cpu cooler for a asrock z690 pg riptide + 13600kf withou ram,fan issues
1,999 (0.43/day)
Denmark
Processor i3 14100f
Motherboard Asrock z690 pg riptide
Cooling arctic freezer 36
Memory 32 gb g skille ripjaws v 3600mhz cl 16
Video Card(s) ASUS Dual GeForce RTX 4070 EVO
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case Corsair 5000D airflow tg
Audio Device(s) Yamaha R-N800A System audio signature 5
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit, Free Avira Security
I have a freezer 36 fits my asrock z690 pg riptide with 100% not ram and fan issue
But not the famous thermalright peerless assassin 120 se do to high ram and even low profile ram is not 100% optimal
Memory is ripjaws v
Rear fan is not usable do to heatsink, 1 fan is no option
I wanna set pl 1 and 2 limits + icc max to what makes my cpu run without edp other limits at 100%
When stress testing i get thermal limits when i set the limit to 90c, i wanna avoid that
I wanna have an aircooler since i hate noise from a aio pump, freezer II-III aio pump speed is not adjustable unless you disable it to find the cable to put on the pump header and fans on the fan header instead of only one cable
I have a z motherboard + a k cpu i don't want to be edp limited and thermal limited, avx is lowered so i don't run at max speed other than that my cpu is not oced but a k cpu so i can make adjustments to things limted to a no k cpu and to only having a b motherboard.
Cpu 13600kf
2,172 (0.66/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Scythe Mugen 6 (Black/White RGB Edition) would be alternative worth considering. It should have zero RAM or rear fan interference. Single 30mm fan is actually a great option.
Mugen 6 has average cooling until you start pushing watts. From that point on if your fan curve is optimized the dense fin stack can handle 14900K.
PA140 test is probably better to link in order to see how a double tower 140mm cooler compares to the single tower 120mm Mugen 6
1,999 (0.43/day)
Denmark
Processor i3 14100f
Thermalright Peerless Assassin 140 is to big i can't use the 120 version do to the front fans has to be raised even with low profile memory and the fastes i have is not low profile
Might not be that much but i don't wanna change my ram and even when the fan is only a half to 1 cm or more (with low profile ram) i want max performance
scythe coolers are hard to get (europe) it's like theres no model stock and the mugen 6
2,172 (0.66/day)
Storage 1TB 980 Pro
Software W11 Pro
Wasn't suggesting any version of already disqualified PA. Was suggesting it as a comparison to something equally off the table it appears.
In any case that test covers most of the mass market air coolers with EU availability.
1,999 (0.43/day)
Denmark
Processor i3 14100f
