DDR4 Overclock
TAITO
9 (0.00/day)
Hello
I made OC to memory RAM up to 3400Mhz CL 15-17-17-35 2T
from standard 3000MHz CL 15-16-16-35 2T
Now I would like to lower the timings
124307
Which of these timings can i lower more?
dgianstefani
TPU Proofreader
5,208 (2.02/day)
Swansea, Wales
System Name Silent/X1 Yoga
Benchmark Scores Legendary
I doubt you'll be able to achieve much if you've already done an OC. 3000/15 is not Samsung B die so good luck.
TAITO
9 (0.00/day)
My ram memory is a samsung d-die with 1.5V
I would like to lower the timings as much as possible
2,707 (0.74/day)
On The Highway To Hell \m/
Then do that. And test for stability with MemTest64. I recommend 20 loops minimum with 75% of your total GB(so 12GB or 12288MB). If it will pass that with 0 errors it's 100% stable in my book.
There no magic numbers for all sticks of RAM(even the exact same type, brand, etc.). They all vary in how much voltage they require, the frequency they'll run at, and how tight the timings can be to remain stable. The motherboard and CPU play a roll too. Different RAM will run differently on a different motherboard and/or with a different CPU. LOTS of variables.
TAITO
9 (0.00/day)
Okey so i did the test with MemTest64
This is the result
124305
cstkl1
7 (0.00/day)
Malaysia
reduce trtp to 3 since you are running tras 35, tcl 15 and trcd 17
twr try 8 or 10
twcl try 9
trrd_s try 4
tref try 26520 , 32727 or just max it out.
trfc i suppose thats the lowest you can go.
thats about it.
10,932 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
trfc 'if' you can go lower is probably priority, you may be able to get away with a higher TREFI as @cstkl1 mentioned.
10,932 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
I usually don't mess with those unless i have a week of my life to lose...
1,533 (0.39/day)
Grunn
System Name Indis the Fair (cursed edition)
Processor 11900k 5.1/4.9 undervolted.
Motherboard MSI Z590 Unify-X
Cooling Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (T30-120 fan)
Storage 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2546K, Dell P2417H
Case FD Define 7
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Odin Infinity mousepad
Keyboard GMMK Fullsize v2 (Boba U4Ts)
Software Win10 x64/Win7 x64/Ubuntu
Try to pull down RFC and increase REFI.
Other secondaries you want to try to decrease. Tertiaries you maybe can play with but they tend to be very finnicky with little performance difference.
You can use something like the ryzen timing "calculator" to find timings to use as a reference. https://rog.asus.com/forum/showthre...mus-V-Formula-UEFI-OC-Tuning-Guide#post131516 This thread might also be useful even though its for DDR3.
TAITO
9 (0.00/day)
124352
I have restored all timings to the standard auto because a lot of errors appeared in MemTest.
Now I was able to steadily reduce trfc to 310
Before this everything on the settings from the first timing screenshot was not stable,
trfc was set to 480 and in the MemTest program full of errors.
Now I have to lower these timings again. What do you think from which timings to start lowering?
Thank you all for help
cstkl1
7 (0.00/day)
Malaysia
last is tref
trfc should be the 2nd last
3rd last is twtr
trtp should be first
tfaw and trrd simultaneously 2nd
the rest actually doesn't matter
3rd timings u should as those on dual channel but afaik only 4k and above they come to play.
TAITO
9 (0.00/day)
Ok, so now i'm going to lower trfc and increase refi, if I do it will give me more performance?
Which of these timings are secondary and other tertiary?
TRFC : 310 stable
TREFi : 26520 stable
Can I increase it to a higher value other than 32727 ?
(ASRock Timing Configurator does not detect 32727 TREFs while in bios it is set and PC boots windows)
I tried to reduce these values:
trtp: 3
twr: 10
tcwl: 9
trrd_s: 4
but PC does not boot windows and restores factory settings in BIOS
trtp: 8 stable ( reduce more or leave? )
twr: 10 stable ( reduce more or leave? )
tcwl: 13 stable ( reduce more or leave? )
trrd_s: 6 stable ( less than 6 PCs will not start )
124355
Now the timings look like this
So now what to do next?
Please help me
2,707 (0.74/day)
tRFC: As long as you can get it without producing errors.
tREFI: Basically no more than 2x-3x the auto setting is recommended(though you might be able to get away with more than that). There's a mathematical formula to determine that...let me see if I can find it again.
tREFI(JEDEC/auto/default) = 7.8ns = DRAM Frequency(actual MHz, not effective "MHz" or MT/s, it's whatever CPU-Z says, or for example 3400 ÷ 2 = 1700MHz) x 7.8
So...
1700MHz x 7.8 = 13260 tREFI(JEDEC/auto/default/7.8ns)
13260 x 2 = 26520
13260 x 3 = 39780
You should also consider tweaking your voltages. That can help a lot. Here's another good guide.
TAITO
9 (0.00/day)
Thank you very much MrGenius
Currently voltage is 1.5V
VCCSA 1.2V
VCCIO 1.2V
TREFI 39780 stable
SiRoCu
4 (0.00/day)
Before OCing RAM you should choose the RAM slot as the standard first, for 2 sticks will be A2 and B2 DIMMs.
For timing try tREFI at the max value 65535 it reduce access time and improve READ and WRITE, this mean COPY also.
10,932 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
can you go lower than 15-17-17? have you tried 15-16-16? 15 all with the new voltages on SA and IO?
Also, have you tried flipping the timings? go 16-15-15 or 17-16-16? some kits perform better with this configuration.
TAITO
9 (0.00/day)
124458
124459
trefi 39780 vs trefi 65534
Now I want to lower the tertiary timings
Can somebody help me ?
Thank you
cstkl1
7 (0.00/day)
Malaysia
based on the asrock timing configurator list i would do
10, 327, 6,4,8,3,8,16,9
btw u wont see much of a difference with this
twcl will see slightly better latency and bandwidth
trefi, tfaw and trf are the major ones
rest more to stabilizing.
are you using bdies??
u should try 16,16,16,36 with twcl 9 first
TAITO
9 (0.00/day)
15-16-16
16-15-15
16-16-16
17-16-16
PC will not start
My ram is Samsung D-DIE
TCWL 9 PC will not start
i can try set TCWL 10, 11, 12 or leave value at 13 ?
Finally the timings look like this :
124473
Make more changes or leave it?
cstkl1
7 (0.00/day)
Malaysia
example 2nd timings i run but on x299
was a basket to get this stable again from bios 0802 to 1503. Asus changed a few things. But seriously good job Asus.. a lot of improvement.
