- Sep 27, 2014
- 550 (0.15/day)
I had used CPU-Z on those mother boards - Dell Precision T5500 (X39) and T7610 (X79) that use ECC RDIMM. The CPU-Z cannot read the SPD on those memories.
I have tried AIDA too, but it doesn't see the SPD either.
Also, on the T7610, I think it also I am not sure it it reads the number of channels right. The BIOS shows 4 channel enabled, but the CPU-Z still shows 2 channel. Or this can be changed (from BIOS value) by Windows's drivers?
T7610 report:
https://valid.x86.fr/wyr2ss
Any ideas?
Ah, and on that linked page, the style "Big CPU", only one of the video cards is shown in the "forum banner" pic. Can it be changed to show both, or at least choose which one will be shown?
LE: OK, I have "solved" the dual versus quad channel mystery.
1. The BIOS shows "channels used" not the actual memory mode. Well when it shows "4 channels" for 4 memory sticks, it's normal, because... That's what it is. But I have 2 CPU's. So it was only 2 slots per CPU (and hence per memory controller). Normal to be able to do only 2 channel per controller.
2. I have harvested the RIMM memory from my other Dell Precision - same capacity per stick, but 2 rank instead of 1 rank and slower speed. Installed them in the farthest white slots, moved the 1 rank sticks in the closest slots (per Dell manual instructions), for a total of 8 sticks (64GB) and... voilĂ le carcalac: Quad channel enabled.
https://valid.x86.fr/hgge83
Still no SPD readings.
T7610 report:
Any ideas?
