- Oct 9, 2007
- 47,424 (7.51/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
At the 2023 Computex, DeepCool showed off its largest all-in-one, closed-loop liquid CPU cooler to date, the LT820. This monstrosity features a 420 mm x 140 mm (3x 140 mm) radiator, along with a trio of FT14 fluid dynamic bearings 140 mm fans. It uses the same groovy cuboidal "multidimensional infinity mirror pump cap" as the company puts is, which it had debuted with the LS512 and LT720 coolers in October 2022. This uses the 4th Gen DeepCool pump-block system in its highest state of tune (for the most coolant pressure to run through the large radiator). The Cooler also includes DeepCool's anti-leak tech inside, which is basically a rubber bulb that normalizes the impact of changing ambient air-pressure on the sealed coolant loop. The LS720 SE Digital WH is a design update over the LS720 the company debuted last October. This 360 mm AIO cooler comes with an all-white aesthetic, the company's 4th Gen in-house pump-block technology, and gets its name from a 7-segment display on the pump-block that displays coolant temperature in real-time (much like the "Digital" series air-coolers by the company).
