Crucial BX500 Overheating
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
I am using four 120GB BX500 SSDs in RAID0 as cache in my UnRAID server. Problem is, after my Plex server acquires content and writes it to the UnRAID server the cache drives start getting toasty real quick. The SMART data shows the drives are failing now which causes all sorts of alerts. I'm using them in this device (I didn't pay $80 for it, only $30 lol): https://www.newegg.com/p/N82E16816215222 which has fans so I don't really know how to further cool the SSDs! I think the issue is the SSDs are plastic so the fans are cooling the case but not the actual SSD internals. Any suggestions?
4,814 (0.96/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
Ahhzz
Super Moderator
9,059 (1.47/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
I'd definitely see how I could mount another fan, maybe perpendicular to the pair inside. My SSD and NVMe devices definitely show me more heat than my SATA drives do, but that's anecdotal. One reason I didn't try moving to removable trays for SSD drives was concerns for their heat level, and my belief that the manufacturers might not be anticipating those levels.
6,881 (1.45/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Fans do wonders. Maybe leave the case door open too.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I've used that enclosure before, those 40mm fans are pretty much useless. They move really no air at all.
I've got two 240GB BX500 drives in RAID1, and have no issues with heat during writing, but I have them in the open space of my case. You'd probably be better off just letting them dangle inside the computer case with the good airflow from that than stuffing them in the closed off enclosure.
Another option would be to just lay a 120mm fan on the top of the enclosure pointing down through the vents to push more air through the enclosure. But I don't know how much good that would do.
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
Crack open the plastic cases of the SSDs and run bare silicon.
1,237 (0.28/day)
System Name Sierra
Do you think airflow will help given that as far as I can tell from reading reviews of these SSDs that there are no thermal pads actually moving heat from the guts of the drive to the casing?
Solaris17
Super Dainty Moderator
27,198 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
I think I have these in my fail over server at home. I can check my temps as well because I also think I remember them getting warm. We can compare notes. With that said though I have done a few migrations and while they get hot they dont seem to throttle etc on data. Though I dont know the TJ max on the controller ICs I have no reason to believe they are dangerously hot.
yup. RAID1 120gb BX500. This is under normal load.
131168
This was the hottest it got while I was beating it up with CDM. (I let the test complete, just kept the highest)
131169
have to tag you because it auto merges posts @shovenose
looks like the silicon motion controller it uses according to the SM tech PDF says 70C
131171
Im assuming thats sustained. so bursts over probably arent a huge deal.
now apparently the BX500s include "adaptive thermal technology" which I imagine is a fancy way of saying throttling, but I didnt see that at over 70C and honestly that was the absolute worst temp during the whole test and it only managed it for a few seconds.
