Cpu cooler under 155mm
97 (0.02/day)
Processor Amd FX 6100 @ 4.1ghz
Cooling CM hyper TX3 evo
Memory 2x4gb Kingston hyperX grey
Video Card(s) AMD sapphire 7850 oc
Storage 1tb WD blue
Display(s) Samsung S24c450
Case Thermaltake versa 2 black
Audio Device(s) Some genius
Power Supply 635watt
Software win 7 64bit
hi guys!
I'am trying to find cooler that can fit into my case almost 15 days, but no success :/
Pls help me to find some good cooler for oc under 155mm...
sneekypeet
not-so supermod
29,686 (4.31/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
97 (0.02/day)
Storage 1tb WD blue
yeah i saw that cooler , but it's 85-90e , too high for my budget :/
1,927 (0.43/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
Thermalright Truespirit 120M. Link
sneekypeet
not-so supermod
29,686 (4.31/day)
System Name EVA-01
Your specs aren't showing when I click on them, what are we cooling here anyways, and are you planning to clock it or run it at stock?
27 (0.01/day)
It would be helpful if you could structure your question better. What's your budget? Like sneekypeet said your specs are not showing, so that's also not helping.
Basically you can't go wrong with the TRUE 120M, despite it being a bit pricey. A cheaper choice would be the CM T4 with quad heat pipes.
97 (0.02/day)
Storage 1tb WD blue
AMD fx 6100 @ 4.1 ghz,load temp. 50c , my current cooler CM tx3 evo... Budget around 50e ....
this cooler loks nice, but i think that i cant find it in my country :/
97 (0.02/day)
Storage 1tb WD blue
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
97 (0.02/day)
Storage 1tb WD blue
12,333 (2.24/day)
Oregon
Fill out your system specs. What case you have? It's more than 1.2 but not sure how much
97 (0.02/day)
Storage 1tb WD blue
take a look
on this test there is 1c diference :/
12,333 (2.24/day)
Oregon
Get the CM212 and mod the case. Its only 5mm so put a custom scoop on the side like a louvered vent
