Corsair Launches High-Performance Carbide 400Q and 400C PC Cases at CES 2016
47,499 (7.49/day)
Corsair, a world leader in enthusiast PC hardware and components, today announced the new Corsair Carbide 400Q and Carbide 400C high-performance PC cases. The Carbide 400Q and Carbide 400C are engineered to pack performance and expandability into beautifully compact mid-tower case designs. The 400C puts your PC's components on display through a stunning full size windowed side panel, while the 400Q features an interior lined with sound-damping material to minimize noise. In both the 400Q and 400C, Direct Airflow technology ensures unimpeded flow of cool air to your PC's hottest components.
The Carbide Quiet 400Q and Carbide Clear 400C are both easy to build in, easy to clean, and liquid cooling capable. Tool-free drive installation, easy-access side-panels and tons of cable routing options mean PC enthusiasts can spend less time building a PC and more time using it. Dust filters are easily accessible to cut cleaning time down to a minimum and two modular and refined PSU and 3.5" bay covers make it easy to conceal cables and drives. The 400Q and 400C both feature room for up to a 360mm radiator in front, a 240mm radiator on top, and a 120mm radiator in the rear, and Direct Airflow technology directs air to the hottest components from two included Corsair AF series fans (1 x AF140L intake, 1 x AF120L exhaust). Despite their compact mid-tower dimensions, the 400Q and 400C can house a full ATX motherboard and multiple GPUs if expansion is desired, making them as capable as they are beautiful.
With its multi-layer, sound-damping panels and streamlined interior, the Carbide 400Q is a compact and quiet ATX case. Sound-damping material placed on the front panel, side panels and top panel quietens even the noisiest internal components.
Carbide Clear 400C
The Carbide 400C packs high performance into a clear and compact case design. A gorgeous full size side panel window provides an unobstructed view into the case that's ideal to show off your PC's components. The all-steel exterior front and top panels complement the design with clean, modern lines.
Available in early February 2016 for $99.99 MSRP from Corsair's worldwide network of retailers and distributors, the Carbide 400Q and Carbide 400C are backed by a comprehensive two-year warranty and Corsair's worldwide customer support network.
Carbide 400C and Carbide 400Q
  • Clean, modern lines with an all-steel exterior: Get rid of those plastic cases - the 400C and 400Q have full steel front and top panels for extra durability and stunning looks.
  • Compact design, full size capabilities: Despite the 400C and 400Q's compact dimensions, they can house a full ATX motherboard and multiple GPUs.
  • Direct Airflow Path: One way to reduce noise is to make sure fans don't work harder than they have to. By removing the drive cages behind the intake fans, the 400C and 400Q provide a more efficient direct airflow path to the hottest components, the CPU and GPU.
  • Liquid cooling capable: With room for up to a 360mm radiator in front, a 240mm radiator on top, and a 120mm radiator in rear, the 400C and 400Q can mount a wide range of Corsair Hydro-series liquid coolers.
  • Two AF series fans: Corsair-exclusive AF120L and AF140L fans efficiently draw ample cool air directly to components without the turbulence that can cause fan hum.
  • Easy to Build: Tool-free drive installation, side panel access, and tons of cable routing options and tie downs means less time spent building a PC and more time using it.
  • PSU and 3.5" Bay Cover: It's easy to tidy the inside of the case by placing cables and drives behind two modular, clean, and refined PSU and 3.5" bay covers.
  • Easy to Clean: Easily access dust filters on front, top, and bottom mean it'll never take more than a minute getting dust out of the system.
Carbide 400Q Only
  • Silenced panels for quiet operation: Sound damping material placed on the front panel, side panels, and top panel reduces component noise.
Carbide 400C Only
  • Hinged and latched full side-panel window: Components are easily accessible and when closed, every part of the build is visible through the full side-panel window.
4,267 (0.67/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Nice, I like that edge to edge window on the Carbide Clear. After seeing the In-Win 901 and other beautiful full/large window cases I'm going 'big and bold' or no window at all.
peche
Thermaltake fanboy
6,709 (1.79/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
looks clear and also a little tight ...but i like the window one.... the other looks like a safe box.... :confused:
857 (0.18/day)
Oregon
System Name Red 101
Processor 9th Gen Intel Core i9-9900k
Motherboard EVGA Z370 Classified
Cooling Custom Primochill and Heatkiller water cooling loop
Memory 16GB of Gskill 3200Mhz CL14
Video Card(s) EVGA GeForce GTX 1080 FTW2 with Heatkiller block @2114Mhz
Storage 4- Samsung Evo 250GB, 1- Pro 512GB and 1-512GB M.2
Display(s) LG 38" UW
Case In Win 101 customized a lot and painted red
Audio Device(s) Razer Kraken 7.1 Chroma
Power Supply EVGA 850w G2
Mouse Razer DeathAdderv2
Keyboard Razer Ornata Chroma
Software Win10Pro and games
Benchmark Scores NA
That windows is almost nice... then the HANDLE takes burns my eyes a little! why the handle???
clean case otherwise
1,006 (0.18/day)
Michigan
System Name Daves
Processor AMD Ryzen 3900x
Case Phanteks P600S
Audio Device(s) N/A
Power Supply Corsair RM 750
Mouse EVGA
Keyboard Corsair Strafe
I like it, my next case!
7,607 (1.46/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Uhh... the plastic behind the case looks ugly and poor quality. (I guess the SSD Tray)
peche
Thermaltake fanboy
6,709 (1.79/day)
System Name Athenna
clone of Nzxt Source.
well.... footstands and window are pretty different, also vents on front sides.... but its almost same scheme ...
6,105 (0.84/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
What does it matter? Nobody's ever gonna see that part.
475 (0.10/day)
Processor i5-13500
Motherboard MSI MAG B760 Tomahawk WiFi DDR4
Cooling Thermalright Peerless Assassin 120 White
Memory Corsair Vengeance LPX 4x8GB 3200
Video Card(s) EVGA RTX3060 12GB
Storage 250GB NVME (main) 1TB SSD (Game) 1TB HDD (Storage) 2TB HDD (ext Backup)
Display(s) Benq 27" GW2765 + Asus 27" VE278 + 55" Hisense
Case Cougar MX600 White
Audio Device(s) Audiotrack Prodigy Cube DAC + Edifer S330D + Plantronics RIG 400
Power Supply Corsair AX760
Mouse Logitech G403 Hero
Keyboard EVGA Z15 Brown Tactile (Blue Oring, Lube, Silence Pad)
So much for design at Corsair. I do not know why they do the things they do?
PSU cover hole is in wrong spot.
If you move the HDD cage over, you will part of the cage, as the cover can not slide over.
The SSD mounting is too thick and can not be made to use 1 or 2. Have to mod it.
The front panel, you have to take both side panels off to remove it.
Compared to the S340 which is easier. The price Corsair wants, you can get the better built and design of the Fractal Define S for the same price.
Think Corsair has lost it's edge and time to replace Corsair George from the lead design team.
2,722 (0.57/day)
East Europe
System Name PLAHI
Processor I5-10400
Cooling 120 AIO IWONGOU
Video Card(s) PNY QUADRO RTX A2000
Storage Intel 670P 512GB
Case Silverstone Raven 03 (RV03)
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Looks like a work horse to me from functional perspective and a tool shed from visual one. Large stable feet. Large comfortable handle, huge ventilation gaps. It will do the job you picked it up for. It speaks business to me. If I need some serious hardware, this thing will do the job. Not so much if I want elegant - at least not to my definition of elegant ( FT02B and InWin S-frame for reference here ;) )
517 (0.09/day)
You are here.
System Name Prometheus
Processor Intel i7 14700K
Motherboard ASUS ROG STRIX B760-I
Cooling Noctua NH-D12L
Memory Corsair 32GB DDR5-7200
Video Card(s) MSI RTX 4070Ti Ventus 3X OC 12GB
Storage WD Black SN850 1TB
Display(s) DELL U4320Q 4K
Case SSUPD Meshroom D Fossil Gray
Power Supply Corsair SF750 Platinum SFX
Mouse Razer Orochi V2
Keyboard Nuphy Air75 V2 White
Software Windows 11 Pro x64
The "big" manufacturers seem to be out of ideas, they are now releasing copies... If you want a nice case, may I suggest the Jonsbo UMX4, it even has a windowed version that shows the way a window should be incorporated in a case.
101 (0.03/day)
Processor i5-4670k
Motherboard MSI Z87-GD65
Cooling Magicool G2 Slim 240+360, Watercool Heatkiller 3.0, Alphacool GPX 290 M05
Memory G.Skill RipjawsX DDR3 2x4GB 2133MHz CL9
Video Card(s) Gigabyte Radeon R9 290
Storage Samsung 850 EVO 250GB, 320GB+1TB HDDs
Case SilentiumPC Aquarius X90 Pure Black
Power Supply Chieftec Navitas GPM-1000C
To be honest looks like worse version of Define S.
34 (0.01/day)
I prefer Corsair's version. The Define S has those decorations at it's squares where dust can accumulate and it's a pain to clean up, where Corsair's is completely flat. No dust, no problem.
FRAGaLOT
11 (0.00/day)
How exactly is a PC case "high performance" it literally doesn't "DO" anything but house your components. Yes some cases are BETTER than others, and have better air flow, or have more room for custom water cooling, or have some nice feature a user might be looking for their needs, but a case isn't classified by it's "performance" but by it's functionality. This is just stupid marketing terminology, next these marketing jerks will claim "...the next generation of overclocked cases!" <face palm>
9,916 (1.82/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
i like the frame, looks pretty solid but the plastic tray? just no for that
