[Case Gallery] Danger Doomsday Device
hockeygod1225
3 (0.00/day)
Specs:
Core i7 920 @ 4.1ghz
Asus Rampage 2 extreme motherboard
12GB gskill 1600 ram
Corsair Memory cooler
BFG EX-1200 watt power supply
Custom Sleeved power supply cables
ATI 5870 graphics card
Danger Den custom Double wide case
2 DDC 3.25 18v Water pumps
2 XSPC Pump tops
UN 3G pump brackets
Primochill 1/2" ID 3/4 OD tubing
Alphacool NexXxoS CPU waterblock
2 Enzotech mosfat waterblocks
Enzotech QPI water block
Ek Nickel full board chipset water block
EK Nickel 5870 full coverage water block
2 raptor 10k rpm hard drives (raid 0)
1 samsung 1.5 TB hard drive
11 Yate loon 120mm UV fans
2 80mm Frozen CPu fans
Rheobus extreme fan controller
2 Fesser Xchanger 480 quad Radiators
8 Fesser extender fan shrouds
Modright fan filters
2 Bitspower x-stations
lite on dvd-rw
4 uv cold cathodes
Customer Acrylic pump stand
Bitspower fittings throughout
Mods:
Sleeved all power supply cables and replaced all connectors. Installed mosfat, qpi, chipset, CPU, and Video card water blocks. Custom made all screw stud for radiator mounting. Designed pedestal pump stand for water pumps.
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
Between the sword & this build,, Not sure why your posting really poor images.
1,072 (0.19/day)
Colorado
System Name not sure yet
Processor R9 3950X
Motherboard Asrock X570 Taichi
Cooling It's a secret for now..
Memory 64GB Vengeance
Video Card(s) 2080Ti FE
Storage 2x 1TB NVME, 3x 500GB SSD, 2TB SSHD
Display(s) Predator 27" 4k 144hz, 55" Vizio 4k
Case Lian Li O11-D White
Audio Device(s) Steel Series Wireless
Power Supply EVGA 1200W
Mouse Glorious D-
Keyboard GMMK 60% Red Box Caps
Software Windows 8.1 Profession x64
Looks great, but the pics are tiny, even when you click on them.
