Hey guys , So I decided to give RBE a spin after all of the problems I've had with Punkbuster and any of the software OC tools out there.
Stats :
CPU: 965 BE @ 3.8
Vid: Sapphire HD 5850 Reference
Mem: 4GB
Here are a few of the things I was wondering :
In the last page of
http://www.techpowerup.com/forums/showthread.php?t=113949&page=6
So to confirm , I only change the clocks and set 1.15v in the register as 0x17 correct ?
I didn't see any memory voltage options in RBE ( I'm using the latest ) Should I be ?
If my current memory maxes out at 1150mhz . Would a 5870 Bios flash allow it to hit 1200 and beyond due to memory voltage differences or is flashing to a 5870 a bad idea due to the fact that my memory doesn't seem to be able to handle that speed ?
Thank you for any help and for this awesome tool.
Stats :
CPU: 965 BE @ 3.8
Mem: 4GB
In the last page of
Default Clocks
Clock 00: 725/1000 @ 1.088v
Clock 01: 157/300 @ 0.95v
Clock 02: 550/900 @ 1.038v
Clock 03: 400/900 @1.0v
Clock 04: 400/1000 @ 1.0v
Clock 05: 550/1000 @ 1.038v
Clock 06: 157/300 @ 0.95v
Default GPU Voltage Registers
0x15: 1.0v
0x16: 1.0375v
0x17: 1.0875v
0x18: 0.95v
Just to confirm, I should not change the voltage setting under "Clock 00" - leave that alone... or do I change that too?
Leave it alone. Its just a lable to display the the highest voltage state. If you change it, you can get some powerplay troubles.
