CPU heatsink fouls Northbridge heatsink: Advice Please
HookeyStreet
Eat, sleep, game!
7,122 (0.97/day)
Great Yarmouth, England
Well, I installed my A64 4000+ (skt939) and was about to fit my 'Arctic Cooling Silencer 64 Ultra' when I noticed that the new cpu heatsink & fan fouled the Northbridge heatsink due to the fact that the ACS64U has 2x tension bracket arms instead of just one :(
So I had to install my stock A64 3000+ heatsink & fan :( (the temps seem fine but Im sure the ACS64U would be better)
As its only the 1st row of fins blocking the cpu heatsinks arm couldnt I just remove them or rotate the Northbridge heatsink 180 degress???
Any help on this problem would be great, thanks in advance ;)
3,059 (0.44/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
rotate it would work or you could use a pair of pliars and bend the fins out of the way btw your specs say you have a 7000+ instead of 4 might want to change that
pt
not a suicide-bomber
8,956 (1.33/day)
Portugal
Processor AMD Turion 64 X2 Mobile TL-60 (Trinidad)
Motherboard ASUS F3Ka (ATI RS690M)
Cooling stock
Memory Nanya 2x1GB ddr2 667@5-5-5-15-2T
Video Card(s) ATI Mobility Radeon HD2600 512MB DDR2@ 580mhz/486mhz
Storage 160GB on laptop+250GB external
Display(s) ASUS 15.4
Case Asus Laptop F3Ka chassis
Audio Device(s) on-board
Power Supply 1:30minutes battery
Software "genui xp", 'cause i hated vista
i want a 7000+ too :p
it didn't look that rotating is possible, i would bend the pins or fert a different cooler
10,885 (1.59/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
I wish I had a picture to show you, but I put ramsinks on a X800GTO - the stock cooler was in the way on a few of them, but only by 1/2 in the worst cases.
So I took a dremel cutoff wheel and knocked the "offending" fins off the ram sinks.
Looks like your 180 deg idea is the best (the other side looks like a row of fins is missing), but if for some reason it doesn't work:
- You could remove it and shave down (or off) the row of fins that are in the way if you have a dremel and cutoff wheel, I don't think you'll loose much NB cooling capacity.
- Look for a lower profile or different NB sink (preferrable solid CU).
10,885 (1.59/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
OH - I just noticed this - the other side of your NB has missing fins to make room for the PCIex1 slot. So it look like rotating it will work, assuming you have no need for the x1 sot (who the heck does?)
HookeyStreet
Eat, sleep, game!
7,122 (0.97/day)
Thanks guys, I forgot to mention that one side of the heatsink had a row of fins missing ;) So its agreed, rotation would probably be best :)
HookeyStreet
Eat, sleep, game!
7,122 (0.97/day)
LMAO havent you seen the A64 7000+ 6.4GHz, its awesome :roll:
345 (0.05/day)
suffolk uk
Processor Core 2 duo - e8400 @ 3ghz
Motherboard Asus P5k-e
Cooling 1 pumps 2 blocks 2 rads 10x 120mm fans
Memory 4GB - OCZ PC2-8500 1066mhz (4-4-4-15)
Video Card(s) BFG 8800gts
Storage 1x Seagate Barracuda - 160gb SATAII
Display(s) 19" tft
Case Mozart TX
Audio Device(s) X-FI
Power Supply 700w coolermaster
Software xp home
give it a spin m8 or fit a low profile aftermarket one.
HookeyStreet
Eat, sleep, game!
7,122 (0.97/day)
I spun the Northbridge heatsink 180 degrees and now my Arctic Cooler fits perfectly :) Thanx for the advice guys :)
10,885 (1.59/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
