Crazy gigabyte X570 Master issue
john066
3 (0.00/day)
I've built my own computers for years and worked with many gigabyte motherboards but I've never seen this kind of problem before. Everything works great until i flash the main bios to a newer version. Then it fails to load windows. However the back up bios works just fine, so it clearly not a hardware issue. I can access the main bios and change any settings but It won't load windows. It states there is no boot drive available. I thought this may have been a defective board as did gigabyte when i put in a ticket for technical support, However i got a replacement board from amazon as i thought the first was broken and now the replacement board is doing the exact same thing. It has to be a software option somewhere, but i can't for the life of me figure out what it is and have searched everywhere. Does anyone have any ideas? I've tried re-flashing the bios, clearing the CMOS, loading optimized defaults ect. but to no avail. The only post code is AA, which apparently stands for reserved whatever that is. Any help would be appreciated.
Thank you.
277 (0.13/day)
System Name Cheapskate Maximus
Processor Xeon W3680 @ 3.99Ghz [133x30] [1.375v]
Motherboard HP Z400 Rev 2
Cooling Alpenfohn Brocken v1
Memory 3 x 4GB DDR3-1600
Video Card(s) Sapphire RX570 Nitro+
Storage 240GB WD SSD, 6 x 2TB HDD
Display(s) 27" iiyama XB2783HSU AMVA+
Case AeroCool
Power Supply HP 600w Bronze (Delta)
Keyboard Gots keys
Software W10 x64
It might just not be detecting the boot partition from the old bios/install. If you got a USB with Windows on it you could boot to repair mode from it and try fixing the boot records etc.
There's a few ways to fix it either using the Windows boot USB/Disc or third party bootable software:
newtekie1
Semi-Retired Folder
28,473 (4.08/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
My suggestion: Return the board for a different model and avoid Gigabyte at all costs. Their products are low quality junk and their customer service is horrible.
17,942 (2.44/day)
Thank you.
Ok, we need a lot more details.
What's your boot drive/interface?
Did you install Windows using GPT or MBR?
Have you disabled CSM?
Can you see the OS drive in the UEFI when you get teh message that there's no boot drive?
Please...
Go spread your FUD somewhere else.
The X570 Master is a really nice board and I have had exactly ZERO issues with it.
silentbogo
5,586 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
First, fill out your spec, so we won't have to speculate or guess.
Second, make sure that your boot options are the same as they were before: check if CSM mode was enabled and whether you have legacy install on MBR, or if you have proper UEFI Windows install. Then check what's going on with secureboot.
Third, and this is very rare, but I've encountered an issue with NVidia GPU drivers on a couple of AM4 boards this summer. Basically if you have an UEFI Windows 10 installation, and an NVidia 10- or 20-series card, then there is a small chance to encounter a black screen at boot (the OS loads, but there is no image). Reinstalling Windows in legacy mode (MBR partition table) solved the problem for my customers. I think it was a 1903 glitch, which I never found a proper solution for. Though, it boots fine the first time, when you have a generic GPU driver installed, or if you switch to Safe mode and delete the driver.
Their X570 boards are one of the best on the market, and x570 Master is definitely a good board (probably in top-10 of the current 570 lineup).
Don't believe me, read some reviews.
1,168 (0.21/day)
Austria, Europe
System Name Bang4Buck
Processor AMD Ryzen 9 5900x
Motherboard MSI PRESTIGE x570 CREATION
Cooling Fractal Design Celsius S36
Memory 32Gb 4400Mhz Patriot Viper Steel(Samsung B-die) @ 3800Mhz 16-16-16-32-48-1T @ 1.38v
Video Card(s) MSI RTX 3080 Ti Suprim X
Storage Adata SX8200Pro 512Gb/2x Crucial P1 1Tb/Samsung 840 EVO/6Tb Raid -HGST Enterprise/2x IronWolf 8Tb/
Display(s) Samsung UE49KS8002 4K HDR TV (US - 9 series)
Case Fractal Design Define R6 Black Usb-C
Audio Device(s) HDMI out to Denon X4400H reciever, 2x Dali Zensor 7, Dali Zensor Vokal, 2x Dali Zensor 1, Yamaha Sub
Power Supply Seasonic Prime Ultra 750W
Mouse Logitech G305 Lightspeed
Keyboard Logitech K520
Software Windows 11 Pro x64
Benchmark Scores https://www.3dmark.com/spy/26216445
What device are you booting from? M.2, Sata,...?
john066
3 (0.00/day)
Thanks for all the replies. I am using a 2.5 samsung 960 EVO, SATA drive for my boot drive. Yes, the main bios sees the drive and i can select it to load from. If i select it i get a black aorus screen that just spins constantly. If i don't go into the bios i get a black screen that says no boot device detected please insert boot device. I have tried with and without CSM enabled. The working back up bios has it enabled. windows is installed as MBR... Should i try reinstalling it? I did a fresh install recently so its no big deal to reinstall again lol
Everything works fine in the back up bios so i'm guessing its not hardware but an options in either windows or the BIOS but specs are
Gigabyte X570 master
Ryzen 3800X
Gskill 16 GB DDR4 3200mhz Cl14
MSI RTX 2080 TI Gaming X Trio
Samsung 4TB 2.5 860 EVO
Corsair 1200AX
17,942 (2.44/day)
Windows 10? If so, which build?
Which UEFI release are you trying?
Considering it's a SATA device, CSM and GPT doesn't make any difference.
The Aorus screen with the spinning "balls" is the Windows loading screen, so if you're rebooting here, it might simply be that you're preventing a Windows update from being applied and thus, never get into Windows. This is a "new" feature in Windows 10, where the UEFI can contain a Windows loading image instead of the Windows logo.
Obviously if you get in to Windows using the UEFI in the backup chip, this might not be the case.
Can't think of any setting that would cause this kind of behaviour on a SATA drive. Might just be Windows detecting it as a new device somehow and taking longer than normal to boot. How long have you waited when you see the spinning balls? Maybe give it 10 minutes and see if anything changes?
Low quality post by eidairaman1
42,984 (6.72/day)
Ugh win10 ftl...
Low quality post by thesmokingman
3,817 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
No love for the Gigfail? Hehe, I agree 100%.
636 (0.14/day)
Technical Tittery....
System Name "IBT 10x Maximum Stable"
Processor Intel i5 4690K @ 4.6GHz -> 100xx46 - 1.296v
Motherboard MSI MPower Z97
Cooling Corsair H100i + 2x Corsair "HP Edition" SP120's
Memory 4x4GB Corsair Vengence Pro 2400mhz @ 2400MHz 10-11-12-31-1T - 1.66v
Video Card(s) MSI Gaming GTX970 4GB @ 1314 Core/1973 Mem/1515 Boost
Storage Kingston 3K 120GB SSD + Western Digital 'Green' 2TB + Samsung Spinpoint F3 1TB
Display(s) Iiyama Prolite X2377HDS 23" IPS
Case Corsair Carbide 300R
Audio Device(s) Rotel RA-04/Cambridge Audio Azur 540R + B&W DM302/Cerwin Vega AT12 / Sony MDR-XB700 & FiiO E5
Power Supply EVGA NEX650G + Silverstone Extensions
Mouse Always failing me....
Keyboard Endlessly broken.....
Software Windoze 7 Pro 64-bit/Windoze 10 Pro
Benchmark Scores I had some of these once upon a time? Old age has seen me misplace them....
As already stated; returning the board and seeking a replacement - be it from Gigabyte again or another vendor - is the right course of action. Any arguing of the awersomeness, of lack thereof, is just distractions and isnt needed.
@infrared Thanks!
4,994 (0.70/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
Thread cleansed, please focus on helping OP.
1,186 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Hmmm have you enabled fast boot in the original bios? I do remember something with a winboot setting, try to go into msconfig and se if theres something written in boot
21,589 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
@infrared Thanks!
I disagree. This does not sound like a board issue, especially if one firmware works and another does not. If anything, this strikes me as a uefi boot order issue, maybe fastboot or secureboot related. A new board will not help.
17,942 (2.44/day)
Have you checked the storage boot order? You might want to try legacy over UEFI to see if that makes a difference.
john066
3 (0.00/day)
This is not a board issues and it has happened on TWO x570 masters. It is either a Bios setting or a windows setting.
I have tried legacy over UEFI and it makes no difference...
Fast start is not enabled in the BIOS and I tried turning it off in widows, it makes no difference...
Does anyone else have any ideas? I've tried all that i can think of and all the suggestions here.
tabascosauz
8,197 (2.35/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Have you any spare drives that you can quickly install Windows on just for testing purposes? What does the bootmenu in BIOS display right now? Does it see the drives, or just one Windows Boot Manager option?
I've run into a number of times where either the UEFI partition is corrupted, or Windows 10 wasn't smart enough to install a new one when putting in a new drive so the UEFI boot partition was still on the old drive.
In that event, Asus boards automatically boot into BIOS, but I suspect GB doesn't do the same.
if you boot to the Windows installer, you can use advanced repair options to see if it can fix the boot partition. Though, in my experience, this works much better with MBR (legacy) installs than GPT (UEFI), where it just doesn't work.
If you have more than one drive, unplug everything save for the one that you want the OS to go on.
newtekie1
Semi-Retired Folder
28,473 (4.08/day)
Indiana, USA
We've given you the suggestions. It is a board issue, whether you want to admit it or not. It might not be a hardware issue, but it is definitely an issue with the motherboard caused by the firmware.
Again, typical Gigabyte quality. Their firmwares have bricked their hardware in the past too.
So either return the board and get something different, or don't update the BIOS.
Xspeed_
2 (0.00/day)
Hello, I own an ITX version of Gigabyte X570 and ran into the same exact problem.
The motherboard was causing MBR to get corrupted on all connected SATA disks. As reported by GDisk, GPT was ok, while MBR was corrupted.
M.2 disks on the other hand were unharmed.
In the end it turned out to be a bug in the BIOS, as it happened only on the new version F20. Going back to F11 resolves the issue.
17,942 (2.44/day)
Wow, that's interesting. Never heard of a bug like that before. I guess a lot of people weren't affected as their boot drive was GPT, rather than MBR.
Low quality post by Adam Krazispeed
128 (0.04/day)
System Name Ryzen 5800X-PC / RyzenITX (2nd system 5800X stock)
Processor AMD Ryzen 7 5800X (atx) / 5800X itx (soon one pc getting 5800X3D upgrade! ;)
Motherboard Gigabyte X570 AORUS MASTER (ATX) / X570 I Aorus Pro WiFi (ITX)
Cooling AMD Wrath Prism Cooler / Alphenhone Blackridge (ITX)
Memory OLOY 4000Mhz 16GB x 2 (32GB) DDR4 4000 Mhz CL18, (22,22,22,42) 1.40v AT & ITX PC's (2000 Fclk)
Video Card(s) AMD Radeon RX 6800 XT (ATX) /// AMD Radeon RX 6700 XT 12GB GDDR6 (ITX)
Storage (Sys)Sammy 970EVO 500GB & SabrentRocket 4.0+ 2TB (ATX) | SabrentRocket4.0+ 1TB NVMe (ITX)
Display(s) 30" Ultra-Wide 21:9 200Hz/AMD FREESYNC 200hz/144hz LED LCD Montior Connected Via Display Port (x2)
Case Lian Li Lancool II Mesh (ATX) / Velkase Velka 7 (ITX)
Audio Device(s) Realtek HD ALC1220 codec / Onboard HD Audio* (BOTH) w/ EQ settings
Power Supply 850w (Antec High-Current Gamer) HC-850 PSU (80+ gold certified) ATX) /650Watt Thermaltake SFX (ITX)
Mouse Logitech USB Wireless KB & MOUSE (Both Systems)
Keyboard Logitech USB Wireless KB & MOUSE (Both Systems)
VR HMD Oculus Quest 2 - 128GB - Standalone + Oculus link PC
Software Windows 10 Home x64bit 2400 /BOTH SYSTEMS
Benchmark Scores CPUZ - ATX-5800X (ST:670) - (MT: 6836.3 ) CPUZ - ITX -5800X (ST:680.2) - (MT: 7015.2) ??? same CPU?
no thats MSI I know cuz iv had many MSI boards fail/ over 10+
My gigabyte boards have never had any issues never
the bios is reset to default after a flashed bios update
if u had a UEFI MODE INSTALL OS and OR HAD the AMD CPU fTPM ENABLED / THIS NEED TO BE RE-ENABLED FOR WINDOWS TO BOOT PROPERLY ALONG WITH SETTING THE BOOT ORDER BACK TO THE UEFI BOOTING DRIVE\ OR "WINDOWS BOOT MANAGER". DUH! APPARENTLY U HAVEN'T BUILT ENOUGH PCS IN UEFI MODE!!
i had an AM3+ 990fx Gigabyte board with a 20gbps nvme supported m.2 drive slot ( no isssues)
all AM4 mb's i cuurently have...
1: X570 Aorus Master ( 2x One is mine and the other is one i built for my dad) so two of these)
2: X570 I Aorus Pro WiFi ( I HAVE 2x of these)
3: B450 Aorus Pro M mATX MB (for a 2600X)
Have Not HAD any issues with any of these MB's
and iv even abused them
besides all mb's have been junk ever scence they were made in "CHINA" NEED TO GO BACK TO BEING MADE IN "TAIWAN" OR BETTER YET "MADE IN TEH USA" as it SHOULD BE!!!! then no issues will ever be on any mb mad in USA or Taiwan!!!
Let me guess, the "GIGABYTE I AORUS PRO WiFi"???? I have two of these and never had this isssue!!!! i even had a hdd on my itx sata.. too slow so i just slapped in a few 1-2tb nvme ssd;s removed my hdds and saif F**k it!!!
SATA IS SO OUTDATED AND SLOW, GET WITH THE TIMES AND JUST GET NVME .... I DONT EVEN USE SATA ANY MORE!!!!
exactly a new board will be worse ( no boot and need reinstall and re-activation or possibly a new COA / Genuine license/ the digital lisence is attached to ur specific mb if changed u will not have a legit windows install. case in point!
im on f20b and no issues on all mbs i have (except b450 mb its different revision)
1,186 (0.27/day)
Denmark
Case Custom builds
Audio Device(s) -
I am testing the F20 bios right now but only using m.2 disks - but thats an odd issue
5,847 (0.80/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
@john066 did you ever get this issue sorted and if so, how? Can you confirm if you were using BIOS F20 when you experienced this?
@jesdals M.2 SATA or M.2 NVMe drives?
1,186 (0.27/day)
Denmark
Case Custom builds
Audio Device(s) -
Corsair MP600 1TB and Gigabyte Aorus 2TB Pcie 4.0 and Samsung Evo 960 1TB
5,847 (0.80/day)
Ikenai borderline!
