Hello,
I am trying the combination listed in title. I really need your help, at least to understand what is wrong in the following set up I tried. I saw in this forum that people seem to have knowledge to bring valuable help (https://www.techpowerup.com/forums/threads/dell-workstation-owners-club.243124/page-50). I give here maximum details on what I did.
Nominal configuration that works with both following PSUs :
Dell Precision T7810
Dell PSU 685W or 1300W
2 x Xeon 2690 v4
RAM 256 GB
nVidia Quadro K4000
I made some tests to understand the rail configuration on my PSUs : Dell 685 and 1300 W. The sticker on the PSU top lists 5 and 10 rails respectively.
Both PSUs work like a charm in my T7810 workstation.
The distribution board I have to power my T7810 cannot use all the rails provided by the 1300 W PSU.
In that way, the 685 W PSU is enough for a standard geared motherboard in this workstation.
Just to mention, the T7600 workstation may fully use the 1300 W PSU. I have also have this distribution board.
In both distribution boards, the rails are connected to the pins identified A1 to A32 and some from between B1 to B32. At least 18 lines in B are connected to the ground. Power is mainly provided by A lines. A lines form sets to power the connectors on the distribution board.
In the T7810 distribution board, for example, the P1 connector uses 2 sets of lines : 5 pins for the ground and 3 pins connected to A9-11 lines. A9-11 lines seems to form an independent power source dedicated to feed a video card. This distribution board does not use A12-14 and A29-32 power sets. However they are used on the T7600 distribution board to feed a video card and one of the CPUs. Hence I know where to find additional power from my 1300W PSU.
From the T7810 distribution board, I see 7 power sets but the 685 W PSU has only 5 rails. From the T7600 distribution board, I see 10 power sets and 1300 W PSU has 10 rails. I do not know what is the exact relation between a rail and a power set.
If A12-14 and A29-32 power sets are matching 2 rails, I would expect to get 2 x 12V x 18 A = 432 W.
I plugged a Tesla k80 card using extra wires I soldered on A12-14 and A29-32 that I mounted in a 8-pin EPS plug which fits in this K80 device. Precisely A12-14 pins connect pins 7 and 8, and A25-28 pins connect pins 5 and 6 on the Tesla board (https://www.nvidia.com/content/dam/en-zz/Solutions/Data-Center/tesla-product-literature/Tesla-K80-Bo.... On the Tesla side, the EPS connector requires 225 W. I hypothetized that A12-14 plus A25-28 may bring 432 W.
Since my nominal configuration works with less than 685W, adding the K80 board cannot drain more than 685+300 = 985 W. I should be okay with the 1300W PSU.
Note that I printed a plastic guide to funnel air from the T7810 front fans througth the K80 passive dissipator : air has no choice than to blow inside the K80 box.
Result with the 1300 W PSU. When the Tesla card is seated in a 16X PCIe 3.0 slot without plugging my extra EPS plug, the T7810 starts normally (of course, in that way, I cannot use the card). When I plug this extra cable, the PSU seems to continuously restart (nothing appears on the screen, I cannot reach the BIOS and no beep is emitted). Note : "Memory Map IO above 4GB" is set in the BIOS.
Despite of the fact this result is frustrating after so much effort, I wonder if someone may bring any information or point any mistake that may help me to reach my goal to have the Tesla k80 card powered correctly.
Thank you for your help.
2 x Xeon 2690 v4
RAM 256 GB
nVidia Quadro K4000
