CPU temps below ambient (i5-13400)
56 (0.09/day)
Processor AMD Ryzen™ 5 7600
Motherboard ASUS ProArt B650-CREATOR
Cooling DeepCool AK500 Zero Dark
Memory 2x16GB ADATA LANCER 5600MHz
Video Card(s) RX 6700 XT XFX QICK 319
Storage Corsair MP600 GS PCIe 4.0 500GB / Crucial P3 PCIe 3.0 1TB
Case Corsair 4000D Airflow Black
Audio Device(s) SONY GENEZI MHC-EC55
Power Supply Thermaltake Toughpower GF1 850W 80+ Gold
Mouse Corsair HARPOON RGB Gaming Mouse
Keyboard Corsair K55 RGB Gaming Keyboard
Benchmark Scores Cinebench R23: 15022 / Geekbench 6: 12976 / Passmark 11: 28156
Hi! I have an i5-13400 and i'm having very low idle temps. I checked temps with CoreTemp, HWiNFO, HWMonitor, etc. On BIOS it's around 22-25°C but when i run, for example, HWiNFO, each core fluctuates between 10°C and 18°C (averaging 14-15°C). My room temp is around 16-17°C. HWiNFO, is between 19°C and 24°C. Should i be worried about condensation or anything, or this is normal?
The rest of the system:
ASUS B660-A ROG Strix WiFi D4
4x8GB Corsair Vengeance RGB Pro
H115i RGB PRO XT with Redux coolers
Zotac RTX 3060Ti Twin Edge OC
Seasonic Focus GX-850
Corsair 275R Airflow Black
Kingston Renegade 500GB PCIe 4.0
WD Blue SN550 1TB PCIe 3.0
Samsung EVO 860 1TB SATA
3x ID Cooling ARGB
LG 27" FullHD IPS G-Sync/FreeSync
Corsair K55 + Corsair Harpoon
367 (0.41/day)
I think this is to do with minimum fan speeds/fan configuration. Could you post a screenshot of the part of HWINFO that shows fan speeds. And how are controlling fan speeds, BIOS settings or software.
18,584 (2.67/day)
System Name AlderLake
786 (0.11/day)
Yulee ,Florida
System Name 1080/1440 Beast
Processor Ryzen 7 5700x @4848.87Mhz
Motherboard Asus ROG Strix B550-F Gaming
Cooling Cooler Master ML240L RGB V2
Memory 64 GB 4x16 GB GSkill Trident Z Neo 3600Mhz CL16
Video Card(s) AMD Radeon™ XFX Speedster MERC 319 RX 6750 XT Black 12 GB /\ Core 2725Mhz Vram 2312 UV 1145mv
Storage WD SN850 Black 1TB M.2 OS C: / Samsung 860 evo 500GB SSD Disk 2/ Western Digital 1TB SATA3 Disk 3
Display(s) Dual Monitors Samsung G5 G55C 32" Curved 165 Hz 1440p HDR / MSI G32C4W 31.3" Curved 165Hz 1080p
Case Vetroo Mesh6
Audio Device(s) Logitech Z-2300 2.1 THX Series / RIG 800 LX Dolby Atmos
Power Supply Thermaltake Smart 700watt
Mouse Asus
Keyboard Asus
Software Windows 11 64bit Home
Benchmark Scores CB R23 15306 SuperPos. 4K 10980 CpuZ 667.3/6728.2 TimeSpy 14,090
Looks like you are idle so in lower power yeah temps are going to be cooler. It also sounds like you have good air flow. Condensation well you would need to be in a really cold environment for that to happen "like opening the window to let the winter air in".
56 (0.09/day)
Hi. Water cooler fans are running at 1200rpm constantly.
So which is it?
Then
That's possible.
Individual core temps and package temps.
Thanks for your explanation. Then you say these temps are fine?
367 (0.41/day)
There is no need to run the AIO fans at full speed all the time. They are running at 100% because the AIO pump is running at 100% and the fans are working off the same PWM duty cycle. The three ID Cooling ARGB fans have a fairly high idle speed, around 900 rpm. All in all this is giving you tons of case airflow and no shortage of cooling when gaming. The only downside might be the noise the system makes at idle. If this does not bother you, then I would leave the system as it is.
56 (0.09/day)
Max rpm for the aio fans is 1500, i put them 1200 because i hate when they ramp up and down. The noise doesn't bother me. The ID cooling fans are running at 1000rpm. Thanks for your time and explanation.
Another thing, while on BIOS, the CPU sits at about 23c but in Windows the package is at 18c. I know the cores run with lower temps compared to the package, but maybe there is a reading error or an error with the sensor. I had a 12400 and i trade it for this cpu and temps where higher while idling with the same ambient temp.
367 (0.41/day)
HWINFO says that the package temp in Windows is a "... 256ms average of the hottest temperature of all Digital Thermal Sensors (DTS) within the package calculated by the CPU". The 12400/13400 difference might be because the 13400 has E-cores and the DTS values of these are being taken account when calculating the package temperature.
56 (0.09/day)
Then it is normal? Individual cores and package temps?
Here's a pic of the BIOS. I think that different softwares are showing wrong CPU temps. Or does the BIOS utilizes a lot of CPU? Cheers.
367 (0.41/day)
The way the BIOS calculates CPU temperature won't be the same as HWINFO. It may well be the temp of the hottest of the sensors on the CPU. But 25C is perfectly OK as a BIOS temp for a 13400. Under idle conditions in Windows you would see a lower number because the CPU would downclock to around 400 MHz and the core voltage would be more like 0.7V. Then you have software calculating average values. I don't think your temperatures overall should give you any concern.
56 (0.09/day)
Ok, thanks very much for the detailed explanation. Have a nice day and cheers! :)
1,439 (0.28/day)
Romania
Processor Ryzen 5700x
Motherboard MSI B350 Gaming Pro Carbon
Cooling be quiet dark rock pro 3
Memory GSKill Aegis 32GB (4x8GB) DDR4 3200MHz CL16
Video Card(s) PowerColor Radeon RX 7800 XT Hellhound 16GB GDDR6 256-bit
Storage Seagate Barracuda SATA-II 1TB , HyperX Savage 240GB SATA 3
Display(s) Benq EX2780Q
Case Be Quiet! Dark Base Pro 900
Audio Device(s) Sound BlasterX G6
Power Supply Seasonic prime TX-650
Mouse Marvo Scorpion G981
Keyboard Razer Blackwidow Elite - Yellow Switch
i don't know about below ambient but my ryzen 1700x in idle or some slow browsing was 24-27 Celsius.
not related: now my 5700x is 49 celcius and they say its normal :ohwell:
77 (0.06/day)
Processor R7 78X3D
Motherboard B650
Cooling Thermalright
Memory 32GB 6000CL30
Video Card(s) 6600 XT
Storage 970 Evo/MX500
Display(s) AOC C24G1
Case Deepcool CH370 W
Audio Device(s) Beyerdynamic DT770 Pro & Fifine T669 Mic
Power Supply SeaSonic Focus GX-850
Mouse Logitech GPXSL
Keyboard Logitech G Pro
Seems fine to me. My 5600G will go as low as 26°C (ambient 23°C) when idling on the desktop. CPU fan is running at 500RPM or less, intake fans at a fixed 650RPM. The fact that your temps are being reported as below ambient is odd though, either your CPU temp sensor is a bit off or your thermometer for your room ambient is off by a few degrees. Either way, as others have stated, condensation is highly unlikely to be an issue, unless you live in a really humid environment and you cause massive temperature fluctuations.
Hugis
825 (0.15/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage SN850X - P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Cooler Master MM712
Keyboard Logitech S530 - mac
for reference
Ambient here atm 21 degrees
56 (0.09/day)
Hi. Next monday i'm borrowing a 13400F from a friend and i will see if it has the same behaviour. Your 1700X was below ambient too? Thanks!
It's a tad humid here, but not too much. Thanks for your answer.
for reference
Hi. Thanks for the reference, i appreciate it. What is your BIOS CPU temperature. Because the BIOS show 25-27°C but in Windows, the package is around 21°C (the cores have pretty low temps). Thanks!!
Hugis
825 (0.15/day)
here you go
825 (0.44/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
There could be a gap between the temperatures measured from different methods
That gap probably made the CPU's temperature seem lower the ambient temperature while the 2 temperatures are very close
56 (0.09/day)
Hi! It was the CPU. They switched me the 13400 (ADL variant) for a 13400F (RPL) and now everything is ok. Thanks! And @Hugis, you're a genius for taking your time to show me the temps. Appreciate it!
56 (0.09/day)
It seems that ADL based CPUs have a different temperature in Windows than in BIOS (specially using ASUS mobos). My 13400F showed correct temps, but it freezed continuously. I asked for a refund, and they sent me a 12700. This CPU has the same behaviour as yours and my previous 13400 (RPL, but based on ADL).
13,889 (6.29/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
If your room is 16-17 °C, then 19 °C on your CPU is not below ambient. It's actually pretty impressive!
56 (0.09/day)
I think my room temp is above cpu temps. A guy from another forum told me that my cpu has an offset of -10c. I don't know if the mother is applying it or if the adl based cpus have these behaviour. A 13400f based on rpl showed the correct temps and the same as in bios, but a 13400 based on adl and the 12700 showed this behaviour. Bios temps are higher than in windows.
97 (0.02/day)
If I remember correctly the thermal senors on processors can get incredibly inaccurate the further and further their delta gets from TJMax, but at TJMax they are very accurate, which is what the manufacturer cares about. I wouldn't be concerned about the reading.
6,881 (1.45/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Ive gone below ambient. Example rinse radiator in sink plug it in fan creates evaporation and goes below ambient for a long while.
Nothing is impossible
56 (0.09/day)
Weird that the raptor lake one was pretty accurate. Seems like adl sensors are, as you said, pretty innacurate.
