory, high-performance gaming and PC components hardware today announced a new addition to its acclaimed range of RGB cooling fans, the LL Series. 16 Brilliant independent RGB LEDs encircle each LL series fan and its central hub (12 LEDs in the outer loop and four in the inner), all controllable using CORSAIR LINK software to create a stunning symphony of color.
CORSAIR has managed to pack even more stunning RGB lighting into the LL Series, with both a 12 RGB LED loop around the fan's edge and an internal four RGB LED loop, creating a virtually limitless amount of color options. The included CORSAIR Lighting Node PRO allows for in-depth software lighting control for up to 12 CORSAIR RGB fans or eight CORSAIR RGB Lighting strips, making it easy to tie all your PC's RGB lighting together. With CORSAIR LINK software. So go ahead and turn the lights on, you'll want to see this.
Available in 3x 120mm kit, 2x 140mm kit or individually, combine LL series fans with existing CORSAIR RGB fans and lighting strips, to create your perfect custom RGB cooling setup. The customization doesn't stop at color; every LL Series fan has PWM fan control, allowing for dynamic speed adjustment between 600 RPM to 1,500 RPM on LL120 RGB fans and 600 RPM to 1,300 RPM on the larger LL140 RGB. Whether you need maximum cooling or stealthy operation, with PWM control, you can instantly switch from low-noise to peak airflow.
Availability, Warranty and Pricing:
CORSAIR LL Series RGB fans are available immediately from the CORSAIR network of authorized retailers and distributors. CORSAIR LL Series RGB fans are backed by a two-year warranty and the CORSAIR worldwide customer support network.
