Corsair Releases the Carbide SPEC-ALPHA Mid-Tower ATX Case
4,784 (1.02/day)
Still on the East Side
Corsair, a world leader in enthusiast PC hardware and components, today announced the immediate availability of the Corsair Carbide Series SPEC-ALPHA mid-tower gaming case. With a large side panel window and bold angular styling, the SPEC-ALPHA offers sharp looks in black/grey, red/white or the previously un-announced black/red to complement its efficient cooling. Packed with features to make your next gaming PC build better, the SPEC-ALPHA boasts three 120 mm fans for Direct Airflow Path cooling, a three-speed fan control and the ability to house a variety of high-end PC hardware.
With its modern, angular appearance, the SPEC-ALPHA really stands out in a crowd. There's plenty of modern features inside too, with native USB 3.0 support, room for up to four SSDs, and a three-speed fan controller for the three included 120 mm fans, allowing users to set their own cooling sweet spot. A large window shows off your internal components and the Direct Airflow Path layout, which provides superior cooling by getting rid of unnecessary drive bays. SPEC-ALPHA is also able to accommodate a front mounted 240 mm radiator compatible, allowing for additional liquid-cooling upgrades.
Available in three distinct color options - black and red, black and grey and white and red, SPEC-ALPHA offers sophisticated angled styling whichever version you choose.
Originally announced at CES 2016, the Carbide Series SPEC-ALPHA is now available with an MSRP of $79.99 from Corsair's worldwide network of retailers and distributors and is backed by a comprehensive two-year warranty and Corsair's worldwide customer support network.
Specifications
  • Bold Exterior Design with LED fans: You'll never mistake it for anything else - the asymmetrical, hard-edged design of the SPEC-ALPHA and its numerous color combinations give it a bold, unique look, and the front LED fans can be viewed through the front air intakes for a glimpse of the performance within.
  • Direct airflow path to keep your CPU and GPU running cooler: Modern systems don't need tons of drive cages in the airflow path. By removing the 5.25" drive cage, the SPEC-ALPHA has a direct path from the front intake to the two hottest components - your CPU and GPU, which can result in better, more efficient cooling.
  • Large side panel window to show off your hardware: Why hide it? All that performance hardware you built your rig with is looks great, so why not take a look at it through the huge side panel window?
  • Three included 120mm fans and built-in three-speed fan controller: Two front LED fans and a rear fan provide excellent airflow, and the built-in fan controller lets you decide exactly how much cooling you need with the flick of a switch.
  • Cable routing cutouts and tie downs: Nobody wants to see a rat's nest of cables, so the SPEC-ALPHA has cutouts and tie-downs behind the motherboard tray to keep your cable routing neat and tidy - and out of the airflow path for better cooling.
  • Easy to Build: Tool-free drive installation and side panel removal mean you can spend less time building your PC and more time gaming with it.
  • Front 240 mm radiator compatibility: Upgrade to the power of liquid cooling for your CPU or GPU with up to a 240 mm hydro series cooler in front of the case.
  • Native USB 3.0 and SSD support for modern builds: Whether it be a new external drive for storage or a new SSD for your OS or games, rest assured the SPEC-ALPHA is ready for anything you throw at it.
For more information on the Carbide Series SPEC-ALPHA visit:
www.corsair.com/specalpha
520 (0.12/day)
System Name CUBE_NXT
Processor i9 12900K @ 5.0Ghz all P-cores with E-cores enabled
Cooling EK AIO Elite Cooler w/ 3 Phanteks T30 fans
Memory 64GB DDR5 @ 5600Mhz
Video Card(s) EVGA 3090Ti Ultra Hybrid Gaming w/ 3 Phanteks T30 fans
Storage 1 x SK Hynix P41 Platinum 1TB, 1 x 2TB, 1 x WD_BLACK SN850 2TB, 1 x WD_RED SN700 4TB
Display(s) Alienware AW3418DW
Case Lian-Li O11 Dynamic Evo w/ 3 Phanteks T30 fans
Power Supply Seasonic PRIME 1000W Titanium
That has to be the ugliest case that Corsair has ever made.
42 (0.01/day)
System Name TBD
Processor Core i7-4790K @Stock
Motherboard Asrock Z97-Pro4
Cooling Hyper 212 Evo
Memory G Skill Ares 3 8 GB (2x4GB)
Video Card(s) MSi RX480 8 GB Gaming X
Storage Samsung 850 250 Gb SSD, WB Blue 2TB, WD Blue 1TB
Display(s) Benq E2440 1080p
Case NZXT S340
Power Supply Antec 500W
Software Windows 7 SP1 64 Bit
9,781 (2.25/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Holy shit!! You are not kidding.what in the world were they thinking?!
"Okay boys...NOW lets develope a case that is never going to sell"
It looks like one of those giant korean robots from the cartoons took a dump:)
6,750 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Just throw your gear in there and use your pc.
When you worry about how shit looks you lost the idea.
MxPhenom 216
ASIC Engineer
12,991 (2.53/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
Keyboard Razer Huntsman Tournament Edition
Holy shit Corsair has gone full retard. That thing is ugly as sin.
3,059 (0.44/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
Not only is it ugly as hell but it has a HDD cage in front off the expansion slot area on the motherboard to block all those extra long GPU's.
13,850 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Maybe it would look better once you pull all that moulded plastic shit of the outside? o_O
2,074 (0.47/day)
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
Any respect I once had for Corsair is now gone. I'm ashamed that my 750D shares the same logo as this monstrosity.
76 (0.02/day)
System Name notta/uhmm no
Processor AMD FX-8350 / I7-6700k
Motherboard Asus Sabertooth 990FX R2.0/ Maximus VIII Gene
Cooling Akasa Venom Voodoo / Corsair H60
Memory Crucial Ballistix 8GB 1866 / generic ddr4-2133 16GB
Video Card(s) Evga gtx 660 TI FTW
Storage sdd m500 2x480Gb / HyperX® Predator m2 240
Display(s) dell 23 1080p
Case Corsair 400R / mastercase5
Power Supply Evga 750b cx750m
Mouse G400
Keyboard roccat
And its MSRP of $79.99 worth of ugly.
Frick
Fishfaced Nincompoop
19,239 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
This is only true if you're a peasant with poor eyesight.
1,226 (0.25/day)
Omaha, NE
System Name Graphics Card Free...
Processor Ryzen 5 5600G
Motherboard MSI B450 Gaming Plus MAX Wifi
Cooling Cryorig M9a w/ BeQuiet! PureWings 2 ~ 92mm
Memory Corsair Dominator Platinum DDR4 3200 ~ 16GB(2x8GB)
Storage Samsung EVO 870 SSD - 1TB
Display(s) AOC 24G2
Case Cardboard...
Power Supply eVGA SuperNova 550w G3
Mouse Logitech t400 Zone Touch Mouse
Keyboard IBM Model "M" Keyboard
Software Manjaro ~ KDE Plasma
Benchmark Scores She's a Runner!
Corsair has redefined the definition of something here...I'm just not sure what that something is.
I've seen the word "ugly" thrown around this thread several times and frankly, I don't think that's quite cutting it in this situation, but I'm no wordsmith.
The first thought that came to my mind after viewing the pictures of this case is that I walked away feeling insulted that Corsair would believe that I'd be interested in purchasing this item?
If you can define that for me...I'd consider it a proper description.
Even a poor blind man has fingers...I'd suggest wearing gloves just in case jboyd's description happens to be true.
Best,
Liquid Cool
12,307 (2.30/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
Don't be so tough on them. 12 year olds need cases too
4,354 (0.88/day)
Corsair is going down the same route as that of Thermaltake. Similar ugly looks and cheap plastics, thin metal and lots of flex.
1,992 (0.34/day)
Processor Intel Core i9 9900k @ 5.1GHZ all core load (8c 16t)
Motherboard MSI MEG Z390 ACE
Cooling Corsair H100i v2 240mm
Memory 32GB Corsair 3200mhz C16 (2x16GB)
Video Card(s) Powercolor RX 6900 XT Red Devil Ultimate (XTXH) @ 2.6ghz core, 2.1ghz mem
Storage 256GB WD Black NVME drive, 4TB across various SSDs/NVMEs, 4TB HDD
Display(s) Asus 32" PG32QUX (4k 144hz mini-LED backlit IPS with freesync & gsync & 1400 nit HDR)
Case Corsair 760T
Power Supply Corsair HX850i
Mouse Logitech G502 Lightspeed on powerplay mousemat
Keyboard Logitech G910
VR HMD Wireless Vive Pro & Valve knuckles
Looks like a modified version of the 760t base chassis. Not my cup of tea, but for people who like the look of alienware desktop cases and other similar cases this is an option for them if they want to build their own and have a decent chassis to be working with.
HDD cage is level with the PSU - as the case id basically a 760t without the rubber gromits on the inside and with a different cladding on the outside I can confirm that it'll take full size GPUs without issues (my 980ti fits in the space with room to spare).
658 (0.09/day)
Everyone saying it's ugly, it looks good in person. I saw it at CES, and it does look nice in person.
44 (0.01/day)
System Name Dricast
Processor Intel Core i7 2600k
Motherboard Gigabyte GA-Z77X-UD3H
Cooling Corsair A70
Memory 12GB Mushkin DDR3
Video Card(s) 2x EVGA Geforce GTX460@GTX560 Clocks in SLI
Storage SanDisk 120GB SSD, Hitatchi 1TB, Hitatchi 2TB
Display(s) Dell 24"
Case Antec 902
Power Supply Corsair 750TX
Software Windows 7 Ultimate
I like the design of this case. I may pick it up. Looks like a budget version of the NZXT Noctis 450.
468 (0.10/day)
Processor i5-13500
Motherboard MSI MAG B760 Tomahawk WiFi DDR4
Cooling Thermalright Peerless Assassin 120 White
Memory Corsair Vengeance LPX 4x8GB 3200
Video Card(s) EVGA RTX3060 12GB
Storage 250GB NVME (main) 1TB SSD (Game) 1TB HDD (Storage) 2TB HDD (ext Backup)
Display(s) Benq 27" GW2765 + Asus 27" VE278 + 55" Hisense
Case Cougar MX600 White
Audio Device(s) Audiotrack Prodigy Cube DAC + Edifer S330D + Plantronics RIG 400
Power Supply Corsair AX760
Mouse Logitech G403 Hero
Keyboard EVGA Z15 Brown Tactile (Blue Oring, Lube, Silence Pad)
Why for the price you can get the NZXT S340, which is a better case that supports 2x140mm fans in front or 280rad, instead of 120mm/240 rad. Plus a much nicer cleaner look.
Also in the price range is the Fractal Define S or the Phanteks P400. Both of these are by far superior in terms of cooling and functionality.
Sorry I would not be caught dead with this case. Corsair George has really slipped in design. Why do Corsair even bother to make cases if they can't bother to make good ones.
Top 3 most sold cases last year was NZXT, Phanteks and Fractal. Shows that they know what they are doing. Corsair never came close to the top 5.
427 (0.08/day)
Iraq
System Name Simon
Processor Core i7 5820K @ 4.4GHz @1.25v core, 1.9v input, 1.12v system agent, 0.9v cache - 24/7 & P95 stable
Motherboard ASUS X99 Deluxe U3.1, BIOS 3101
Cooling Corsair H110i GTX + 2 x Corsair ML140 Pro Red LED, exhaust @ top panel
Memory Corsair Vengeance LPX 4x 8GB 2666 MHz 16, 18, 18, 35, 2T (Stock)
Video Card(s) MSI GTX 1080 Gaming X (OC BIOS), +60 MHz GPU, +450 MHz Memory
Storage Samsung 960 Evo 500 Gb, WD Green + White Label, total 17 TB
Display(s) 3x Samsung CFG73 (24" 1920x1080, 144Hz) in 2D Surround, LG C7 OLED TV (55", 4K, 60Hz)
Case Corsair 760T + Corsair SP120 Perf.Ed. + 3x ML 140 Pro Red + DEMCI Dust Filter Kit + DeepCool RGB LED
Audio Device(s) Creative SB Z, Topping E30 + SMSL SP200, Hifiman 4XX, beyerdynamic 770 250Ω, Audeze iSine 10, HD6xx
Power Supply Corsair RM1000i + APC BackUPS RS1500 (modded w/ 130 AH Kung Long Batteries) + APC Smart UPS SUA1500i
Mouse Razer Naga Chroma + Reflex Lab Extended Mouse Pad + Xbox One S Controller + 3 x Xbox 360 Controllers
Keyboard Corsiar K70 RGB (2016 Edition) Cherry Mx Red w/ custom Arabic-legend shine-through keycaps
Software Windows 10 Pro x64 - ver. 20H2
Benchmark Scores Onkyo TX-NR626 AV Receiver, speakers: 4x Yamaha NS-M325 + Yamaha NS-C3290 + Proson Libre Sub 8.1
Was, by any chance; the person who designed this case the same one who designed their Corsair Gaming logo?
418 (0.09/day)
Processor Intel i7 10700K
Motherboard Gigabyte Z490 Aorus Pro AX
Cooling Be Quiet Dark Rock Pro 4
Memory DDR4 Corsair Vengeance LPX 3200MHZ (2X16GB)
Video Card(s) Palit GTX1080ti Super JetStream 11GB
Storage Trandscend 370s 256GB / WD Caviar Black 2+1TB
Display(s) Acer XB270HU 144hz Gsync
Case Phanteks Eclipse P600S White
Audio Device(s) Sound Blaster ZXR
Power Supply Corsair RM1000X 1000W 80 Plus Gold
Another case with useless space where 5.2" drives used to be.
468 (0.10/day)
Processor i5-13500
Care to explain why having no optical bay is useless? There is much more benefits to have it removed.
CorsairBlake
Corsair Rep
14 (0.00/day)
Fremont, CA
It's actually not a 760T chassy. It's based on the 230T and SPEC-01 to SPEC-03 chassy. This is why it has the SPEC designation.
