CPU Support (problem?)
Marco_Came
8 (0.02/day)
Good evening,
I have a question to ask hoping to receive an answer and find a solution.
To be precise, I purchased this machine:
MSI Katana GF66 12UD-074IT, Gaming Notebook, 15.6" FHD 144Hz, Intel I7-12700H, Nvidia RTX 3050Ti 4GB GDDR6, 16GB RAM DDR4 3200MHz, 1TB SSD M.2 PCIe 4.
I use this notebook with windows 11 and I only use OBS to stream with my console.
It's new so I don't use it for gaming.
However, I noticed that when doing a test with Cinebench R23, my CPU is "cut" (because it probably reaches 100%) and then returns to normal values with a maximum of 91 degrees (see image):
Furthermore, as you can see, the CPU remains at 45W instead of supporting its 115, giving a core score of almost 12,000 and not 16,000 as reported by various tests online.
As regards the temperatures, the tests on Hwinfo show them remaining around 70/80 degrees. All this in idle or at most with OBS open (the streaming program).
Can you explain to me if this is normal or is there something wrong?
The profile is set to High Performance.
If anyone would be kind enough to give me some clarification on this, I would be grateful.
Thank you
2,924 (4.72/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
0. Your CPU is limited to 45 W in BIOS and for a good reason. Your cooler will never manage to cool 115 W down.
1. There is nothing you can do but changing BIOS settings or modding the BIOS (or maybe Throttlestop...). But...
2. You will need to improve your cooling first. Hitting 91C at 45 W simply means your CPU will get to a million degrees at 115 W and burn your laptop and yourself as well.
3. The most reasonable thing you can do is to undervolt your CPU so it will stay at 45 W but hit higher clocks.
4. And yes, this behaviour is absolutely normal.
329 (0.19/day)
System Name myPC
Processor i5-11600k @ stock
Motherboard Asus TUF Z590 Gaming Plus
Memory Corsair Vengeance LPX 2x8GB DDR4 3200
Video Card(s) Asus Dual RTX 3060 ti
Storage Boot: WD Black SN770 1TB - Game Storage: WD Black SN770 2TB - Other Storage: 4TB
Display(s) Samsung Odyssey G5 curved 27" 1440p 144hz
Case Thermaltake v100 perforated
Audio Device(s) Some headphones and some speakers
Power Supply Gigabyte UD750GM
Mouse Logitech G203
Keyboard Redragon K509
Software W11 Pro
Max Turbo Limit is 115W, but that is not what your CPU regularly consumes under load.
That's what they call Processor Base Power, which is 45W.
Marco_Came
8 (0.02/day)
Thanks for the replies
What I would like to understand is:
- is it normal to just use the obs program and have those ranks without playing? With the fans still spinning? Didn't do this before (PC is new)
- If I were to play then, the CPU would explode hahahaha
I took a look at the score obtained online with my own notebook, and mine achieves a much lower score..
If you think everything is fine and I don't have to worry, that's better.
If you have any other helpful tips, I'm all ears.
2,924 (4.72/day)
Russian Wild West
If your CPU doesn't overheat it's fine.
Nope. Your CPU is overqualified for most games and won't hit so much of temperature. On the other hand, games will burn your GPU but you can lower settings, enable vsync at half your refresh rate, undervolt etc. If you run into any overheating issues it's a good idea to contact the seller and ask them for repasting.
Marco_Came
8 (0.02/day)
With hwinfo, now, only with the browser open, it detects these degrees:
When I open obs and go live, it almost reaches 90/100 (as I showed in the previous screenshot.)
Maybe I'm the one who isn't understanding how it works? Very likely.
2,924 (4.72/day)
Russian Wild West
2,924 (4.72/day)
Russian Wild West
If you're recording at that moment all values are valid. Temperature is a bit high but what can you do, laptops are almost always like that. If repasting is available go for it.
Marco_Came
8 (0.02/day)
What do you mean with 'if repasting?' looool
However, no, they are values only with the program open.
When I go live they increase.
Risk of burning the CPU?
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
82C at usual loads is fine. It isn't too hot, especially for a laptop CPU. I'd be concerned at 95+ under load. Or idling at 82.
2,924 (4.72/day)
Russian Wild West
ir_cow
4,386 (0.74/day)
USA
Intel designed 12th Gen and up to run at 100c. If its below, that nice, but nothing to worry about.
2,373 (0.58/day)
Audio Device(s) A LOT
I think OP is saying that it’s 80* with OBS open and no streaming.
@Marco_Came what are temps when streaming?
329 (0.19/day)
System Name myPC
Mouse Logitech G203
Software W11 Pro
He said 80 when he opened OBS and went live. 90C was Cinebench, which is fine.
2,373 (0.58/day)
7,479 (1.77/day)
Click the gear toward the bottom right, just next to the X(close) button.
2,924 (4.72/day)
Russian Wild West
