- Oct 9, 2007
- 47,324 (7.51/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
DeepCool brought a pair of new all-in-one liquid CPU coolers to the 2023 International CES. These include the LT series, the LS520 series, and the new FT14 case fan. The LT series is characterized by the unique geometric shape of its pump-block, which looks like a metal cube has been peeled to reveal a more solid geometric shapes inside, thanks to an illusion created by an infinity-mirror setup. DeepCool already launched debuted the LT series in October 2022, but at CES it introduced new all-white variants.
The LS520 series "smart" AIOs feature pump-blocks with LCD displays that provide real-time monitoring of the pump-speed, base-plate- and coolant temperature. These are otherwise identical to the LS series from mid-2022. Also making its debut is the FT14, a unique 140 mm case fan with a square fan-frame, which can be made to fit 120 mm fan vents, by pulling out the four corners of the frame, to reveal an inner frame with 120 mm mounts. This could prove useful where you have a 120 mm fan vent that has room for a larger impeller.
