Crosshair V Formula performance (bios settings)
1,098 (0.16/day)
System Name Beaver's Build
Processor AMD Ryzen 9800X3D
Motherboard Asus TUF Gaming X670E Plus WiFi
Cooling Corsair H115i RGB PLATINUM 97 CFM Liquid
Memory G.SKILL Trident Z5 Neo DDR5-6000 CL30 RAM 32GB (2x16GB)
Video Card(s) NVIDIA GeForce RTX 4090 Founders Edition
Storage WD_BLACK 8TB SN850X NVMe
Display(s) Alienware AW3225QF 32" 4K 240 Hz OLED
Case Fractal Design Design Define R6 USB-C
Audio Device(s) Focusrite 2i4 USB Audio Interface
Power Supply SuperFlower LEADEX TITANIUM 1600W
Mouse Razer DeathAdder V2
Keyboard Corsair K70 RGB Pro
Software Microsoft Windows 11 Pro
Benchmark Scores 3dmark = https://www.3dmark.com/spy/51229598
i have come up with a short list of critical settings for optimal performance thus far (1 day of use) on the Crosshair V Formula,
disable C1E, Cool'N'Quiet, C6 state, and also change the default setting of Enabled for ECC (ram option) to Disabled.
this will net you a consistent frequency for the CPU with the added benefit of the best AHCI performance you can get (especially SSDs). For some reason the Crosshair V Formula defaults to using ECC for the ram settings, which really hurts performance... after changing it to disabled my overall performance increased...
there may be more options that are just as critical for a solid and consistent performance, but this is the most important i have encountered thus far
4,117 (0.57/day)
System Name RiseZEN Gaming PC
Processor AMD Ryzen 7 5800X @ Auto
Motherboard Asus ROG Strix X570-E Gaming ATX Motherboard
Cooling Corsair H115i Elite Capellix AIO, 280mm Radiator, Dual RGB 140mm ML Series PWM Fans
Memory G.Skill TridentZ 64GB (4 x 16GB) DDR4 3200
Video Card(s) ASUS DUAL RX 6700 XT DUAL-RX6700XT-12G
Storage Corsair Force MP500 480GB M.2 & MP510 480GB M.2 - 2 x WD_BLACK 1TB SN850X NVMe 1TB
Display(s) ASUS ROG Strix 34” XG349C 144Hz 1440p + Asus ROG 27" MG278Q 144Hz WQHD 1440p
Case Corsair Obsidian Series 450D Gaming Case
Audio Device(s) SteelSeries 5Hv2 w/ Sound Blaster Z SE
Power Supply Corsair RM750x Power Supply
Mouse Razer Death-Adder + Viper 8K HZ Ambidextrous Gaming Mouse - Ergonomic Left Hand Edition
Keyboard Logitech G910 Orion Spectrum RGB Gaming Keyboard
Software Windows 11 Pro - 64-Bit Edition
Benchmark Scores I'm the Doctor, Doctor Who. The Definition of Gaming is PC Gaming...
776 (0.13/day)
Processor Ryzen 7 5700X3D
Motherboard Asrock B550 PG Velocita
Cooling Thermalright Silver Arrow 130
Memory G.Skill 4000 MHz DDR4 32 GB
Video Card(s) XFX Radeon RX 7800XT 16 GB
Storage Plextor PX-512M9PEGN 512 GB
Display(s) 1920x1200; 100 Hz
Case Fractal Design North XL
Audio Device(s) SSL2
Software Windows 10 Pro 22H2
Benchmark Scores i've got a shitload of them in 15 years of TPU membership
Howcome C1E decreases performance? Do you disable virtualization also?
499 (0.10/day)
System Name Multipurpose desktop
Processor AMD Phenom II x6 1605T @ 3.75Ghz , NB @ 2.5
Motherboard Gigabyte 990FXA-UD3 (rev 1.0)
Cooling Prolimatech Megahalems Rev. C, 2x120mm CM Blademaster
Memory Corsair Vengeance LP (4x4GB) @1666Mhz 9-9-9-20-24 1T
Video Card(s) ASUS Strix R7-370 4GB OC
Storage 2x WD Caviar Black 500GB Sata III in RAID 0
Display(s) Acer S211HL 21.5" 1920x1080
Case Cooler Master Centurion 534+, 3x 120mm CM Sickle Flow
Power Supply Seasonic X650 Gold
Software Windows 7 x64 Home Premium SP1
C1E and CnQ can cause voltage instability at high overclocks, which causes cpu instability, which causes errors.
