[Case Gallery] death machine
1,737 (0.25/day)
Canada
System Name death machine
Processor intel 6600 quad core cooled by scythe mutgen 2
Motherboard dfi lanparty UT P35-T2R
Cooling air
Memory crucial ballistic tracer 4 gb
Video Card(s) nvida 260 gtx
Storage segate baracuta 500 GB , western digital blue 1TB
Display(s) asus 23.6 vh242h
Case lian-li pc-a70 full tower
Power Supply 650 watt Antec Earth Watts
Software windows 7 and lots of other titles
Specs:
3.0 GHZ Intel CPU,Asus p4p800-e Deluxe Mother Board,ATI radon 3650 video card, sound blaster 24bit 5.1 sound card, OCZ premier ram @2.5-3-3-7,OCZ Value Series @3-4-4-8 Antec smart power psu 450w , western digital 80 GB hard drive,NEC DVD burner/CD burner
Mods:
added a blow hole and a zalman 7000-B ALCU cooler and fans and a cold cathode tube and cleaned up my cables i also changed the stock power led from green to red
reason for doing this is because its a pain to mod a old one
L
luix
lamborstyle pc
you isolated the wires with ribbon glue isolated me too in my pc XD very nice the red and alien on the cooler
3,288 (0.50/day)
Halifax, Canada
Processor Q6600 G0 @ 3.2Ghz
Motherboard Asus p5k-Premium/Black Pearl
Cooling Luna Block, 240mm rad
Memory Patriot Extreme PC2-6400 2x2GB
Video Card(s) Saphire 5850 1GB
Storage 60GB SSD + 2x500GB/1TB/2TB
Display(s) Samsung 226BW and 50" Panasonic S2
Case Silverstone TJ-09
Audio Device(s) X-fi Prelude
Power Supply Enermax Galaxy Dxx 850watt
Software Windows7 32Bit
Benchmark Scores Super Pi 1M 14.333
I gave you a 7 for the modding and nice shinny paint job! ah, I forgot to take in the top blowholes good job on them.. you kept a record of temps before and after? Im sure there will be a huge difference.
bigboi86
1,442 (0.22/day)
techPowerUp!
System Name Just getting started....
Processor Athlon II Propus 620 @ 3.51ghz (quad core) L3 cache enabled
Motherboard ASUS M4A785TD-V EVO
Cooling Cooler Master Hyper 212 (great heatsink, 40c max load overclocked)
Memory Kingston HyperX DDR31600 4gb 2x2
Video Card(s) ATI Radeon HD 4850 by XFX
Storage Western Digital Caviar Blue WD3200AAKS 320GB SATA
Display(s) Acer 21.5 inch viewable G215H 1920x1080p, AOC 22inch 1680x1050
Case Antec 300, stock for now
Audio Device(s) Onboard, Turtle Beach headphones / crappy logitech desktop speakers
Power Supply Corsair 650 watt PSU <3
Software Windows 7 x64
I'd give it about a 5 if I were to vote(but I wont do that). It looks like you used electrical tape to "sleeve" your PSU cables. Those blowholes are also very uneven, use a holesaw next time.
The paint job looks like it was done decently from what I see, but the pictures aren't very good and I can't tell if the paint is uneven or if those are just smudges. I also hate those Powmax cases(and most other cheap cases).
1,737 (0.25/day)
Canada
Cooling air
my wires are just raped with electrical tape
bigboi86
1,442 (0.22/day)
techPowerUp!
A
aron7676
good work
thats actually pretty good, how much did you spend on the system?
is that a vantec fan card? iv got one too if it is.
by the way... my wires are raped by black duct tape ;-]
what type of case is that?
5,410 (0.86/day)
Tennessee
System Name AM5
Processor AMD Ryzen R9 7950X
Motherboard Asrock X670E Taichi
Cooling EK AIO Basic 360
Memory Corsair Vengeance DDR5 5600 64 Gb - XMP1 Profile
Video Card(s) AMD Reference 7900 XTX 24 Gb
Storage Samsung Gen 4 980 1 TB / Samsung 8TB SSD
Display(s) Samsung 34" 240hz 4K
Case Fractal Define R7
Power Supply Seasonic PRIME PX-1300, 1300W 80+ Platinum, Full Modular
Awesome paint job; the electrical tape used to wrap the wires isn't good for this case or any case, IMO. It actually makes your wire management look worse than it already is (no offense). Use zip ties instead. Some drimmeling can be done if needed. You spent the time to make the paint very nice, now spend just a little extra to make the wire management better. Your air flow would be much better as a result! I'll save my vote.
1,737 (0.25/day)
Canada
Cooling air
well i spent probably close to 2000$ on every thing and second i am no good at doing cables and i have done a lot of moding to hide cables there are a lot more then what u see also i have not had the time nor the motive to do it
5,410 (0.86/day)
Tennessee
System Name AM5
All the more reason why you should take a little more time to make those wires better.
EDIT: Also, it looks like the case has all the holes already there for you...
1,737 (0.25/day)
Canada
Cooling air
ya but see i am working on the house so i dont feel like doing anny thing to it tell the house it back to normal
sirrep74
24 (0.00/day)
sterling, illinois
Processor amd sempron 3100+
Motherboard msi ms 7142
Cooling currently air thinking about going to water
Memory 2g pony
Video Card(s) geforce 6200
Storage 1 40g maxtor(os),1 80g(everything else)
Display(s) 1 15" e1514 lcd
Case stock e-machine w3105 w/a self modded window
Audio Device(s) none
Power Supply 400w power king w/loomed wire
Software windows xp
ill give you a 7 , but if you were going to use tape on your wire you should have used red tape at least not black
hint: autozone has 10 feet of red wire loom for 5.99 plus tax if you dont have the time to heat shrink
panchoman
Sold my stars!
9,595 (1.55/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
good case, but the thermaltake blue orb is better then that zalman and thats why i give you a 8/10 lol
DaMulta
My stars went supernova
16,168 (2.47/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
I voted 10/10 because:
Very nice
Love the paint job.
1,737 (0.25/day)
Canada
Cooling air
thanks damulta
