CPU per core frequency monitoring
Dux
511 (0.16/day)
Can someone recommend me program that can track all per core CPU frequencies. I know OCCT can do that but it shows some weird results when i try per core overcloking in ryzen master on 5900x. Hwinfo displays only frequencies for 6 cores. Anything else out there?
Mindweaver
Moderato®™
8,344 (1.44/day)
Charleston, SC
System Name Tower of Power / Delliverance
Processor i7 14700K / i9-14900K
Motherboard ASUS ROG Strix Z790-A Gaming WiFi II / Z690
Cooling CM MasterLiquid ML360 Mirror ARGB Close-Loop AIO / Air
Memory CORSAIR - VENGEANCE RGB 32GB (2x16GB) DDR5 7200MHz / DDR5 2x 16gb
Video Card(s) ASUS TUF Gaming GeForce RTX 4070 Ti / GeForce RTX 4080
Storage 4x Samsung 980 Pro 1TB M.2, 2x Crucial 1TB SSD / NVM3 PC801 SK hynix 1TB
Display(s) Samsung 32" Odyssy G5 Gaming 144hz 1440p, 2x LG HDR 32" 60hz 4k / 2x LG HDR 32" 60hz 4k
Case Phantek "400A" / Dell XPS 8960
Audio Device(s) Realtek ALC4080 / Sound Blaster X1
Power Supply Corsair RM Series RM750 / 750w
Mouse Razer Deathadder V3 Hyperspeed Wireless / Glorious Gaming Model O 2 Wireless
Keyboard Glorious GMMK with box-white switches / Keychron K6 pro with blue swithes
VR HMD Quest 3 (512gb) + Rift S + HTC Vive + DK1
Software Windows 11 Pro x64 / Windows 11 Pro x64
Benchmark Scores Yes
CPU-Z might work. I haven't used it in awhile I can't remember if it has a log.
  • Like
Reactions: Dux
461 (0.21/day)
Western NY, USA
Processor AMD Ryzen 7 3700x
Cooling Scythe Ninja 5
Memory G.Skill Ripjaws V 16GB (2 x 8GB) (F4-3600C16D-16GVKC) @ 3733 MHz 16-19-19-19-36-56
Video Card(s) MSI RTX 2060 Super Armor OC 8GB
Storage 1x Samsung 970 EVO 500GB / 3x Crucial MX500 / 4 HDDs
Display(s) Dell 23" LCD S2316M
Case Rosewill Rise Glow
Power Supply CORSAIR RM650
Mouse Cooler Master MS120
Keyboard Cooler Master MS120
Ryzen Master displays the frequency of each core under the Cores section.
If you are using Ryzen Master to OC you should be able to see them there.
Dux
511 (0.16/day)
That's exactly my problem. Ryzen master is not reporting frequencies correctly, or i am doing something wrong. I just sent a bug report to AMD and here is copy/paste of report.
"Simultaneous multithreading OFF, per CCD overcloking. Set different frequency on at least one core in CCX compared to other cores. Ryzen master will report that frequency is what you have set it to. But programs like OCCT and CPU-Z will report that the highest clocked core really does run at frequency you have set it to, while other cores in CCD drop in frequency. Tested with cinebench R20 to confirm. All cores in CCD 0 and CCD1 set to 4.5GHz. OCCT and CPU-Z report all core at 4.5GHz. Cinebench score almost 6500 with hyperthreading off.
CCD0 and CCD1 core C01 and C07 set to 4.7GHz, others to 4.6Ghz. OCCT and CPU-Z show those 2 cores at 4.7GHz. Others with significant drop despite ryzen master showing 4.6GHz on them. Tested with cinebench R20. Significant drop in score compared to all cores at 4.5GHz. Around 5700score. But should be higher if Ryzen master was reporting correctly. "
This is on R9 5900X
Edit. I just found this. Basically, AMD says no per core overcloking on ZEN 3. :( I'm suprised that Ryzen master let's you mess around with that then. Confusing.
217 (0.14/day)
System Name PowerSpec 1720 (Clevo PB70EF-G)
Processor i7-8750H (UV)
Motherboard PB70EF-G
Cooling SYY 157
Memory 32GB 3000MHz 15-18-18-36 1T (OC)
Video Card(s) 115W RTX 2070 8GB GDDR6 (OC/UV)
Storage 500GB WD Black SN700 NVME, 1TB Samsung 980
Display(s) 144Hz G-Sync 17.3" IPS
Case PowerSpec
Audio Device(s) Sound Blaster Pro-Gaming X
Power Supply 230W
Keyboard Redragon K556/DITI K585
Software M$ Windows 10 Pro, Throttle Stop 9.5, MSi Afterburner, ParkControl
Core Temp 1.16 has a very basic System Info option that lists each Core, thread, bus speed, voltage, and frequency. I am not sure if this is accurate enough or loggable, but it is a free program.
461 (0.21/day)
Western NY, USA
Well that's a shame.
Hopefully they will support it in future AGESA / BIOS versions.
Toothless
Tech, Games, and TPU!
9,738 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Hwinfo does per core clocks and temps.
3,831 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
The design of the CCX layout should be self explanatory?? There's only one CCX now, thus only one multiplier on a chip with one CCD. And btw for the record, there NEVER was per core overclocking on Zen. You could do per CCX previously but obviously since all 8 cores are now combined into one CCX, it is what it is. Only on two CCD chips is there option for two multipliers.
671 (0.43/day)
Austria
System Name nope
Processor I3 10100F
Motherboard ATM Gigabyte h410
Cooling Arctic 12 passive
Memory ATM Gskill 1x 8GB NT Series (No Heatspreader bling bling garbage, just Black DIMMS)
Video Card(s) Sapphire HD7770 and EVGA GTX 470 and Zotac GTX 960
Storage 120GB OS SSD, 240GB M2 Sata, 240GB M2 NVME, 300GB HDD, 500GB HDD
Display(s) Nec EA 241 WM
Case Coolermaster whatever
Audio Device(s) Onkyo on TV and Mi Bluetooth on Screen
Power Supply Super Flower Leadx 550W
Mouse Steelseries Rival Fnatic
Keyboard Logitech K270 Wireless
Software Deepin, BSD and 10 LTSC
23,179 (6.10/day)
MSI Afterburner + RTSS does it all. Logging it is optional. On screen display is tweakable.
461 (0.21/day)
Western NY, USA
I was under the impression that the 5800x has only 1 CCX BUT the 5900x and 5950x CPUs have 2 CCX's.
Which is why the 5800x tends to run hotter.
This change also means that AMD can now produce CPUs with up to eight cores using only a single CCX and the accompanying I/O die—this is exactly how the Ryzen 7 5800X is configured. Meanwhile the top of the stack, the Ryzen 9 5950X, which is a 16-core, 32-thread CPU, has two eight-core chiplets alongside that same I/O die. The likes of the Ryzen 9 5900X meanwhile has a pair of chiplets each with six active cores.
Manual overclocking to 4.6GHz at 1.3V produced the biggest uplift in Cinebench R20, with a score of 9,062, which is even faster than 16-core, 32-thread 3950X manages. Just let that sink in a second: the improvements AMD has made to this chip make up for a difference of four cores compared to the previous generation. That's pretty impressive. Unfortunately the single core performance still suffers under this overclocking regime, and the performance dropped by seven percent to 594.
Perhaps per CCX or per core overclocking will change this after the fact. But, for now, it just isn't worth overclocking these chips.
If I am mistaken please let me know, so I am not misinformed or misinforming others.
1,470 (0.21/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Then how do you get a single core boost of say 4.8/9ghz whilst the other cores are running lower than that?
3,831 (0.74/day)
Processor AMD 5900x
Storage Sabrent
Case Phanteks 719
Mouse Logitech G600
I was under the impression that the 5800x has only 1 CCX BUT all the other released 5000 CPUs have 2 CCX's.
The 5600x and 5800x are single CCD chips. The 5800x may run hotter because it runs at the same TDP as the two larger chips the 5900x and 5950x. Do the math per core the 5800x runs with a higher TDP. I would have thought that was why ppl wanted a 5800x, to be less limited by power design limits?
You don't control single core boosting, AMD's algorithms do. When you switch to manual all core overclock, you effectively disable that. Read up on the Curve Optimizer, that will allow you to boost single core and raise the all core boost. But doing things the old way isn't a benefit anymore, like manual all core oc'ing.
461 (0.21/day)
Western NY, USA
I edited my last post.
And I tend to agree that Manual OCing Ryzen 3000 and mosty likely 5000 CPUs isn't worth the effort.
I run my 3700x with PBO instead of a manual OC because a Manual OC does Not benefit my CPU except in Multicore Benchmarks.
Dux
511 (0.16/day)
I have a 12 core chip. So 2 CCD chips. It is confusing that when you go into Ryzen Master advanced settings you can without problem set per core frequency. It even lets you adjust all of them by moving just one slider, or each core separately. That is the confusing part. That it lets you do that. Even when you click apply it shows that each core is at that frequency you set it to. But it doesn't work like that.
