CPU Block Suggestion - Modultra LOBO CPU water block/heatsink or EK-Quantum Velocity² D-RGB - 1700 Full Nickel w/EK-Quantum Velocity² Direct Die-1700
595 (0.72/day)
Right now, I am looking at the following two blocks. I will use the Intel 14900K CPU. I will have the CPU overclocked. I have done my research, and right now my first choice is the EK Full Nickle Block with the Direct Die. From my research, I have seen some nice reviews on the Modultra water block/heatsink combination. I do understand the Modultra is a block, and pump all in one, and the EK is a block only.
Modulta stays "Pump Cooling: The LOBO in conjunction with a Modultra heatsink has been shown during testing to decrease DDC pump temperatures by more than 45 degrees C. This is a function of the LOBO’s solid brass body and heatsink conduction paths into the body. Because the body is solid brass, and the pump is sandwiched between the body and the aluminum heat sink, heat flows from the pump into the loop coolant. This means that your DDC pump will live a much longer life due to decreased operational temperatures. Estimated heat load addition to the loop coolant should be between 6-10 watts, depending on your pump load. Loop temperature increase will depend on loop size and radiator configuration but is estimated at 1-2 degrees water temperature. We at Modultra think that a 1-2 degree increase in water temperature is a small price to pay for a 45 degree temperature reduction in your DDC pump."
Does anyone have any real work experience with the Modultra?
Modultra LOBO CPU water block/heatsink - https://modultra.com/shop/ols/produ...-water-block-plus-plain-heatsink/v/MPBC-W240I
EK-Quantum Velocity² D-RGB - 1700 Full Nickel w/EK-Quantum Velocity² Direct Die - 1700
422 (0.09/day)
Quodam loco Albanianae
System Name The Dark side of the room
Processor AMD Ryzen 9 5900X
Motherboard MSI MEG X570 Unify
Cooling Custom loop watercooling (Bykski CPU-XPR-POM-M-V2, Alphacool Eisblock GPX, Freezemod PU-PWM5B18W)
Memory GSkill Ripjaws V DDR4 3600 CL16 (4 x 16GB)
Video Card(s) XFX Speedster QICK 319 Radeon RX 6700 XT
Storage 1 x Kingston KC3000 1024GB (boot drive) + 2 x Kingston NV2 2TB (games & storage)
Display(s) LG 34WP65C Ultrawide 3440x1440 @ 160Hz freesync premium
Case Thermaltake Core P90 TG (slightly modded)
Audio Device(s) onboard Realtek® ALC1220 with Logitech Z906
Power Supply MSI MAG A850GF 80 Plus Gold
Mouse Generic
Keyboard Sharkoon Skiller SGK60 (with brown Kalih switches)
Software Windows 11 pro
Benchmark Scores It's a form of exhibitionism...;-), but fun in a way But showing off is triggering.............
The direct die version has the biggest potential (fastest heat transfer), but are you aware of the fact that you have to remove the IHS from your brand new CPU which means: warranty void!!!
see text below from EK:
Details​
EK-Quantum Velocity² Direct Die D-RGB - 1700 Nickel + Plexi is specifically designed for direct die cooling of the Intel® LGA 1700 socket-based CPUs of 12th and 13th generation Core architecture. It features a direct-die-exclusive cooling engine that is LGA 1700 socket-specific. It requires the removal of the IHS, the process popularly called Delidding. This CPU water block is EK-Matrix7 compliant and is mounted via a reinforced EK-Exact Mount system.
For every other model the cooling capacity is comparable to each other, as the limiting factor is the IHS and the TIM below. That's why there is a direct die model, for the die hards ;).
Also, 14th gen is not mentioned (yet) in their compatibility description.
8,862 (3.29/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
There is also a new block from Alphacool that has some impressive Specs.
334 (0.81/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
I had written this on your other thread as I didn't realize you had a separate one for the CPU block discussion:
"Heatkiller are great parts. I have a heatkiller GPU block that is performing very well. I also have one of their MO-RA rads and use their reservoirs at work.
I have an Optimus CPU block that I really like, but their GPU blocks are crazy expensive. They sometimes have "blemish" sales where a part may have a scratch or something and it gets a heavy discount. It's a risk where/what the blemish is, but it is never one that effects performance and they're often undetectable, so it can be a good deal.
I agree with Belfaborac on EKWB. They do have some good quality products, but they've been increasing prices without increasing performance for a while. They have some unique and interesting designs, but they're more about bling than performance."
I'll add to that after catching up with this thread. Delidding is made to look easy by Der8aur, Jayztwocents, etc, but I also know people that destroyed the first CPU they tried it on. It also tends to ruin any resale value of the cpu and you will need to keep an eye on the temperatures as they need re-pasting more often than unmodified CPUs, especially if you use liquid metal. So I don't personally see the benefit outweighing the cost if you're not seeking out record benchmark scores. I'm not trying to talk you out of it, but I wanted to make sure you weigh the costs before committing to it.
2,005 (1.00/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Audio Device(s) Yamaha YSP-800 DSP soundbar/Bowers and Wilkins P7 Headphones
Software Windows 10 Pro X64
Benchmark Scores Who cares
I switched from a HK IV to the alphcool Core 1, which i think is near the best performing CPU block now without delidding, which i am not doing to my 12700k.
595 (0.72/day)
As I continue my search and research, I have found that the EK-Quantum Velocity² DDC 4.2 PWM D-RGB - 1700 Nickel + Plexi is a reliable choice. However, there is one aspect of this part that I am concerned about. The reservoir is placed on top of the DCC pump and CPU block, which makes me wonder if the pump will run hotter due to this configuration, and DCC noise. On the other hand, this option allows for two less components in the ITX build (pump and reservoir).
Any real work experience?
9,340 (5.48/day)
Louisiana
Keyboard G710+x3
Region would help
Best least & expensive cpu water blocks in the US is the optimus foundation way better than ek offerings only ek block close to it is the ek magnitude.
EU
Get on facebook and hit up super cool computers
They have a very good direct die solution mount and water block.
@mrthanhnguyen has one.
595 (0.72/day)
Region would help
EU
I reached out to Optimus yesterday about other blocks. They have a version of the Singiatire V3 - CPU Block - Intel soon. When I am not sure. But it is extremely nice block. In the picutre below is the AMD version. Extreamly nice looking block, but companyies thense day, never tell you when items are coming out? All you get we are testing :)?
2,188 (1.26/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
I only know of one person who tried it and wasn't very happy with it.
595 (0.72/day)
Thank you for sharing! It seems like there are some issues with the product right out of the box. The ports on the side of the RAM are a bit unusual. I am planning to wait and see when the Optimus CPU block will be available. Hopefully, someone can provide a date soon.
I also spoke with another user who had a completely different experience with the pump. The user from the link you provided did not like the access points and found the continuous buzzing of the pump to be very annoying. In my opinion, this is a major drawback. If I were in their shoes, I would have returned the triple block by now.
9,340 (5.48/day)
Louisiana
Keyboard G710+x3
Yeah I didn't see a sigV2 Intel there just the V3 amd :confused:
SigV2 is a very good block to if you can find one very surprised optimus doesn't list it anymore.
Get on facebook about super cool computers !
595 (0.72/day)
I agree that it seems like Optimus has a limited supply of their products. It's understandable though; after all, business is business.
9,340 (5.48/day)
Louisiana
Keyboard G710+x3
Yeah if business is good it's understandable for short supply.
Foundation is still an awesome block.
