Dead pixels and 1700 hours usage on a amazon warehouse LG C3, what do now?
40 (0.01/day)
Hi everyone, I finally moved on to an OLED on the PC, I bought a LG 42 C3 on Amazon Warehouse, it was a used but the price was not bad and with a 20% discount I paid in total "only" 550 euros, this discount I requested because the panel I saw some Dead pixels in the edges (in the right edge at the bottom only one that remains dead in all colors), and in the edges on the left and on the right, one at the bottom and one at the top , these are small row near the tv frame (see three photos)
https://i.postimg.cc/5NzJcgZd/photo-1-2025-03-18-10-10-29.jpg
https://i.postimg.cc/Z5hSJ3S9/photo-2-2025-03-18-10-10-29.jpg
https://i.postimg.cc/0ydqjQkV/photo-3-2025-03-18-10-10-29.jpg
Among other things, I also discovered that this TV has already been used for 1700 hours, at this point what do you advise me to do? On Amazon it is no longer available to be purchased therefore either I keep it at the good price I paid or I make the return having to spend much more for another model, or could LG repair the panel in your opinion?
My concern is that the dead pixels could increase over time, given that this TV has been used for many hours/months
thank you for you help
Rungar
19 (0.49/day)
looks like youve been cleaning the screen with something. never do that. it will get in there and cause damage in the edges. just use a dry dust cloth.
534 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
tbh those pixels are in the corner so you will never ever notice them 1700 hours aint too much. should check for the brun in if present.
7,971 (5.16/day)
São Paulo, Brazil
Video Card(s) NVIDIA RTX A2000 (5090 shipping to me soon™)
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
1700 hours isn't a lot if the TV was well taken care of, pixel cleaning routines done on time and mitigations against burn in enabled, especially if its brightness was set to modest settings. It looks like this was something the previous owner saw the defects and stalled to the last day they could return it. Unfortunately, this panel cannot be fixed, not even by LG - those dead pixels are dead for life, and you better hope it doesn't develop any further.
I'd send it back and put down the extra couple of bones for a brand new B4 (899 euros at Amazon.de), lacks the 144 Hz of the C4 but similar to the C3 in that regard.
96 (0.15/day)
Processor 7800X3D @ Curve Optimizer: All Core: -25
Motherboard TUF Gaming B650-Plus
Memory 2xKSM48E40BD8KM-32HM ECC RAM (ECC enabled in BIOS)
Video Card(s) 4070 @ 110W
Display(s) SAMSUNG S95B 55" QD-OLED TV
Power Supply RM850x
I have a C3 bought new at 1400 hours "Panel Usage Time" (in read out by sticking a USB-stick and pressing the blue button on the remote 5-10 times, it's then in the OLED42C*_UTT_M60.txt file on the stick). 1400 hours isn't a lot and 1700 either. The C3 has always been in PC / 4:4:4 mode, OLED brightness is set to 80 out of 100. The brightness is limited in PC mode to like 250 nits at the full 100 brightness setting. AFAIK, since C3, all OLED panels use the OLED.EX panel, which should last even longer at these low level brightness levels than the previous panel generation in C1 (C2 had a panel lotery of EX and non-EX panels). If that one pixel isn't bothering you visually and you use the TV mainly in PC mode where the brightness is limited in the first place, I wouldn't send it back. But even when used with HDR content for movies, not necessarely as a PC monitor where enabling HDR isn't recommended for static content, I maybe wouldn't send it back either.
3,051 (2.03/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASUS TUF GAMING B650-PLUS
Cooling Noctua NH-D15 G2
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) ASUS Radeon RX 7900XTX TUF Gaming OC
Display(s) Alienware AW2725DF, LG 27GS95QE-B
Case Streacom BC1 V2 Black
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software Nobara 41, ~2000 Video Games
40 (0.01/day)
You have any dead pixel on it?
JCW MINI MAN
4 (0.11/day)
I picked up on several things here...
Your thread title says 1700 hours use , Rungar thinks you cleaned it and you reply you only got it yesterday so why say its had 1700 hours use.
Dead pixels can be a bit like a mark on your room wall ...... you dont see the room you just see the mark !
Dead pixels for refunds a bit of a minefield and i found this information on another site.
There are a number of dead pixels accepted on different screen resolutions, a few of them are mentioned here
  1. A 1024 x 786 screen resolution takes up to 4 dead pixels at a time.
  2. 1280 x 1024 takes up to 7 dead pixels.
  3. 1600 x 1200 accepts approximately 10 dead pixels at a time.
  4. 2048 x 1536 takes up to 16 dead pixels in general.
This means that if for example you have a 1600 x 1200 with only 6 dead pixels .... even if they are bang in the middle of the screen you can be refused a refund.
If you search the internet you can find some free programs that claim to repair dead pixels ..... and my disclaimer is ...... its your choice to risk it i am only telling you they exist.
6,343 (2.86/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Unless this isn't the same corner we're not seeing burn in here:
If this was G series you would probably qualify for 5 year panel warranty but I would still consult with local LG office if they can do something about it. Otherwise, return to Amazon.
bug
14,221 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I have a CX (bought new). Also developed a few pixels in about the same area and a few on the left. They're not noticeable from typical viewing distance, haven't seen new ones in a while. I'd say enjoy your new purchase, don't pay too much attention to those pixels.
40 (0.01/day)
is a used tv, i bought on amazon warehouse as i said in the title and original post
