- Oct 9, 2007
- 46,755 (7.65/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
CORSAIR, a world leader in enthusiast components for gamers, creators, and PC builders, today expanded its CORSAIR XENEON family of gaming monitors with two new additions: the CORSAIR XENEON 32UHD144 and XENEON 32QHD240. Whether you opt for stunning UHD 4K resolution gaming or QHD at an incredibly smooth 240 Hz refresh rate, both monitors deliver the beautiful design, brilliant display, and innovative technologies synonymous with the XENEON name.
Now gamers and creators alike can experience gorgeous 4K visuals on the XENEON 32UHD144's ultra-slim, 32-inch 3840x2160 IPS LED display, perfectly complementing the monitor's vivid colors and realism made possible by Quantum Dot technology with 100% sRGB and 100% Adobe RGB color space. Now with HDR600, the XENEON 32UHD144 is capable of a wide brightness range and color gamut, for greater detail in the darkest and brightest scenes. Equipped with two HDMI 2.1 ports, DisplayPort 1.4, USB Type-C, and an integrated USB 3.1 hub to expand your connectivity, the XENEON 32UHD144 helps keep your connections tidy with RapidRoute cable management built into its stylish die-cast aluminium stand.
If getting the smoothest image with a high refresh rate is your top priority, the XENEON 32QHD240 is just what you're looking for. Its 32-inch 2560x1440 IPS LED panel delivers a terrific image, while its 240 Hz refresh rate with 1 ms response time handily keeps up with the impressively high frame rates that modern graphics cards are capable of outputting. The XENEON 32QHD240 also features Quantum Dot technology and the extensive brightness range of HDR600, and connects using USB Type-C, 2x HDMI 2.0, or DisplayPort 1.4.
Both new XENEON monitors are AMD FreeSync Premium certified and NVIDIA G-SYNC compatible, ensuring synchronized visuals with your graphics card for smooth images, less screen tearing, and low input latency. Lastly, enjoy your monitor worry-free thanks to CORSAIR's Zero Dead Pixel guarantee and the XENEON's three-year warranty.
For more information, visit the product pages of the XENEON 32UHD144 and the XENEON 32UHD240.
