Custom Water Block Drops NVIDIA GeForce RTX 5090 GPU Temperatures Down by 30°C
AleksandarK
2,781 (1.02/day)
German overclocking specialist Der8auer has showcased a custom water block for NVIDIA's flagship RTX 5090 Founders Edition, achieving a remarkable 30-degree Celsius reduction in core GPU temperatures. The prototype copper cooling solution demonstrated peak operating temperatures of just 43.8°C, compared to the stock cooler's 73.8°C under identical testing conditions. The design features an all-copper construction with a substantial 14 mm-thick cold plate, engineered specifically for optimal thermal transfer from the GB202 die. While maintaining the dual-slot form factor of the original Founders Edition cooler, the water block incorporates multiple cooling channels beneath a transparent top panel that reveals the coolant flow.
Memory temperatures also significantly improved, dropping by 38 degrees Celsius below stock measurements. Despite its impressive thermal performance, the prototype faces several engineering challenges. The team was constrained by the graphics card's display output ribbon cable, which prevented a more compact design closer to the actual PCB dimensions. Additionally, the Founders Edition card's unique split PCIe finger design presented structural concerns that require additional reinforcement before any potential commercial release. Der8auer's prototype prioritizes function over aesthetics, omitting common features like RGB lighting in favor of raw cooling performance. The water block's industrial design reflects its proof-of-concept nature, though the transparent top panel offers practical utility for monitoring coolant flow. While no retail release timeline has been announced, Der8auer indicated that addressing the PCIe slot structural support issue remains a critical milestone before any commercial version could be considered.
2,208 (1.05/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
And how much does the block weigh? Definatley going to need some support with that on your card.
536 (0.16/day)
System Name My Addiction
Processor AMD Ryzen 7950X3D
Motherboard ASRock B650E PG-ITX WiFi
Cooling Alphacool Core Ocean T38 AIO 240mm
Memory G.Skill 32GB 6000MHz
Video Card(s) Sapphire Pulse 7900XTX
Storage Some SSDs
Display(s) 42" Samsung TV + 22" Dell monitor vertically
Case Lian Li A4-H2O
Audio Device(s) Denon + Bose
Power Supply Corsair SF750
Mouse Logitech
Keyboard Glorious
VR HMD None
Software Win 10
Benchmark Scores None taken
It was a prototype. If it ever reaches production, it will loose a lot of weight.
FreedomEclipse
~Technological Technocrat~
24,444 (3.76/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Would I be right in saying that not having some cooling fins milled out here is a little bit of a missed opportunity for extra heat dissipation? Its such a empty wide open space and something could have been done with it albeit adding to the overall cost but then again this is a premium product anyway and if youre buying a 5090. Youre hardly going to be strapped for cash.
1,796 (0.45/day)
Like Kohl said, it's a prototype not the final product one can buy.
420 (1.58/day)
System Name Kuro
Processor AMD Ryzen 7 7800X3D@65W
Motherboard MSI MAG B650 Tomahawk WiFi
Memory Corsair DDR5 6000C30 2x48GB (Hynix M)@6000 30-36-36-76 1.36V
Video Card(s) PNY XLR8 RTX 4070 Ti SUPER 16G@200W
Storage Crucial T500 2TB + WD Blue 8TB
Case Lian Li LANCOOL 216
Power Supply MSI MPG A850G
Software Ubuntu 24.04 LTS + Windows 10 Home Build 19045
Benchmark Scores 17761 C23 Multi@65W
Beautiful piece of kit.
Probably not enough to matter even if you milled some fins in and pointed a fan at it, and I for one would like to see some fancy 2000's classic videocard renders on there. :p
FreedomEclipse
24,444 (3.76/day)
Hong Kong
Doubtful. Its increased surface area and if you have decent airflow. There isnt a reason why it couldn't help dissipate some of that heat
1,145 (0.19/day)
Berkshire
System Name Staggered
Processor 7800X3D (XSPC Rasa)
Motherboard MSI B650 Carbon WiFi
Cooling RX360 (3*Scythe GT1850) + RX240 (2*Scythe GT1850) + Laing D5 Vario (with EK X-Top V2)
Memory 32GB (2x16GB) DDR5 6000MHz CL30 1.4v
Video Card(s) XFX RX 6800XT 16GB Speedster MERC319
Storage Samsung 970 EVO Plus 1TB + Crucial P3 Plus SSD 2TB
Display(s) Flatron W3000H 2560*1600
Case Cooler Master ATCS 840 + 1*120 GT1850 (exhaust) + 1*230 Spectre Pro + Lamptron FC2 (fan controller)
Power Supply NZXT C1000 (1000W)
OCing the 4090 seemingly didn't benefit much, if at all, from proper watercooling, am curious about the 5090.
There are people on r/nvidia with waterblocks and no GPU or viceversa :laugh:
Will have to wait for stars to align to get reviews of custom waterblocks plus some extra time for a good sample size.
101 (0.07/day)
According to my own experiment (years ago) in sticking a copper heatsink (with fan) on a copper CPU waterblock with thermal epoxy, no. There is no cooling effect lost.
FreedomEclipse
24,444 (3.76/day)
Hong Kong
