Dell T7810 workstation standard power supply???
CloudX99
11 (0.09/day)
I have a lot of Dell T7810 workstations and I want to make it work on a standard power supplies that available on market so is there anyone got it working or any other solution???
I found a lot of helpful info online but it didn’t seem to be working for me
12,820 (1.93/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
If you google 24-pin connector pinout, you will see your clearly is NOT standard. No surprise since Dell is notorious for using proprietary supplies.
What you can do is get yourself a PSU Tester. With these, you can test the supply without worrying about damaging a motherboard.
If you want to use those Dell workstation supplies, you will need to use a proprietary, compatible, Dell PSU.
CloudX99
11 (0.09/day)
To be exact I’m trying to make a normal PSU compatible with this T7810 motherboard (by modding the PSU)
My PSU is Fantech Shadow PSB 550
Added DC-DC booster for the 5vsb wire to make it 12vsb
Toothless
Tech, Games, and TPU!
9,517 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
You're going to short or cause a fire. Just search a proper COMPATIBLE replacement.
864 (0.60/day)
System Name ASUS TUF F15
Processor Intel Core i7-11800H
Motherboard ASUS FX506HC
Cooling Laptop built-in cooling lol
Memory 1G6B @ 3200
Video Card(s) Intel UHD & Nvidia RTX 3050 Mobile
Storage Adata XPG SX8200 Pro 512 GB & WD Blue SN520 128 GB
Display(s) Laptop built-in 144 Hz FHD screen
Audio Device(s) LOGITECH 2.1-channel
Power Supply ASUS 180W PSU
Mouse Logitech G604
Keyboard SteelSeries Apex 7 TKL
Software Windows 10 Enterprise 21H2 LTSC
there are "adapters" to Dell MB. I have old Optiplex 3020 (don't remember but it's Haswell H81 chipset so Intel 4 gen CPUs), and I've seen "adapters" for standard PSUs to its MB if I ever need it. Maybe for your model there are exist same things. Try Aliexpress or eBay.
No need for any "inverters" or "boosters" extra for god sake, lol
12,820 (1.93/day)
Nebraska, USA
Mouse Logitech M190
Or ATXPowerSupplies.com. Note that link just goes to an example. You need to verify compatibility before buying.
I do NOT recommend modifying the connectors yourself by cutting, splicing and moving wires.
Because we are talking about low voltage DC (+12V maximum) I would not be worried about fires. But certainly shorts are possible resulting in permanently damaged components, including CPUs, GPUs, RAM modules, chipsets, drives, and/or the motherboard - not to mention the PSU itself.
CloudX99
11 (0.09/day)
I have searched a lot for adapters but unfortunately there is no single one available for Dell T7810 that’s why I’m trying to mod the PSU
Toothless
9,517 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
There are tons of units on the used market. Too many to justify you using that junk power supply that you're trying to use. (no name, bronze, etc)
You're going to find it hard for anyone with common sense to help.
CloudX99
11 (0.09/day)
You're going to find it hard for anyone with common sense to help. I know that there is a lot of available OEM PSUs online but the issue is the shipping because there is no direct shipping to my country that'swhy I can’t buy it and even if I use some sites like myUS to ship it to my country the shipping will cost more than the cost of the PSU
Toothless
9,517 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Pay extra shipping or use a junk unit, play electrician without knowing what is what, and nuke the workstation..
I think I know which one I'd do.
CloudX99
11 (0.09/day)
As I said before
I have about 30 pcs of this MB so I don’t care if I lost one of them if I had to sacrifice one of them
At least one will work that will be enough
4,912 (3.85/day)
Colorado, U.S.A.
Software Windows 11 Home
What is wrong with the original supplies?
4,912 (3.85/day)
Colorado, U.S.A.
When I read 'I have a lot of Dell T7810 workstations' I assumed you had the original power supplies.
4,912 (3.85/day)
Colorado, U.S.A.
A T7810 supply is only about $22 second hand with shipping
5,683 (0.79/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Keyboard Razer Pro Type Ultra
Not efficient as other brands
I guarantee you that the Dell PSU is better quality than the supposedly Bronze-rated piece of shit you're intending to replace it with.
Toothless
9,517 (2.49/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Can vouch, my T3610 has a gold rated unit.
13,850 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Compare the pin out on the Dell connector to a standard ATX power supply and remove and swap pins as required.
You will need to jump two extra +12V pins and remove others based on the diagrams.
CloudX99
11 (0.09/day)
Didn’t work but I will try to replace the rams
12,820 (1.93/day)
Nebraska, USA
Mouse Logitech M190
Yeah, I sure would NOT rate Dell supplies as top-tier but I would definitely rate them higher than any no-name or off-brand generic.
And BTW, if you look here in the CLEARResult database (the official keeper of the 80 PLUS certification program), I see no Fantech PSU listed at all. That would make me question whether or not that 80 PLUS Bronze logo is truly authorized to be there.
That said, it must be noted that 80 PLUS certification is NOT an indication of quality, reliability, or any compliance with the ATX Form Factor standard. It is ONLY an indication of a relatively "flat" efficiency curve across a wide range of load levels - certainly important - but nothing conclusive in terms of quality.
CloudX99
11 (0.09/day)
The only thing I want right now is to get the system working with a standard PSU because as I said before : I can’t buy the original Dell PSU that’s why I want to mod the standard PSU
12,820 (1.93/day)
Nebraska, USA
Mouse Logitech M190
You would need to know the true pin-out configuration of the exact original PSU and compare that to the exact PSU you want to put in there. If you are not a qualified tech with the necessary test equipment, tools, and skills, then not sure what to suggest.
Do you know for a fact these motherboards even work? Do you have working RAM and CPUs to mount on them?
Ruru
S.T.A.R.S.
12,207 (2.84/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 256+240+128+480+2x1TB SSDs + 3TB HDDs
Audio Device(s) Asus TUF H3 Wireless
VR HMD Oculus Rift CV1
Without reading the thread, does adapters exist for that model? I've seen many cheap gaming PC builds on Youtube where they use old Dells, get an adapter and run those with a good quality standard ATX PSUs.
