Delidded 4790k temp drop then spike in temperature? Thermal Grizzly C-series Liquid Metal + MX2
265 (0.05/day)
System Name Intranetusa PC
Processor i7 2600K @ 4GHz
Motherboard Asrock P67 Extreme4
Cooling Cooler Master N520
Memory 16GB DDR3 1600MHz RAM
Video Card(s) GTX1060
Storage Samsung SSD, Samsung 1TB Spinpoint, Hitachi 2TB
Case Cooler Master Elite
Power Supply Zalman 750watt PSU
Software Windows 7
So I delidded my 4790k and applied a tiny amount of liquid metal (Thermal Grizzly C-series). I also reattached my lapped IHS with black silicone adhesive (with some gaps for air) and applied a layer of clear nail polish to the CPU circuits near the die so the liquid metal won't short it out on accidental contact. For the heatsink + cpu IHS, I used a small line + 4 dots in the corners of MX-2 thermal paste.
When I tested my cpu, initially everything was ok. 35'C idle, 65'C max Prime 95 Small FFT. Then an hour later, idle temperatures are around 45'C, and Prime 95 SFFT now maxes out at 88'C. This is not normal I presume?
Did I do something wrong? (eg. apply too little or too much liquid metal?, used too much pressure on the IHS and die?)
Here are pics of the liquid metal application:
520 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
Conductonaut thermal grease must not be used with aluminum heatsinks!
720 (0.11/day)
Processor i9 9900k @ 4.8 Ghz
Motherboard Asrock Z370 Taichi
Cooling Xspc raystorm direct die, 2x 480 swiftech rads + 2x 120 block ice rads D5, Monsoon Dualbay Res
Memory 32gb G.Skill DDR4 3200mhz CL14
Video Card(s) Gigabyte Aorus 3080 Ti Waterforce WB shunt mod
Storage Samsung Evo 860 500gb, Samsung Evo 860 1Tb x2, WD White 12tb x2
Display(s) Acer xb270hu 144hz 2560x1440
Case Enthoo Primo
Audio Device(s) Schiit Modi Multibit/Magni3 - M1060 (fuzzor+LQi cable+Eikon suede)/ATH-W1000X (Purrin's mod+suede)
Power Supply EVGA SuperNova 1300w
Mouse Razer Orochi
Keyboard Tesoro
Software TeamOS W10 Pro/W7 Pro
He said he used MX-2 between the ihs and heatsink...
I am not sure what would cause such a rise in temps after some time like that. I have heard this happen before with conductonaut but I have only ever used coolab liquid pro. Maybe reseat your cooler and reapply the MX-2 again and see if temps go back down and it happens again. Then you'd know that it was the MX-2 and not the conductonaut giving you issues. If no change, re-delid, check your conductonaut, clean it, reapply, and try again.
I would keep testing to see where the issue is. Once you find it, maybe switch thermal compounds and see it changes your results. Keep a good log of what temps you get with what compounds at what time interval after delid etc.
Mussels
Freshwater Moderator
58,413 (7.88/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
the silicone you used probably expanded and made the IHS shift
Put it back into the socket and let the clamp hold it down, or use a small drop of superglue on a corner to hold it in
265 (0.05/day)
Software Windows 7
I put the ihs on the die and had the cpu clamped by the bracket on the motherboard as soon as I applied the liquid and silicone. I then mounted the heatsink - all within 30min. Is it possible for it to expand even with this pressure? How much does silicone expand?
Does my liquid metal application look incorrect/insufficient?
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
If the silicone hadn't cured, uneven pressure might have tilted the IHS slightly, that's my guess and probably what @Mussels is thinking too.
I did a 3570k both with IHS and naked. Never had a problem with the IHS (I never put silicone back on it, btw), but had similar problems to you with running it naked. Took some heatsink pressure tweaking.
Oh and I don't think silicon expands, but you'd have to look at the specs for it.
265 (0.05/day)
Software Windows 7
What do you mean you had the 3570k naked? No IHS/heatsink directly on die?
Did you solve the problem with more pressure or alleviating pressure?
Since I have to take everything apart again, do I need to reapply the liquid metal or can I just leave on what I currently have?
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Yes, I had to crank down pretty hard and try different pressures on the waterblock screws to get it directly on the die. Sometimes it wouldn't boot, other times it would be very unstable. When I got it set, it was stable. Ironically, the temps between naked and IHS were negligible. I ended up putting the IHS back on several months later when I was doing some maintenance.
I have never worked with liquid metal, so I don't know what the consistency is and I don't know how forgiving it is. I use AS5 paste, it flows into gaps nicely and stays there.
720 (0.11/day)
Case Enthoo Primo
Mouse Razer Orochi
Keyboard Tesoro
Ah yeah. I don't reseal my ihs either. I just use the cpu clamp to keep the ihs in place.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
i had great results with my 4790. I used a spot of gasket sealer on each of the 4 corners, "painted" the die with grizzly conductonaut, and that was it. Im aware of people putting polish on , but never did myself when delidding. Just need to redo if its not working good for you. iirc, i had one hotter core for a day or two after i delidded, but its cold as ice now.
Re do all.
265 (0.05/day)
Software Windows 7
Re do all.
Gotcha. I think the mistake I did was I put the sealer on the bottom of the IHS corners. I'm not supposed to put the adhesive between the IHS and the CPU substrate right? I'm supposed to put on the IHS first without sealant, and then dab the edge where the IHS/CPU meets with the adhesive?
10,885 (1.56/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Either method should work, just use it sparingly. I never put sealer on mine, just put the chip in, IHS on top and let the socket clamp hold it in place before installing the heatsink. Did that several times and never had an issue. I did seal the chip when I sold it, I think I just dabbed the corners with white silicone sealer and tested it after curing a few days.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
i will toss a couple pics i took when i did my 8600k, & my 4790. Ive used super glue after putting the IHS back on, and just put a dot on each corner. Ive also done spots of Gasket sealer in a few spots (under IHS like in pic below) as long as your not putting too much, it wont interfere with seal.
i like to put LM on both Die & IHS. (if you do this be careful your familiar with how much LM to use)
this is how i usually apply Gasket Sealant. Or i just put it under the four corners.
note the scotch tape, i use it to make LM application SUPER easy, as you cant get it anywhere but the Die.
i use a toothpick or similar small tool to apply.
you can see here how badly my 4790 needed delidding
265 (0.05/day)
Software Windows 7
Thanks. Do you recommend putting a decent amount of liquid metal on both the IHS and die? I put it mostly on the die, and then rubbed smidgens of leftover stuff on the IHS. I rubbed nitrocellulose nail polish over the circuits next to the die to protect it, so I don't think short circuiting from residual LM is too much of an issue.
So both putting the silicone sealant underneath the IHS and putting it on the corners/edges of the IHS (not underneath it) both work? Did you notice the difference between the two?
I'm wondering if I messed up by using a bit too much underneath it, so maybe the edge/corners method would work better for me.
9,781 (2.18/day)
Massachusetts
Processor i7-11700K
Remember you're not trying to permanently fasten this IHS down ,or anything serious, don't try to do what the factory did ,just put enough to hold the IHS down and that's it. You could literally apply it with a paintbrush if you were able to spread it with one ,and then vice clamp it down. In the picture I posted earlier, what you see on the end of that toothpick ,is basically what you need for the entire job.
Also make sure your clamping it down with a vice for an hour or two while the sealant sets up , or longer. As long as you're applying enough pressure while the sealant cures, it won't matter what you put on ,because any excess is going to push out on the inside and on the outside, so you're going to want to put as little as possible while having enough toform a bond.
If you're not comfortable with this method, I would suggest if you don't have success using sealant, to just put the IHS back on the chip ,and put a couple drops of super glue on 2 of the corners.
remember all you need from whatever bonding agent you use ,is enough to hold the IHS on while you install it into the motherboard ,because you're going to clamp a heat sink or a cooler on top of it .
i did it because i had enough out of the syringe to apply it to both, but you dont want too much, so be careful.
Edit:
I just noticed that you posted you lapped the ihs, I wouldn't of done that personally because there's no need (unless you have pitted surface, corrosion, etc). Did you lapp the top or the bottom of the IHS? Please post a clear & detailed pic. Unless you've gotten low temperatures after the lapping process, it could be the cause of higher/fluctuating temperatures.
