Dataland Rx5700XT Fan spin at low rpm
archieaang
8 (0.42/day)
Greetings, I recently bought the Dataland RX5700XT Aerial - X card....i have issue with the fan.only 1 of the fan spins but barely(400rpm as per Fan Control & AMD Adrenalin Software)...i tried ramping it up to 100% and disable 0 Rpm but the fan speed maintained 400rpm while the other fan is not spinning..i have tried plugging in the 12v & G wires into molex pin 12v & G and both fan runs at 100% speed...any known solution to this ?
Thanks in advance.
1,687 (1.04/day)
Tel Fyr
System Name 1️Purple Haze 2️Vacuum Box
Processor 1️AMD Ryzen 7 5800X3D (-30 CO) 2️Intel Xeon E3-1241 v3
Motherboard 1️MSI B450 Tomahawk Max 2️Gigabyte GA-Z87X-UD5H
Cooling 1️Dark Rock 4 Pro, P14, P12, T30 case fans 2️212 Evo & P12 PWM PST x2, Arctic P14 & P12 case fans
Memory 1️32GB Ballistix (Micron E 19nm) CL16 @3733MHz 2️32GB HyperX Beast 2400MHz (XMP)
Video Card(s) 1️6900XTXH ASRock OC Formula LM'd & Phanteks T30x3 2️5700XT Sapphire Nitro+ LM'd & Arctic P12x2
Storage 1️ADATA SX8200 Pro 1TB, Toshiba P300 3TB x2 2️Kingston A400 120GB, Fanxiang S500 Pro 256GB
Case 1️Modded MS Industrial Titan II Pro RGB 2️Heavily Modded Cooler Master Q500L
Power Supply 1️Rosewill Capstone 1000M 2️Enermax Revolution X't 730W (both with P14 fans)
Deshroud the card and use 2 120mm fans of your choice (high pressure preferably). Ziptie them together, then ziptie them to the card. Power them off the motherboard as @droopyRO suggested, and make use of the excellent Fan Control software (figure it out). Problem solved.
44,180 (6.80/day)
Start with sticker pics from the card back, also gpu-z screenshot and then go to advanced tab and change it to amd bios and screenshot that please
Thanks in advance.
archieaang
8 (0.42/day)
Did you try to plug those wires in to a fan output on your motherboard and control it with Fan Control - A highly focused fan controlling software for Windows (getfancontrol.com) ? Can you return that card and get another brawi
havent tried. is the header the same ? will give it a shot later. return is not an option as i bought it from facebook marketplace which originally sold as fault no display but after abit of cleaning on the port it did give display. hehe
still trying to figure whether its the gpu sensor or fan faulty. so will give the 2nd option a try but not the 1st option haha
44,180 (6.80/day)
Please get a picture of the white stickers located on the back of the card please. If it's truly Dataland it would be using a TUL/Powercolor bios and not a PCPartner/Sapphire Bios...
While youre at it get a picture of the heatsink with fans please
archieaang
8 (0.42/day)
Product sticker is missing though... I tear everything down to look for the sticker but cant be found.
Yesterday i did flash bios with Dataland Rx5700xt Aerial X Bios
Not sure why GPUz's AMD Bios showing sapphire
Update 1 : remove the whole cooler and tried it on another gpu(xfx rx580 to be precise) and the fan worked. I started to think that maybe its the gpu sensor it self or bios? Any idea for a compatible bios forbthe current card with the info given fron gpuz?
1,687 (1.04/day)
Tel Fyr
That was an advice for the simplest solution possible (plug & play). Because the fan headers are not the same. It's also the best one (solution) in regard to cooling potential and acoustics.
I prefer my deshrouded card's fans to be powered from the cards exclusively, but it involves either butchering the original fan cables for headers, or finding the correct ones elsewhere. Relying on a 3rd party software is not my thing, but a last resort option.
The choice is yours anyway. Cheers
archieaang
8 (0.42/day)
If there's no fix i thibk this might be it.
1,687 (1.04/day)
Tel Fyr
You need to consider there is a large variety of a GPU fan headers out there, as I was talking generally. Eg. all of my 3 cards have a completely different headers.
2,151 (0.35/day)
System Name Ryzen7700
Processor AMD Ryzen 7 7700
Motherboard Asus ROG STRIX B650E-F GAMING WIFI
Cooling NZXT Kraken X62
Memory Patriot Viper Venom PVV532G700C32K (32GB @ 6000CL28)
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Can you share a picture of the PCB? Your card seems to be a "Dataland RX 5700 XT X-Serial Warrior"
Currently you have flashed a X-Serial bios, not sure if it is the correct edition.
See boost speed of 1905 MHz listed in the comment:
https://www.techpowerup.com/vgabios/253263/253263 (Try at own risk)
https://www.techpowerup.com/vgabios/257994/257994 (Comment states X-Serial Demon with 1905 MHz...)
archieaang
8 (0.42/day)
Would gove it a try tomorrow. I have flashed wuite few vbios now but out of curiosity if i were to bricked it i can just reflash old bios with igpu right. Never bricked a card. Hope this wont be the 1st one
Isnt they are all the same with 12V,G,TACH(Sensor),PWM? Because i opened 5 diff card and they all had the same header except for 1 gtx970 had like 5 header
2,151 (0.35/day)
Recovery should be possible, but sometimes the card is bricked so hard it needs an external programmer like the CH341A (v1.7) to fix it.
archieaang
8 (0.42/day)
2,151 (0.35/day)
The bios I provided earlier, are ment for a different PCB (AA02). Dont flash it. It might brick your card.
The bios you flashed earlier seems to be the correct match:
Written on the PCB: 0120 AA01A
Boot message: 113-AA01AM-U06
archieaang
8 (0.42/day)
Actually the bios i flashed were forced flash.. The old one was AA02.. Using v2.9.3... I think the previous owner used a modified bios with SSID AA02
archieaang
8 (0.42/day)
I have consult with a gpu repair specialist. Decide to sent it to him for a troubleshooting. Btw, the card is not booting up this morning(no changes made since last successful boot) so I think sending it out to an expert is the best option. Anyways, Thanks for all the suggestion, information, guides & etc provided. You guys are awesome
