CORSAIR Launches New Hydro Series H100i and H115i RGB PLATINUM Liquid CPU Coolers
VSG
Editor, Reviews & News
3,704 (0.96/day)
CORSAIR, a world leader in PC gaming peripherals and enthusiast components, today launched the latest in its line of best-selling Hydro Series all-in-one liquid CPU coolers, the CORSAIR Hydro Series H100i RGB PLATINUM and CORSAIR Hydro Series H115i RGB PLATINUM. The new pair of coolers take the Hydro Series to new heights in both cooling performance and dazzling RGB lighting across both the fans and pump head.
Each of the new entries in the acclaimed Hydro Series range is cooled by a pair of CORSAIR ML PRO Series RGB magnetic levitation PWM fans, delivering the superb airflow and high static pressure needed to cool today's hottest CPUs. Thanks to the ultra-low friction of their magnetic bearings, they also generate less noise than traditional bearing fans even when spinning at higher RPMs. The H100i RGB PLATINUM comes equipped with two 120mm fans and a 240mm radiator, while the H115i RGB PLATINUM is cooled by two 140mm fans and a 280mm radiator.
As the first Hydro Series coolers to feature customizable RGB lighting on both the fans and the pump head, the H100i and H115i RGB PLATINUM take lighting to a brilliant new level with a whirlwind of color. 16 Individually addressable LEDs in the pump head and four in each fan combine for a total 24 RGB LEDs, heightening your system's style while lowering its temperatures.
The Hydro Series PLATINUM coolers achieve their extraordinary performance thanks to a thermally optimized copper cold plate and precise PWM control over the fans. The H100i RGB PLATINUM can be set between 400 and 2,400 RPM, while the H115i RGB PLATINUM ranges between 400 and 2,000 RPM. In addition, the low-noise pump design, combined with Zero RPM cooling profiles that can stop the fans entirely at low temperatures, results in exceptionally quiet coolers that efficiently channel heat out of the CPU to the radiator without an excess of distracting noise.
CORSAIR iCUE software brings everything together in a single, easy-to-use interface for powerful control over all of the H100i and H115i RGB PLATINUM's functions. iCUE allows users to directly control pump and fan speeds, creating custom cooling curves that automatically adjust based on a range of monitored system temperatures. iCUE also enables full customization of the Hydro Series RGB PLATINUM range's 24 RGB LEDs, allowing you to dynamically change your RGB lighting based on your CPU temperature, or create brilliant lighting patterns and effects, synchronized across all of your CORSAIR iCUE-compatible components and peripherals.
With extreme cooling performance, detailed customization, and killer looks to match, the CORSAIR Hydro Series H100i RGB PLATINUM and CORSAIR Hydro Series H115i RGB PLATINUM set a new standard for all-in-one liquid CPU cooling.
Availability, Warranty and Pricing
The CORSAIR Hydro Series H100i RGB PLATINUM and CORSAIR Hydro Series H115i RGB PLATINUM are available immediately from the CORSAIR worldwide network of authorized retailers and distributors, as well as direct from the CORSAIR webstore. The H100i RGB PLATINUM and H115i RGB PLATINUM are backed by a five-year warranty and the CORSAIR worldwide customer service and technical support network.
To learn more about the CORSAIR Hydro Series H100i RGB PLATINUM and CORSAIR Hydro Series H115i RGB PLATINUM, please visit: http://www.corsair.com/hydro-platinum-liquid-coolers
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
Damn it I just bought their 115i RGB Pro! Ehhh now I want this.
866 (0.19/day)
NL
System Name SIGSEGV
Processor AMD Ryzen 9 9950X
Motherboard MSI MEG ACE X670E
Cooling Noctua NF-A14 IndustrialPPC Fan 3000RPM | Arctic P14 MAX
Memory Fury Beast 64 Gb CL30
Video Card(s) TUF 4090 OC
Storage 1TB 7200/256 SSD PCIE | ~ TB | 970 Evo | WD Black SN850X 2TB
Display(s) 27" /34"
Case O11 EVO XL
Audio Device(s) Realtek
Power Supply FSP Hydro TI 1000
Mouse g402
Keyboard Leopold|Ducky
Software LinuxMint
Benchmark Scores i dont care about scores
LOL. RGB over everything...
Crazy..
I prefer NON RGB fan but offering similar quality build as Gentle Typhoon industrial fans.
89 (0.02/day)
That impeller looks way too robust to be an Asetek design. Is Corsair going back to CoolIT?
887 (0.22/day)
somewhere
I have an H110i on my R5 2600, does the job and I won't be looking to replace it with something else unless it kicks the bucket and is out of warranty. I still have another ~3 years left on its warranty. I did look at getting one of the RGB ones because I had a brief fling with the idea of making over my PC with RGB but... I got some of their expensive fans instead ._.
Also I think these new ones should have fully copper radiator fins instead of Aluminium. That would set them apart from other ones IMO.
2,186 (0.50/day)
Deez Nutz, bozo!
still using the old cheap H55 AIO. Probably considering this.
FreedomEclipse
~Technological Technocrat~
24,265 (3.75/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Some of us have already seen TPUs review of the product :p
Deleted member 158293
I still see a lot of black plastic...
Needs more RGB! o_O
Corsair you can do this!
352 (0.10/day)
Southampton UK
System Name zx spectrum
Processor i7-4960x
Motherboard Asus Rampage IV Extreme
Cooling Corsair H100i
Memory 32Gb Kingston Hyper Beast Quad-DDR3 2400Mhz
Video Card(s) Saphire Tri-x R9 290 4GB
Storage 240Gb Kingston Hyper X SSD
Display(s) Samsung UE55NU8000 55'' Freesync
Case Cooler Master Cosmos II Ultra Tower
Audio Device(s) On Board 7.1
Power Supply Corsair Ax1200i
Mouse Razer Death Adder 2013
Keyboard Razer Death Stalker Ultimate
Software Win 10
2019 the year RGB dies. Enuff of christmas every day STOP!!!!!!!!!!
8,263 (1.31/day)
Mouse Logitech G604s
9,781 (2.19/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
FreedomEclipse
24,265 (3.75/day)
London,UK
3,032 (0.83/day)
I want that...oh wait already have a great air cooler:p
While AIO maybe is a good mix for those that want easy access to water cooling. I will have to say that i will either go for a big air cooler or a custom loop.
8,263 (1.31/day)
AIO's give the option so you dont have to constantly clean a custom loop.
3,302 (1.02/day)
Buenos Aires
System Name Ryzen Monster
Processor Ryzen 7 5700X3D
Software Windows 11 Start 11
This looks like a great replacement for my H100i, which is now over five years old.
Seen it on Scan UK for about £109.
FreedomEclipse
24,265 (3.75/day)
London,UK
I think it would be very very overkill for your 2600X. you could probably save yourself a lot of money and order a 'cpu arctic freezer 33 esports ' - I had one cooling a R5 2600 at stock and that thing barely even got warm even after 2hrs of stress testing in Asus RealBench.
Myself personally, Im thinking of going with a Cryorig or Noctua when i replace my H105 later this year. I think its done at least 4 or 5 years service.
