CPU IHS adhering to the cooling block
1 (0.00/day)
Processor Ryzen 7 2700x
Motherboard MSI Gaming M7 AC
Cooling Cooler Master 360mm ML360R
Memory 2x16gb 3000 Trident Z
Video Card(s) MSI RTX 2070 gaming X
Storage 1Tb SSHD FireCuda, 120gb Kingston SSD, 250gb 970 EVO+
Display(s) 2 x AG32C
Case H700 NZXT
Power Supply 1000W SuperNova g1+
I had this issue a while back and although I solved it I want to know how many other people have had this issue. I also ended up bending the pins on my new Ryzen 7.
I am doing this for a school engineering project.
This is a google form that I have mad to gather feed back, if anyone could fill this out I would appreciate it.
43,546 (6.77/day)
Been happening since skt 423 when first IHS appeared, it's best to run the system, shut down, pull the clip/screws twist heatsink several times, then pull.
For bent pins use a mechanical pencil to straighten them.
bug
14,081 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Or use an Intel CPU. They haven't had pins to bend in ages ;)
1,609 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Fractal Arc XL / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM850 / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
You sure about that?
How about these?
The amount of people that came back to me with new builds, and said that they've bent them is ridiculous.
bug
14,081 (3.96/day)
How about these?
You don't bend those when removing a stuck cooler from the IHS ;)
Plus, I said CPU. You're showing me a socket.
1,609 (0.34/day)
Mouse Logitech G903
VR HMD Rift S
Still pins tho, which are easily bendable, and even though they're not on a CPU, they're still there.
Solaris17
Super Dainty Moderator
27,249 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Just twist in AMD systems that’s what I do anyway
43,546 (6.77/day)
There have been plenty of motherboards from lga 775 to now that users came here with bent pins or burnt pins.
And they are easier to distort on lga...
bug
14,081 (3.96/day)
It will be such a glorious day when people will learn to focus...
3,984 (1.10/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
13,664 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
^^^This^^^ Running the system to warm the TIM (thermal interface material) first often makes it easier to break the cured bond. And then gently twisting the heatsink back and forth and then pulling while twisting typically lets you remove the heatsink without pulling off the IHS, or yanking the CPU out of its socket (leaving a few pins being).
326 (0.17/day)
Nuremberg
Processor Core i7 8700K@5 GHz
Motherboard MSI Z370 Gaming Pro Carbon
Cooling 2xEKWB Rads, EKWB Reservoir 250, Aqua Computer Kryos Next CPU Cooler, Phanteks Glacier GPU Cooler
Memory 16 GB DDR4 GSkill Trident Z 3200
Video Card(s) Asus ROG STRIX RTX 2080 O8G (GPU@2115 MHz/VRAM@7800MHz)
Storage 1x Samsung Evo 840 SSD 256, 1x WD Blue 1 TB HDD
Display(s) Asus ROG Swift PG248 1080p Display/144Hz/G-Sync
Case Fractal Design R6 with Window
Audio Device(s) Realtek onboard
Power Supply be quiet 650W Straight Power
Keyboard Cherry KB
Benchmark Scores FireStrike: 25953/Extreme: 13141/Ultra: 7099/TimeSpy: 11426/Superposition: 7667/CinebenchR20: 3916
I usually use a hair dryer or heat pistol for this :D
No need to run the system and you get the point where you can put it off very exact. The same is needed to disassemble GPU cooling blocks.
13,664 (2.02/day)
Nebraska, USA
Mouse Logitech M190
7,102 (1.01/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Pre heat it. Then gently push down with the heatsink while rotating it back and forth, rather than pulling up. The shear force of the twisting is what will separate the thermal paste bond, not the pulling action.
