creative zen vision m mp3 player dead
1,037 (0.17/day)
System Name mine
Processor 2600k@5.2ghz 1.41 vcore
Motherboard asrock z77 OC Formula
Cooling pa120.3, apogee HD, mcp655 pump
Memory 16gigs ddr3 1600mhz sammy's @ 1886
Video Card(s) evga gtx470 under water on a seperate loop
Storage Crucial M4 128gig SSD
Display(s) HP 2511x 25inch led
Case none ATM
Power Supply PC Power & Cooling 750watt seasonic x-1250watt(dead)
Software win 8 pro 64bit
well after a happy short life it died.
i was using it all day at work yesterday worked fine, went to use it on the bus ride home and it wouldn't power up. i figured i forgot to turn it off and the battery died. well when i got home i put it on the charger. it powered up and started charging. then about 10 minutes later, i heard a weird squealing sound. once i tracked the noise down, it was my mp3 player.
i picked it up to unplug it and see what was wrong, the dam thing was pretty hot. not burning hot, but hotter than its ever gotten. now its a brick.
i contacted creative support(what a joke,think dell only worse) they were no help. i dont have the receipt so no warranty.
i recently moved and threw away the box, receipt was in it. now i'm screwed
arghh just ranting srry
PuMA
724 (0.11/day)
Finland
Processor lapped C2D e6850, 3600mhz
Motherboard ASUS P5N32-E SLI (680i SLI)
Cooling NOCTUA NH-U9, 3 2x120mm 1x180mm case fans
Memory 6GB A-DATA vitesta DDR2 900mhz (2x1gb + 2x2gb)
Video Card(s) LEASTEK GTX 260 (701/1408/1105)
Storage SAMSUNG F1 640GB SATAII/SEAGATE 250gb SATAII
Display(s) SAMSUNG 226BW 1680x1050 2ms
Case ANTEC three hundred
Audio Device(s) ASUS SupremeFX, SONY surround AMP
Power Supply XION 630W
Software VISTA ULTIMATE x64
Benchmark Scores 3dmark06:15126 (701/1408/1105) vantage: 11698
and what do we learn?? allways keep ur receipts. I feel ur pain mate, if u look at creative forums, theres alot of ppl with dead vision M's. i quess the more advanced these gadgets come, the more problems theyhave
2,818 (0.45/day)
US
Processor Intel Q9400
Motherboard asus p5q-pro
Cooling Ultra120
Memory 6GB ddr2
Video Card(s) NVS 290
Storage 3TB + 1.5TB
Display(s) Samsung F2380
Case Silverstone Fortress FT02B
Audio Device(s) Creative X-Fi
Power Supply 750W PC P&C
Software win 7 ultimate 64bit
is battery removable? something probably melted inside. did you notice any weird smell from it?
1,037 (0.17/day)
System Name mine
Case none ATM
not the end of the world
i sold a rifle scope of mine on the same day my zvm died. took those profits and bought a new zen vision w, the one with a 4.3 inch wide screen.
i live in the city and commute 1 hour on the bus each way. so my media players get used. i really need 1 to keep from being bored to tears on my bus rides.
those media players use 1.8 inch hard drives. anyone know if there is a usb adapter to use the hard drive as extra storage on my pc?
other option would be, buy a new 1 at walmart(where i bought it at originally) then put my old one in the box and return it. lol just kidding, that would be unethical.
6,560 (1.06/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
does it power up at all? not even to the boot screen?
i mean i had a problem that somehow the firmware got corrupt all i had to do was to install it again good job to as it would have been a very expensive paper weight
1,037 (0.17/day)
System Name mine
Case none ATM
no power
no boot nothing. when hooked up to usb power the blue light comes on but nothing else.
when its not hooked to any power the blue light blinks 5 times when i try to turn it on.
the screen never lights up
6,560 (1.06/day)
System Name Vintage
Case Generic
Software Windows 7
have you tried booting it up to menu screen - with my creative zen i take the battery out - hold the power button on and then insert the battery again - then this makes it boot to, I'll call it BIOS (have no idea what else to call it)
DaMulta
My stars went supernova
16,168 (2.47/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
I have smashed, dropped in water, dropped down the stares, and who all knows what else I have done to my Sony Mini Disc payer.
Guess what? It still works!!!
Sony Mini Disc FTW
1,037 (0.17/day)
System Name mine
Case none ATM
the battery
battery is internal and i cant find my micro screw driver. but yes as soon as i can it abd remove the battery i will.
assuming i ever get it working again i'll prolly sell it.
6,560 (1.06/day)
System Name Vintage
Case Generic
Software Windows 7
good luck bud
Frick
Fishfaced Nincompoop
19,030 (2.83/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Very much luck indeed. :) Report your progress. I have one of those too, and that problem made me kinda worried.. I don't want my baby to die.. :cry:
But I'd really appreciate if you would keep us updated. :toast:
EDIT: Cleaned up spelling a bit. I'm very tired right now.
131 (0.02/day)
Processor AMD Phenom II X4 955 Black Edition
Motherboard Gigabyte GA-870A-UD3 Rev2
Cooling OCZ Vendetta w/Scythe Ultra Kaze 2000RPM Fan
Memory 8 gb Corsair Vengeance 1600mhz 9-9-9-27
Video Card(s) Gigabyte GeForce GTX 570 1280MB Overclocked V2
Storage 3x Seagate Barracuda 1TB
Display(s) 22" Samsung LCD
Case Coolermaster HAF 932
Audio Device(s) Integrated
Power Supply Corsair HX-620 620W
Software Windows 7
I'd say it would probably have been the HDD that died. I don't think batteries squeal at all. :p
I've had my ZVM for nearly a year now, still going strong (fixed the scratches on the screen with superglue and metho, message me for how I did it if you want.)
With regards to the receipt woes, I feel your pain. I've had it happen several times, the last time that happened, I grabbed the attendant by the collar and told him to replace it or I'd violate him with the jagged end of the Xbox. :p (Kidding. I wouldn't really do that.... or would I? :p)
6,959 (1.07/day)
Australia, Sydney
Squealling = DEAD. End of story, a capacitor or choke died. Its irreversable damage so you're basically...screwed...
Fuse-Wire
855 (0.14/day)
Scotland, Far away from normality as possible
System Name The Box
Processor DualCore AMD Athlon 64 X2 2300MHz (11.5x200) 4400+
Motherboard AsRock N 68-S
Cooling Basic 90mm fans
Memory OCZ XTC Platinum 2GB DDR-2 800 SDRAM
Video Card(s) ATI Saphire x1650 Pro Series
Storage Maxtor 6L300R0 (300GB) Maxtors S (250GB)
Display(s) 19" LCD CTX
Case EYE-T
Audio Device(s) Realtek ALC650 @ Intel 82801DB ICH4 - AC'97 Audio Controller [B-0]
Power Supply 600W colors-IT super quiet
Software Microsoft 7 Ultimate
bit of an unlucky one if you ask me, the guys are right keeping your receipt would have been a brainy idea. mind you i bought an Xbox bout 2 year ago, flung the box n receipt away and two days later the HD screws up, not being able to swap HD's cos of Microsofts HD key. so i bought another, this time a crystal, this time i still got the box n receipt!!
steiner666
110 (0.02/day)
USA
System Name Ubelsteiner Rig
Processor Intel Q9550 @ 3.5ghz
Motherboard Asus P5E-VM HDMI
Cooling Zalmann 8700
Memory 4x2GB G.Skill DDR2-1000
Video Card(s) EVGA GTX570 (900/1600/2000)
Storage 2x250gb WD Caviar in RAID-0 (primary), 1x WD 1TB green (storage)
Display(s) Mitsubishi 60" 3D DLP TV
Case In-Win Dragonslayer
Audio Device(s) Creative X-Fi XtremeMusic
Power Supply Antec EarthWatts 650w (+12v1: 22A,+12v2: 22A,+12V3 25A)
Software Win7 Ultimate x64
i love my Zen V:M. hope i never have your problems. On thing you may, or maybe not, want to try is buying a travel charger for it and try charging it from an outlet instead of USB (which is how i'm assuming you charge it since they only come with a USB cable) i've talked to several ppl who had "dead" Zens and told them to try this and it was able to pull their Zen out of its coma state. Of course this only applies if your Zen is dead on power, because it has to have so much of a charge for it to communicate with your computer on USB and charge. it's weird, but try it. And as far as buying a new one and returning your old one in the new ones box... pshh, go for it. i've done it a couple times. the stores get refunded and Creative gets their f***** up product back to try to fix and sell as a refurb. It's the same as if you wouldnt have lost your receipt.
