CPU Upgrade vs 1080ti?
129 (0.03/day)
System Name BK-201
Processor Intel i7-7700K 4.20GHz
Motherboard GA-Z270X-UG
Cooling Cryorig H7 Tower Cooler
Memory Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz (PC4-25600)
Video Card(s) Gigabyte AORUS GeForce GTX 1080 Ti Xtreme Edition 11GB
Storage Seagate 7200rpm 2TB; Western Digital 7200rpm 1TB; Samsung 860 EVO 2.5" SATA III 500GB
Display(s) AOC 24" 1080p 144hz G-Sync
Case Thermaltake Chaser MK-1
Audio Device(s) N/A
Power Supply Thermaltake Smart M850W Modular 850 Watts
Mouse Razer Naga Hex v2 Chroma
Keyboard Razer Black Widow Ultimate Chroma
I am thinking of upgrading once again, and right now not entirely sure on what I should choose between a cpu upgrade or a 1080ti.
First of all, here are my specs:
CPU: i5-3570k
GPU: 2 x Gigabyte G1 Gaming GeForce 970
RAM: 2 x 8GB Ballistix DDR3 1600Mhz
PSU: Thermaltake 850 Watts (can't quite remember the exact model)
MOBO: Gigabyte Z77X-UD5H
CPU Fan: CoolerMaster Hyper 212 EVO
I game using a 1080p 144Hz monitor, and if I can, I also use Dynamic Super Resolution when framerate allows depending on the game. I play a lot of Witcher 3 still to this day (modded mind you), which I know is a more CPU demanding game and one of the reasons for this dilemma.
So I am either thinking of getting a 6th or 7th gen CPU (most likely 6700k or 7700k) if I am to go this route but If I was to get a 1080ti I would wait for the manufacturer custom cards.
What do you guys think?
EDIT: Forgot to put motherboard model and cpu cooler!
1,269 (0.35/day)
Birmingham UK
System Name El Calpulator
Processor AMD Ryzen R7 7800X3D
Motherboard ASRock X670E Pro RS
Cooling ArcticCooling Freezer 3 360ARGB AIO
Memory 32GB Corsair Vengance 6000Mhz C30
Video Card(s) MSI RTX 4080 Gaming Trio X @ 2925 / 23500 mhz
Storage 5TB nvme SSD + Synology DS115j NAS with 4TB HDD
Display(s) Samsung G8 34" QD-OLED + Samsung 28" 4K 60hz UR550
Case Montech King 95 PRO Blue
Audio Device(s) SB X4+Logitech Z623 2.1+Astro A50 Wireless
Power Supply be quiet! Pure Power 12 M 1000W ATX 3.0 80+ Gold
Mouse Logitech G502X Plus LightSpeed Hero Wireless plus Logitech G POWERPLAY Wireless Charging Mouse Pad
Keyboard Logitech G915 LightSpeed Wireless
Software Win 11 Pro
Benchmark Scores Just enough
I would advise you to do both, wait for Ryzen 5 to come out as I can see you don't do OC . If the price is good and the performance is good as well get one of those and a gtx1080 this together will be a good buy and just a bit over the 1080Ti budget I think. If you prefer Intel instead go for the 7600K and get it OC around 4.6ghz and get also the GTX1080 this should be more than enough for 1080p gaming.
You'll have to buy the platform all together for Ryzen or Intel 7600K so that is MB+CPU+RAM
129 (0.03/day)
System Name BK-201
Audio Device(s) N/A
Hmm well I was thinking of upgrading this summer actually, because then I assume most of the 1080ti's will have been released at that point. I would like to do both but money is an issue. I'm thinking of doing one or the other, at least for now.
As for Ryzen 5, I can definitely wait and see the benchmarks and all that, but I have always went with Intel so I suppose I do prefer them though I don't have any experience with AMD.
I had compared 1080 vs 970 SLI and it just wasn't worth the upgrade, so I'd rather go with 1080ti. Honestly, even with what I have right now, some games like AC Syndicate I can't even max out @1080p 60fps. Though something tells me it might be the CPU sometimes, especially with Witcher 3, I usually have 80-90fps but in some situations it goes under 60fps.
Also, not much benefit to 7700k as opposed to 7600k? i7 still not that much better than i5 then I guess?
41,440 (6.58/day)
The only difference between intel and amd is how they overclock, that is it.
If you intend on a total upgrade I'd grab a Ryzen r5. If not you can always drop a 3770K in that board and A GPU upgrade too, however with 1155 I would ensure you have a motherboard bios from 2013 even if that means a beta bios. Otherwise stay put and oc the cpu and grab a 1080ti. Then upgrade the rest later if the prices pitch in everyones favor.
Tatty_Two
Gone Fishing
25,889 (3.79/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Software Win 11 Home x64
CPU, it is more behind in performance terms that 970sli IMO.
5,676 (1.12/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
Both, but CPU first. I also think you're better off waiting to see what the Ryzen hex core performance and pricing will be. Plus your 2x 970 GPU arrangement is plenty to game at 1080p for now, even with a 144Hz display. I would stick with Nvidia on the GPU though. I simply don't trust AMD for GPU driver support anymore, and I'm currently on an AMD.
It's not so obvious now, but in a couple years we could see a lot of games running smoother on CPUs with more than 4 cores. To be honest, I'm kinda leaning toward an 8 core CPU myself, especially now that Ryzen benches are looking so much better with AMD and W10 updates. It will likely be even better when the high speed RAM compatibility issue is fixed.
9,327 (3.31/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Both , not necessarily now , you can take the 1080ti and upgrade the platform say a year from now.
Hardly a good advice , or rather just not relevant , I have already said this a number of times : both Nvidia and AMD can screw up their drivers. I used both for an extended period of time and they both gave me headaches. Also , lets face it , if the GPU that you currently use is the 7970 , well that's reaching it's 5th birthday this year , you can't expect it to receive the same support as it did form day 1. Kepler is also dead to Nvidia too which is from the same time period as GCN 1.0.
12,310 (2.29/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
F it get the 1080 ti
peche
Thermaltake fanboy
6,709 (1.86/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
i'll uprade video cards & proceesor, how? sell your sli, get a GTX 1080 and 1151 i5,
Regards,
2,388 (0.64/day)
Shenandoah Valley, Virginia USA
System Name Home Brewed
Processor i9-7900X and i7-8700K
Motherboard ASUS ROG Rampage VI Extreme & ASUS Prime Z-370 A
Cooling Corsair 280mm AIO & Thermaltake Water 3.0
Memory 64GB DDR4-3000 GSKill RipJaws-V & 32GB DDR4-3466 GEIL Potenza
Video Card(s) 2X-GTX-1080 SLI & 2 GTX-1070Ti 8GB G1 Gaming in SLI
Storage Both have 2TB HDDs for storage, 480GB SSDs for OS, and 240GB SSDs for Steam Games
Display(s) ACER 28" B286HK 4K & Samsung 32" 1080P
Case NZXT Source 540 & Rosewill Rise Chassis
Power Supply Corsair RM1000 & Corsair RM850
Mouse Generic
Keyboard Razer Blackwidow Tournament & Corsair K90
Software Win-10 Professional
Benchmark Scores yes
Replace your CPU and you may be pleasantly surprised at the ~real~ performance of the SLI 970s
6,862 (1.13/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
Not really understanding the recommendations for upgrading the CPU over the GPU, especially with a SLI set-up. I mean really? The 2500k/2600k are still considered capable CPUs. But SLI support is not what it used to be from everything I've read here on TPU.
So I'm going against the grain, and recommending keeping your current CPU/MB/RAM for the time being, and going for the 1080ti upgrade. And learn to OC that 3570k to around the 5GHz mark.
Kanan
Tech Enthusiast & Gamer
3,517 (1.06/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Do you run the CPU overclocked? If not, you should. That said, 1080 Ti will be bottlenecked by this CPU by a fair amount because it's simply too fast for this CPU to cope, whether overclocked or not. If you plan to upgrade to 1080 Ti, do it and buy CPU after, or upgrade CPU + GPU both at the same time. For the 1080 Ti I'd go with a Ryzen 7 1700 (but only if you overclock) or i7 6800K.
The bottleneck with 1080 Ti will only occur in games that are CPU heavy, a few games that are GPU heavy like Crysis 3 and not CPU heavy would run fine with that CPU + 1080 Ti.
129 (0.03/day)
System Name BK-201
Audio Device(s) N/A
I must say all those different answers got me more conflicted about which one I should go for first. Though, if I go the 1080ti route, I was thinking of selling my 2 970s to compensate for the price which would definitely help.
As for new CPU, I'm fairly certain I would go with LGA 1151 socket for Intel. On the AMD side, if I was to go for a Ryzen, I have seen some benchmarks and it seems like those are more workstation oriented than gaming.
As for OCing, anybody got a simple tutorial or video that I could check out?
2,715 (0.59/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
If you are only using a 1080 monitor, I wouldn't upgrade to the 1080ti.
How overclock is your processor, you didnt mentioned if the cpu was overclocked or not.
Outback Bronze
2,000 (0.42/day)
Walkabout Creek
System Name Raptor Baked
Processor 14900k w.c.
Motherboard Z790 Hero
Cooling w.c.
Memory 32GB Hynix
Video Card(s) Zotac 4080 w.c.
Storage 2TB Kingston kc3k
Display(s) Gigabyte 34" Curved
Case Corsair 460X
Power Supply PCIe5 850w
Mouse Asus
Keyboard Corsair
Software Win 11
I'm recommending OC the 3570K and 1080 Ti.
I doubt your processor overclocked will bottleneck a 1080 Ti.
Kanan
3,517 (1.06/day)
Europe
VR HMD Still nope
It will 100%, even a 4670K @ 4.2 GHz bottlenecks a 980 Ti in certain games, and we're talking about almost double that GPU power. That 3570K has no chance.
@OP: you can simply sell the GTX 970's, buy 1080 Ti and upgrade CPU later. Overclock is easy, it's just buying a "K" CPU (and Z mainboard ofc), going into bios and rising multiplier, it's fairly simple. It just gets interesting when you want to finetune voltage, but it's not a must do.
Tatty_Two
Gone Fishing
25,889 (3.79/day)
Worcestershire, UK
Even at 1080p 144Hz I struggle to recommend a 1080Ti to anyone unless they actually have a large spare wad of cash lying around doing nothing, the Op clearly has not so my CPU upgrade recommendation was based on what I consider to be the weakest link (I am not saying weak, just weakest), I agree that SLi can be iffy, but he has them and is using them, I can only presume if he was having huge issues with them he wouldn't have needed to ask this question in the first place he would have just replaced the 2 cards.
Kanan
3,517 (1.06/day)
Europe
VR HMD Still nope
If the main problem is a CPU bottleneck than this has to be upgraded first ofc. The OP seems kinda in a hurry to replace those GTX 970 though. Fact is, a i5 3570K without! overclock isn't really enough to drive 2x 970 in SLI, as I said even a 4670K @ 4.2 GHz can bottleneck a 980 Ti (OC), those GTX 970 in SLI are essentially the same, just his CPU is much weaker. At this point, I'd now recommend upgrading the CPU first. 6700K/7700K, nothing else if you want to stay Intel, 5820K and 6800K are a nice and even better alternative, but the platform is more expensive (in my books easily worth it though). For the latter ones you have to definitely overclock for decent gaming, for the 6700K/7700K not, because they are already pretty nice clocked out of the box.
Here you go.
1,350 (0.35/day)
Processor i7-4790K 4.6GHz @1.29v
Motherboard ASUS Maximus Hero VII Z97
Cooling Noctua NH-U14S
Memory G. Skill Trident X 2x8GB 2133MHz
Video Card(s) Asus Tuf RTX 3060 V1 FHR (Newegg Shuffle)
Storage OS 120GB Kingston V300, Samsung 850 Pro 512GB , 3TB Hitachi HDD, 2x5TB Toshiba X300, 500GB M.2 @ x2
Display(s) Lenovo y27g 1080p 144Hz
Case Fractal Design Define R4
Power Supply EVGA Supernova G2 850w
Mouse Glorious Model D
Keyboard Rosewill Full Size. Red Switches. Blue Leds. RK-9100xBRE - Hate this. way to big
Software Win10
Benchmark Scores 3DMark FireStrike Score : needs updating
OP, send me a pm if you decide to sell the 970s. I could use another 970, my 4790K needs to stretch out for once.
Edit: I would say a cpu upgrade as others have said that the i5 is a little slow for a 1080Ti. Though it is a great cpu, just not for a 1080Ti, just my uninformed opinion.
2,012 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
qubit
Overclocked quantum bit
17,865 (2.91/day)
Quantum Well UK
System Name Quantumville™
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Agreed, £700+ is an obscene amount of money to spend on a graphics card. While I could afford it, I wouldn't be comfortable doing so unless I had a very solid need for a 1080 Ti, which I don't. Selling the 970s will help a fair bit, though.
@BlackAzrael I recommend a 1080 Ti if you wanna hit that high 144Hz framerate more reliably and get away from the issues of SLI. While your CPU will hold it back to some extent, especially in The Witcher, even the latest 7700K overclocked to over 4GHz will do so - check TPU's review, so don't let that put you off too much. What it will do, is help the lowest framerates. As soon as you can, I think you should upgrade that CPU to a 7700K and overclock it.
Personally, I think you'll be fine with a 1080 which will save you a wad of cash that you could spend towards a CPU upgrade.
2,012 (0.36/day)
Heart of Eutopia!
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
hat
Enthusiast
21,744 (3.33/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Eh, just overclock the 3570. You can probably get another 1000MHz out of it. If you can't reach 4.4, 4.2 or even 4.0 will still be a nice boost.
359 (0.09/day)
Motherboard MSI B350 Tomahawk Arctic
Memory 4x8GB Corsair Vengeance LPX DDR4 3200Mhz
Video Card(s) Gigabyte 6700XT Gaming OC (2.80Ghz core / 2.15Ghz mem)
Storage Corsair MP510 NVMe 960GB; Samsung 850 Evo 250GB; Samsung 860 Evo 500GB;
Display(s) Dell S2721DGFA; Iiyama ProLite B2783QSU;
Case Cooler Master Elite 361
Power Supply Cooler Master G750M
Upgrading your current video card setup on a 1080p display is pointless unless you're trying to play something that completely fails to utilize the SLI and that pisses you off ^^
I'd also recommend waiting a bit till some good motherboards drop and get a Ryzen 5 + some fast memory.
212 (0.04/day)
Germany
System Name Steam Deck LCD
Processor AMD Van Gogh 4-Core 8-Threads
Motherboard Stock
Cooling Stock + MX4 Thermal Paste
Memory 16GB DDR5 5500
Video Card(s) AMD Van Gogh 8 CUs
Storage 512GB NVMe + 512GB MicroSD
Display(s) 7" 800p | LG 34" Ultrawide + 27" both 75Hz | 58" UHD TV
Case Stock + Airflow Backplate (5C less and a lot less noise)
Audio Device(s) Jabra Elite 65T Bluetooth Headphones | 50W Sound Bar
Power Supply Stock
Mouse Logitech MX-Master 3 Bluetooth | PS4 controller (because gyro)
Keyboard Logitech MX-Keys Bluetooth
Software SteamOS
CPU: i5-3570k
Honestly when going for the 1080Ti you have to have a pretty badass system. If you really wanna do it, you will need to OC at least to 5GHz and still have some (but very minute) bottlenecking. The best solution would be to go i7. I know this makes no sense and I am no fan of i7s for gaming but that card was made for 4K, which makes it hard for me not to think of i7 to run it without bottlenecking anything. The Ryzens will do a great job too, but atm, they are not so well optimized and may lead to slowdowns, especially on 1080p.
Given what I said above, I would advice going with the 1080Ti. Try to OC the CPU as much as you can, and if possible the RAM too. You will minimize any bottlenecking this way. Keep in mind that you will have no SLI issues and the 1080Ti will play much much better than the 2x970s you have rn.
