CPU overheating for no visible reason
jiggyraff
2 (0.00/day)
Here a photo of BIOS in EZ mode directly after booting
Recently, my cpu has been reaching temps of 100C even in BIOS, and I have no idea why. I factory reset the BIOS to see if I screwed something up, but nothing changed. I use a 240mm coreliquid msi water cooler, and the tubing is hot to the touch right on startup. Any advice would be greatly appreciated.
Here are my specs:
NZXT h510i
MSI MPG Z490 Gaming Edge Wi-Fi
Intel i5-10600K
32GB Corsair 3200Mhz ram
MSI 240mm coreliquid cooler
AMF
693 (0.51/day)
USA
System Name MR T System price 2280$
Processor Ryzen 9 3900x 325 $4.7Ghz boost pbo +50 +50 enhance - offset auto voltage -.1875 offset soc
Motherboard ROG STRIX X570-E Gaming 125 $ open box
Cooling 280mm ARCTIC FREEZER II idle temps 25c cpu 28c cpu diode 20c vrm 25c motherboard b stock 60$
Memory 2x 16GB Dual rank G Skill Trident Z Neo F4-3600C16-16GTZNC @3800 1.395v 16-19-16-20-38-58-1T $96
Video Card(s) Asrock RX 6950XT Oc formula Oc edition 705$ 2700 2800 boost 1090v 2476 mem 19GB/s
Storage 500 GB WD SN850 PCI-E 4.0x4 85$ pcie16x4
Display(s) V505-J09 Vizio 4k HDR 299$ oc 5hz
Case Cougar Panzer Max G Full Tower Tempered Glass 150$
Audio Device(s) TV junk ewww
Power Supply Seasonic SS-1250XM2 Bought in 2013 350$ 11 y/o hasnt lost any voltage or watts
Mouse Logitech ERGO Trackball 35$
Keyboard Corsair K57 50$
VR HMD Dont give a damn about vr
Software win 11 pro modded by me no ai no remote connections free hehe
Benchmark Scores 8188 multi 540 single cinebench r20
sounds like pump not working or bad pump block install/ no thermal paste/ not enough mounting pressure . did u take off the plastic peel on bottom of cooler block? prebuilt or you built? pictures of inside case might be helpful also make sure power plug is not loose or seated allthe way on aio
212 (0.06/day)
ID_SUB
System Name Asus X450JB
Processor Intel Core i7-4720HQ
Motherboard Asus
Memory 2x 4GiB
Video Card(s) nVidia GT940M
Storage 2x 1TB
From your description with the tubing being hot, it sounds like the heat transfer to the block just fine, but not to the working liquid. Are you sure the AIO even working properly? Some early batches of MSI coreliquid got problematic gunk-prone coolant. It was recalled, but worth checking I guess.
Of course it still could be something else tho. Human touch are notoriously unreliable for thermal sensing :D. Hot to the touch can be anywhere from 30C to 100C++.
ixi
1,451 (0.38/day)
Remove msi aio and install air cooler and check temps then.
13,460 (1.99/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Please elaborate.
What do you mean by recently? Were they cool before? Or did they got hot from day 1?
10,898 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
9,583 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
What you are describing makes no sense to me.
There is no way the tubing gets hot to the touch right after booting the PC, I have to wait a good 5-10 minutes after a cold boot for any of the tubing or radiator to heat up noticeably, water has a high thermal capacity meaning it takes a quite a lot of heat to rise it's temperature vs a metal heatsink.
jiggyraff
2 (0.00/day)
Please elaborate.
Whenever I first ran this cpu, it also overheated very quickly, which is why I got the Mai cooler, and since then it has ran great, going up to a max of about 84C on heavy loads and 50-60C on light loads. And to be more specific, the CPU usually takes about 5 or 6 minutes to reach high 90s. It starts out in the high 50s.
I built this pc from scratch, and I did remove the plastic and put thermal paste. I’ll check up on the thermal paste, and then try a different cpu cooler.
9 (0.01/day)
Texas
System Name This One?
Processor Intel 11700k
Motherboard MicroStar MPG Z590 Force
Cooling CoolerMaster 280 Mirror AIO
Memory 32 gigs Corsair Vengeance Pro ddr4 3200MHz
Video Card(s) Sapphire Pulse Rx 6800 xt
Storage 2x- WD NVME 2x 3gig HGST spinning rust
Display(s) LG 27 inch 1440 p
Case Fractal Pop Air XL
Audio Device(s) on board Realtek
Power Supply EVGA 1000 watt
Mouse walmart special
Keyboard walmart special
Benchmark Scores https://www.youtube.com/watch?v=zpBA7eX1v6M
Here is your problem explained by a good tuber
1,727 (0.32/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
My friend was complaining and I found half a cat embedded in his radiator. Clean that thing out.
13,460 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Well, we don't know anything about your ambient (room) temperatures, but IMO, if those were your temps when the system was first put together, even then they were too high. They are not "hot" but 50 - 60°C with light loads is still pretty warm - too warm, IMO.
It appears that case only comes with 2 x 120mm fans. 120mm fans would be considered on the small size these days. You may not have enough cool air flowing through the case.
18,584 (2.67/day)
System Name AlderLake
NZXT h510i
I'm not surprised your hardware in that case runs quite hot....
It's almost a closed case with almost no fresh air coming in...
13,460 (1.99/day)
Nebraska, USA
Mouse Logitech M190
Which is why I was surprised NZHT only put in 2 x 120mm fans. According to the specs, it supports 2 x 140mm fans in front plus 1 x 120mm in back, and a 140mm up top.
@jiggyraff - you might want to remove the side panel and blast a desk fan in there just to see what happens. If temps drops significantly, you know you need to address your case cooling.
One more thing - one of the more common mistakes people make when applying TIM (thermal interface material) is they apply too much. Remember, the most efficient transfer of heat occurs with direct metal-to-metal contact of the mating surfaces. And the purpose of TIM is to fill the microscopic pits and valleys in those mating surfaces to push out and prevent any insulating air from getting trapped between the device and its heatsink. Any excess TIM is in the way and counterproductive to that efficient transfer of heat. :( So you want as thin a layer as possible while still providing full coverage.
3,125 (2.40/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
This sounds like a faulty AIO pump or coolant loss especially if the CPU temperature gradually climbs while idle. You can duplicate this behavior with a functional AIO by unplugging the pump just as I have done inadvertently. :D
Go to the Hardware Monitor section of the MSI UEFI screen. What does it say about the pump speed? If it's zero or very low, you have a broken pump. If the pump revolutions look normal, there was probably some sort of coolant loss.
Both failures are rare yet possible, the same as a modern gas-powered automobile which has the exact same cooling system.
