- Dec 14, 2015
- 79 (0.02/day)
System Name | ACXtreme |
Processor | Ryzen 4 7800x3d |
Motherboard | Arous xtreme x670e |
Cooling | Artic cooling artic freezer II 420 |
Memory | T force rgb ddr5 6000 |
Video Card(s) | Rx7800xt nitro+ & Sapphire R9 390 NITRO with back plate |
Storage | 990 pro nvme samsung |
Display(s) | 34" ultra wide rgb |
Case | ANTEC performance 1 |
Audio Device(s) | Sound blaster |
Power Supply | Evga supernova 1000w |
Mouse | 502 protocols core or something like that |
Keyboard | G910 "Logitech" romer g switches |
Software | Windows 11 |
Benchmark Scores | 4600+ heaven |
Should I add a dot of artic silver 5? I didn't remove the heatsink but I loosened it and checked everything out and I saw artic silver 5 running down the side of the chip pretty much so I didn't break the heatsink off but should I remove it and add some compound to the center of the cpu?
I've also used prime95 and looked at the temp
This pic is the cpu temp normal not doing anything like playing games
