CPU upgrade: Ryzen7 5700X → 5700X3D
Murders_Inc828
1 (1.00/day)
My current build looks like this. MB: B550 GPU: RTX4070 CPU: Ryzen 5700X RAM: 16GBx2 DDR4 OS: Win11 Home PSU: 750W
Been wanting to upgrade my CPU for a while since I play CPU heavy games eg Tarkov, Helldivers, Hell let loose, RTS.
Ideally, I would go for a 7800X3D but it costs around 800USD with tax and conversion rate included for where I live and most retail stores I personally trust has ran out of stock. Not to mention swapping out the MB, RAM and perhaps the CPU cooler comes with an additional cost.
On the other hand, 5700X3D is like 300-400USD with no need to swap out other components (I think).
Is this a logical and a reasonable upgrade? Or am I being stupid here? If I were to buy a 7800X3D, I’d like to make a 2nd PC from scratch and use my current pc for my work/business work station.
Thx for taking your time reading and sorry for the long post.
288 (0.85/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000, 32GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
What utilization is your 4070 running at in the games you play? Is your CPU pegged right now?
If you're playing at 1080p, you might see some uplift going to a better CPU, but if your 4070 is already at 99-100% utilization and your CPU isn't running that hard in those games, you will likely see minimal uplift. It's important to remember that the CPU comparison charts on reviews are using a 4090, intentionally trying to bottleneck the CPU as much as possible to show the differences in the CPU. If you are not running a 4090, that bottleneck shifts towards the GPU and you may not gain as much by upgrading your CPU.
2,773 (1.51/day)
System Name Not a thread ripper but pretty good.
Processor Ryzen 9 5950x
Motherboard ASRock X570 Taichi (revision 1.06, BIOS/UEFI version P5.50)
Cooling EK-Quantum Velocity, EK-Quantum Reflection PC-O11, EK-CoolStream PE 360, XSPC TX360
Memory Micron DDR4-3200 ECC Unbuffered Memory (4 sticks, 128GB, 18ASF4G72AZ-3G2F1)
Storage Samsung 2TB 980 PRO 2TB Gen4x4 NVMe, 2 x Samsung 2TB 970 EVO Plus Gen3x4 NVMe, AMD Radeon RAMDisk
Power Supply Corsair RM750x
Mouse Logitech M575
Benchmark Scores Typical for non-overclocked CPU.
Side grading 5700X to 5700X3D probably isn't as cost effective as getting a better GPU but you already have a 4070 making this side grade an relatively expensive prospect to chase higher framerates. I would go 7800X3D but if the cost is too much you don't have to get a X3D CPU either. Better choices might be 7600x/9600x if cash is tight. Looking at benchmarks between 5800x3d and 7000/9000 cpu's will come in handy trying to pick the right one. You should also check to to see if the games you are playing actually benefit from X3D.
32 (0.03/day)
which rams speeds? if you are 3200-3600 you are done. static overclock 5700x at 4,775ghz using lowest possible voltages and call it a day untill you get 5700x3d or 5800x3d at discounted price. tweak windows and disable spectre protection also help, upgrade bios, chipset drivers.
dgianstefani
TPU Proofreader
4,746 (1.97/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White, Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
Get 9800X3D or Arrow Lake.
