Cpu Cooler Help.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi there.
I am Running an AMD FX 6300 Hexa-Core Processor 3.5GHz Socket AM3+ with the Cooler stock, I would like to upgrade that Cooler, could someone suggest me a good Cooler for that Processor?
Plus i need some suggestions about VRM Heatsinks for this Motherboard:
ASUS M5A78L-M/USB.
Are those here ok, or is there VRM for this Motherboard?
Cheers
Toothless
Tech, Games, and TPU!
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Hyper 212.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
Toothless
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
657 (0.18/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl16 - 32gb
Video Card(s) 6800xt
Storage nvme 1TB + ssd 750gb
Display(s) xg32vc
Case hyte y60
Power Supply 1000W - gold
Software 10
zalman reserator 3 max, have it before, work very quiet and keeps my cpu at low temp
6,862 (1.13/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
DeepCool Lucifer keeps my 4790k under 80c on OCCT with the 4.4ghz turbo on.
I'll +1 for the Lucifer. Had one on a 3930k OC'ed to 4.3 GHz running Bionic, temps stayed between 70-80'c. If it will handle an 4.3GHz 3930k running Bionic, a FX6300 will be no problem for it.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
What about the Cooler Master Hyper 612?
Toothless
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Okay so ignoring won't get you anywhere, just saying.
I used to have a FX-6300 and the stock cooler was perfectly fine. A Hyper 212 is enough for that chip to have a 400-800mhz overclock. The Lucifer is MORE than enough for that CPU.
There isn't really any other coolers that'll fit the bill. That CPU is cheap with no sense of putting a cooler worth more than $90 on it.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
Thanks for the quick reply, I will see which one looks better :) Btw it will be after I come back from Holiday.
And what about the VRM Heatsinks?
Toothless
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Put a small 80mm fan there blowing on the VRM heatsinks. I'll post a picture when I can of my old setup.
Stock cooler. VRM cooler, and back case fan. Temps were very good all around.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
ok, thanks a lot for the advices.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
@Toothless I have one more question,
Do you know why Core Temp is causing my my new pc reboot?
Cheers.
Toothless
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Cheers.
I never used CoreTemp on my AMD rigs. It was SpeedFan and Speccy, sometimes AIDA. The only AMD rigs that I had temp issues with was my laptop and it was either loud fan or quiet fan.
657 (0.18/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl16 - 32gb
Display(s) xg32vc
Case hyte y60
Software 10
lol and you calling that good temp?
I have fx9370 and temp with zalman never goes up than 40C
browsing web site, watching movie, temp stay 20C
playing games like wot,hon, temp going 35-40
Toothless
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Your specs say liquid cooling while the Lucifer is air cooling. Either your specs are off or you're just being rude and ignorant about liquid/air cooling differences.
657 (0.18/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl16 - 32gb
Display(s) xg32vc
Case hyte y60
Software 10
my spec talk about this moment pc m8 :)
and I talk about before my rig, i found old video, sorry for video quality but you can easy look temp and noise :)
http://videobam.com/YxfPX
rtwjunkie
PC Gaming Enthusiast
13,940 (2.36/day)
Louisiana
Processor Core i9-9900k
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
Toothless
9,537 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
You are comparing a liquid cooler to an air cooler. An AMD processor compared to an Intel processor. Your argument is invalid.
rtwjunkie
13,940 (2.36/day)
Louisiana
Yes, the copper ones in the picture. I used them on the VRM's of a Socket 775 MB that only had 3 phases, which if you remember, trying to overclock with that few phases was suicide. Result? I was able to overclock almost to the cpu limits.
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
how are fixed to the VRM?
rtwjunkie
13,940 (2.36/day)
Louisiana
They come with adhesive tape pieces.
2,084 (0.53/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
Something better? :)
Hyper 212 Evo kicks ass. If you wont oc too high (probably wont because of the high vrm temps) you dont need more than the hyper 212. I have it on a stock fx-6100 and temps never go above 54 c
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
i will get those one after my Holidays:rockout:
FireFox
The Power Of Intel
7,507 (1.93/day)
Germany
those are my Temp with the stock fan
