- Aug 10, 2019
- 23 (0.01/day)
System Name | RaptorLake |
Processor | Intel Core i5-13600K |
Motherboard | Gigabyte Z690M AORUS ELITE AX DDR4 |
Cooling | Noctua NH-D15 |
Memory | Corsair Vengeance LPX CMK32GX4M2D3600C16 |
Video Card(s) | Powercolor Hellhound RX 7800 Xt |
Storage | Samsung 980 Pro 2TB + Samsung 980 Pro 1TB |
Display(s) | Lenovo ThinkVision P40w-20 |
Case | Lian Li O11 Air Mini Black |
Audio Device(s) | Audioengine D3 USB DAC + Audioengine A5+ Black |
Power Supply | Fractal Design Ion+ 2 Platinum 560W |
Mouse | Logitech MX Master 3S |
Keyboard | Logitech Cordless Desktop Wave Pro |
I've recently done a new build based on a Ryzen 5 3600. I haven't done any overclocking since the early 2000's, but as Zen CPU's pretty effectively OC themselves and can benefit from quick memory, I'm curious what I can get out of my RAM. Just for fun, btw, nothing too extravagant. I want to keep the system rock solid.
I paired the Ryzen 5 3600 with an Asus Prime X470-Pro, and spent slightly more on the RAM compared to an ordinary 3200MHz CL16 set: I went for a Corsair Vengeance LPX kit at 3600MHz CL18-22-22-42.
After reading up on RAM OC'ing a bit, I found the DRAM Calculator for Ryzen on TPU. Helpful tool, definitely! To figure out which chips are on the DIMMs, I used Thaiphoon Burned. It tells me it has Micron E dies.
This is what the calc suggests as safe settings:
I started extremely conservative, and after a few iterations I currently have CL16, tRCDrd 19, tRCDwr 16, tRP 16, tRAS 36. Still at 1.35V btw.
I tried getting tRCDrd under 19, but I can't get the system completely stable, even after cranking up the voltage to 1.4V which the calc suggests as max.
The more secondary timings I pretty much left as is, for now. I had a little experiment with Trdwr, tFAW and ProcODT, but that miserably fails. I reverted them back to auto.
I'm looking for a little guidance here, how to progress...
What's the deal with the tRCDrd? How could I get it from 19 to the suggested 17. A higher voltage? Or do the other mentioned voltages in the calc play a role?
Secondly, how do I best test stability? I now use the MEMbench that comes with the calc as a quick 5min check. If there aren't any popups running the test, I do a +30min Prime95 run. No errors there I consider the settings stable.
How do I test whether a change actually improves performance, and with how much? Till now, I looked at the time MEMbench needs to run. I'm now at 300.14 sec. A little experiment moving from 3600 to 3733MHz actually resulted in a 1.5% perf loss: 304.66s. So is this a good tool to make an evaluation, or is there better out there?
