DeepCool LT720 issue?
Alfred Stoppels
3 (0.01/day)
Lo Peepz,
Along with loads of other parts I got myself a DeepCool LT720.
My choice was to use THermal Grizzly paste with it so I cleaned the cooler block.
Used the proper alcohol and soft papercloth for it.
What I then found is seen on the picture below. I am 100% sure I did not cause it, it just revealed while cleaning it.
Any idea how this could have happened (testing example maybe)?
Second question: Is this a problem?
The AIO did not look used when the paste was still applied, it was spotless.
9,426 (3.28/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I recall seeing something similar when I changed my CPU and cleaned the paste after about 3 years, I guess it just stains over time. Shouldn't matter.
9,426 (3.28/day)
Case Phanteks NV7
Stains? ... hmm, it was brandnew, bought it a week ago :)
Yeah but I mean it could stain it regardless, it kind of looks as if you just swiped away something and it left some marks.
Alfred Stoppels
3 (0.01/day)
Could accept that if I realy scrubbed it hard but I didnt. Just gentle with only soft material. Became vissible already after the first whipe
13,097 (1.96/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Copper begins to corrode almost immediately after exposure to air (oxygen). Can you feel scratches or irregularities with your finger? If not, I would not worry about it. HOWEVER, since you just tried to feel for scratches, you just deposited skin oils on it so you need to clean it again. I would NOT however, use papercloth (whatever that is) - unless specifically designed for eyeglasses and from a reputable company like Bausch & Lomb. I use a clean, microfiber cloth designed for eyeglasses.
